gaussā¦. :person_facepalming: ā¦ Iām not ragginā on you my friend. But this is what I am talking aboutā¦. I even ātriedā to look it up. . No joyā¦
Given, I am not the sharpest knife in the drawerā¦ but this sounds like it came straight from a Jargon Generator ā¦ :weary:
Meta-level tangents = å ē“åē· ā¦ā¦. both of these mean about the same thing to me.
Your gonna have to try and ādumb it downā a bit more or at least provide a link so I can find out what you mean when you write something like thisā¦. please.
Maybe that is how I learned how to use forumsā¦. but at this rate Iāll never know for sure.
I just completed a trivial test with 3 chargersā- 3100 / 3400 / Liitokala 500
With a 3 cell group of NOS laptop pulls that were charged and matched a year ago on the 3400 ( didnāt want to abuse good cells)
My conclusionāthe BT-3100 mah reading is around 5-6 percent higher than the other 2 chargersāThe 3400 and the 500 test fairly close on averageāamazing considering the Opusā discharge @ 1 amp and the Lii 500 @ .5 ampāā When you compare the readings as a group,then figure their percentage matchāall 3 chargers are very close in that regardā- this set of cells with all 3 chargers is around 4% matchā Not sure why there is #1 cell that is a flyer ( target term) but the overall average is pretty consistent
I love the UI of the Opus, but I feel like itās worth the price point. I constantly get ghost battery indications (screen reads FULL after I take the battery out), bad voltage readings (full battery reads 0.2v), the fan has been giving me trouble for 2 years and just died, and one of the negative terminals snapped off so Iām left with 3 slots.
So Iāve heard that the newer Opus chargers have fixed these issues, but it makes me wonder if I should just invest in a higher priced charger
I donāt know if all the issues have been āfixedā or not on the OPUS. We discussed a bunch in this thread & a couple of others too.
My 3100 v2.2 works fine & I have no issues at all now that I upgraded the power supply.
Never had any issues at all with the Lii 500ā¦ it is my favorite.
I know this is an old old thread but I bought the 3400 ,and when I asked the seller from e-bay (rdna)told the difference was the āsofrtwareā
Thatās all he knew or told me I have had it a little over a year and the only issue I have had is the power source melted and the seller is sending me a new one under warranty
That LITEON is sold out, and my Opus V2.2 came with the KYT 12V 3A power supply.
Is there another power supply you can recommend for this charger? Will any old 12V >=4A power supply work better than the supplied supply, or are there characteristics I should be looking for, like that efficiency standard?
At the 7 second mark of the video shows the Opus BT-C3100 V2.2 Charger sparking electricity, yellow flashes at the input plug connection every time I plug in power using the included 12 Volt charger(also used another 12V charger which also is sparking). Tested the included charger with my multi-meter and the charger is only 12.3 Volts DC. Is this a FIRE HAZARD? None of my other battery chargers ever spark. Connected the charger through my OPTI-UPS Grounded Surge Protector so its not an outlet issue, which I also tested and works fine with other electronics.
Reading through this thead on Page 4 about the āā¦The Opus will draw more than 3A in peak current, in my test I measured 6A for nearly 0.02 second. Then 0A for 0.03 seconds, bringing the average below 3A.ā and reviewer listed āPower adapter: DC 12V, 3.0A ( Output ), 100 ā 240V, 50 / 60Hz ( Input ) ā
Best I remember this was discussed in one of these threads. It is normal . Mine does it. If you plug the 12 V in before you do the main it (of course) wonāt do it.
