✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Hunting Tactical FMA Helmet Safety Light LED Flashing for Airsoft Bike Sports Driving is in preorder for $10.99 and with BG points working it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$9.34
$9.23
$9.12
$9.01
$8.79
This LED marker is also known as FMA V-lite or E-lite (because it’s a clone of $40 S&S V-lite marker), it’s velcro backed, uses CR2032 lithium battery and operate for up to 120h. The light has two modes: constant and blinking and it’s made with elastic silicone so it’s completely waterproof and shock resistant. Good alternative for chemical lights.
DC5V 30W 2400lm 4 Light Modes Portable USB Charging Flood Light LED Emergency Light in preorder for $9.99. Using BG points it’s possible to lower the price further:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$8.49
$8.39
$8.29
$8.19
$7.99
Works one or two parallel 18650 cells which are not included, has USB output (can be used as powerbank) and additional red and blue LEDs for red,blue and purple light modes.
XANES 2305 800 Lumens T6+2xCOB LED Bicycle Headlight Mechanical Zoom Outdoor Sports HeadLamp 4 Modes Adjustable Head Light for VIP2 accounts and above is for $7.99 and with BG points it’s possible to further lower the price to:
VIP2
VIP3
VIP4
VIP5
$6.71
$6.63
$6.55
$6.39
Be advised: main LED is probably some kind of XM-L clone, because there’s no Cree name in the description to be found. Still - for the price it should provide ample amount of light from 2x18650 cells - even stated 800lm should be possible but probably designates at best LED lumen. Two COB LEDs provide flood light, main LED is zoomable. There are 3 colors to choose from: black, red and blue.
BlitzWolf® AmpCore BW-TC5 3A USB Type-C Braided Charging Data Cable 3.33ft/1m With Magic Tape Strap on sale for $2.99. Very good USB type C 3A cables, supposedly able to tow 1,5t car :slight_smile: Two colors, cable organizer included.
BlitzWolf® Ampcore BW-MC4 2.4A Micro USB Braided Cable 3.33ft/1m for Samsung S7 Redmi Note 4.
This one is for micro USB version, $3.59
Link for all Blitzwolf Ampcore cables - including Apple/lightning ones.
BlitzWolf® BW-MC1 2.4A Micro USB Braided Charging Data Cable 3.33ft/1m With Magic Tape Strap
This one is also micro USB cable, the price is $2.99. Cable organizer is also included (aka. “Magic tape strap”), there’s also free car charger included as gift but it’s only capable of 700mA output.
Update: Deal expired.
BlitzWolf® 20W 3A BW-L1 Foldable Portable SunPower Solar Charger USB Solar Panel Charger with Power3S for iPhone 6s / 6 / Plus, iPad Air / mini, Galaxy S6 and More is now in preorder till May 31 for $42.99
It the most cost effective option on the market right now - parameters are not overstated: 2 USB output ports able to deliver up to 3A of current (combined) so its able to charge any smartphone out there. It doesn’t even require full sun to charge(performance is reduced of course). The same product is sold on amazon and elsewhere under Anker 20W and Anker 21W panel if you want to search for more reviews.
Astrolux SC Copper XPL-HI 1400lumens LED Flashlight 14500 is for $31.95
Both tints 1A and 3B are avaialable.
MUSTOOL MT833 2000 Counts Auto Ranging Digital Multimeters DC Current Frequency Capacitance Resistance Diodes Transistor Audible Continuity Tester is for $11.11 for all accounts now.
Astrolux TB-01 Bullet Copper/Stainless Steel 45LM Mini LED Keychain Flashlight is for $3.29
Astrolux TB-01 Bullet Aluminium Alloy 45LM Mini LED Keychain Flashlight is for $2.26
Two sets of batteries are included with either version.
Those lights are good as zipper pulls because of their size.
Astrolux K01 CU XP-L 7/4modes 1400LM Tactical EDC LED Flashlight 14500 for VIP2 and above accounts the price is $29.95 and using BG points it’s possible to lower the price even more:
VIP2
VIP3
VIP4
VIP5
$25.16
$24.86
$24.56
$23.96
Lumintop Ant Stainless Steel/Brass XP-G2 R5 120LM EDC Mini LED Flashlight is now in preorder for $25.90 (brass version) and $26.90 (stainless version). BG points are working so it’s possible to lower the price even further to:
Brass version:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$22.02
$21.76
$21.50
$21.24
$20.72
Stainless version:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$22.87
$21.60
$22.33
$22.06
$21.52
Lenovo ZUK Z2 5.0 inch 4GB RAM 64GB ROM Snapdragon 820 2.15GHz Quad-core 4G Smartphone is in promotion for $175.99 and BG points still work, so having enough points it’s possible to lower the price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$149.59
$147.83
$146.07
$144.31
$140.79
KEWEISI 3V-9V 0-3A USB Charger Power Battery Capacity Tester Voltage Current Meter is now for $3.27 and using BG points price can be lowered to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$2.78
$2.75
$2.71
$2.68
$2.62
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight is right now for only $23.95. All three LED options available.
Coupon code is now available: use code 8a955d to lower the price to $25.50
18650 extension tube available here:
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $2.49 (BG points can be used to lower price further).
BlitzWolf® Graphene Earphone BW-ES1 In-ear Wired Control Earphone With Microphone
Good value earphones with graphene diaphragm converters now for $11.99
ARILUX® AL-SL06 Solar Powered 62 LED PIR Motion Sensor Light Outdoor Waterproof IP65 Wall Lamp
for VIP2 and above at only $19.99 and using BG points it’s possible to lower the price to:
VIP2
VIP3
VIP4
VIP5
$16.79
$16.59
$16.39
$15.99
$1.28 for Outdoor Portable Silicon LED Light Night Running Mini Safety Hanging Lamp Warning Light and using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$1.09
$1.08
$1.06
$1.05
$1.02
$19.95 4PCS NCR18650B 3.7V 3400mAh Protected Rechargeable Lithium Battery using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$16.96
$16.76
$16.56
$16.36
$15.96
Nitecore MT06MD Nichia 219B 180LM LED Pocket Medical Penlight Flashlight
Using coupon code price drops considerably. »Request deal info via PM here«
The flashlight uses 2xAAA cells and Nichia 219B LED with CRI over 90 at CCT=5000K. It has 3 modes and always starts in low (4lm), medium is at 45lm and high at 180lm.
$39.99 EKEN H9 WiFi Sport Action Camera DV Car DVR SPCA6350 4K 25fps 1080p 60fps 720P 120fps New Version
This is the new version with round lens housing.
$44.99 EKEN H9R Sports Action Camera 4K Ultra HD 2.4G Remote WiFi 170 Degree Wide Angle
This version is equipped with mini remote control.
Other Eken cameras
For the ones without dedicated promotion use EKEN20%1 and/or EKEN20%2 coupon codes to lower price by 20%.
Following deal has expired. Send me a PM for a valid coupon code.
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight is now in preorder for $42.95 but using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$36.51
$36.08
$35.65
$35.22
$34.36
XP-G3 and Nichia 219C hight CRI available. Registered shipping included. Colored version is also available in the same price - links below:
Astrolux S42S Colored 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
To utilize LEDs to max extent and be able to get the most light it’s best to use 18650 high current drain cell.
Matching extension tubes are available:
Astrolux S41S/S42S Colored LED Flashlight 18650 Extension Tube Body Tube for $9(silver) / $11(heat colored) and using BG points it’s possible to lower price as well:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$7.65/$9.35
$7.56/$9.24
$7.47/$9.13
$7.38/$9.02
$7.20/$8.80
