Ok thanks and the double switch?
It’s just that I have that NC EC21 that I can’t get rid of so I’m thinking of modding it with another driver. I also find the red LED underpowered, not enough lumen to light the path you’re walking on. It’s only good for reading something upclose…. I ws hoping I could do it with one of the drivers Lexel is putting together with your firmware.
Ah, a new version, so I should write a new cheat sheet.
Wasn’t there a feature if you switch to maximum brightness it does a quick ramp, to not stress the eyes?
A fade from on and a fade to off, like the olight S1R.
ttrev has the meld driver. It’s designed for multicolor lights but it can be used with a single white and has double e-switch support. The firmware has an option to run both a primary white and a secondary emitter/laser. I believe you could take advantage of the ec21 by adding a better red led or a laser like ttrev did to his. Check into it anyway as my information may not be spot on.
Ok - think you are referring to the method to turn the Indicator LED off - from OFF: click to ON, then quickly click OFF. This will leave the Indicator off when the main LED is off. I added this now to the reference manual .
Dang, I recall this being discussed but forgot bout it. I'm maintaining a list of open issues, so I'll add this to the list -- ok, OpenIssues.txt is updated .
List so far is below, but it's a work-in-progress that would probably never end
Open Issues ----------- - FIXED: Tom E: in mode sets, step down settings wasn't working correctly - FIXED: 1 Lexel/BLF spotted: Blinkies unable to turn off in ramping - FIXED: delay processing of fast click operations to avoid max/turbo flash and allow more fast click options (over 4 doesn't work) - re-work triple channel ramping tables: add more to the FET range, check/test for different # of 7135's in the bank (5/27: not sure this is necessary now with new 3 chan ramping table) - add in buck driver support cleanly
Possible New Features --------------------- - joechina recommended to do a quick ramp to max, maybe even quick fade to OFF to ease tension to the eyes. The Olight A1R does this. - research "bump protection" - tolerate a short loss of power - build in a method to show the current config settings - more blinky modes, like lightning, etc.
Yea, ttrev designed the meld driver around being able to control separate LED's, plus the driver is designed to match so that's a big advantage. Also he uses PIC MCU's which have more capabilities than the ATMEL's we are currently using. That sort of capability is better suited for the ATMEL's with much more I/O pins. I'd rather go straight to the ATMEL ATtiny1617 that has twice the memory of the ATtiny85 and much more I/O pins.
OP updated. There will be more info added, just not sure yet where/how to organize it yet.
I need to get this latest version installed in some of my more favorite lights.
I tested the one channel configuration on the FET of a 2 channel board in a SupFire L5. The low levels in ramping don't look smooth - not sure what's goin on there - there's noticeable flicker. Might be the high PWM rate combined with low PWM value driving the FET, not sure.
Sorry I missed all this. I knew about the meld driver but I tought it would be overkill for one LED and one through hole red LED. I wouldn’t mind using the red LED like an indicator LED, modify the firmware a bit so that it stays on instead of blinking but the 2 switches should still be operational. But I’ll have another look into that driver. Thank you for the replies and sorry for the OT.
Dunno why I stuck that on the list - really hard to tell whether it was a serious request or not. I have no plans to do it, unless I was totally bored which I don't see anytime soon .
Edit - Important Update
I just updated the source and HEX files. Realized I had the default moon mode set to a PWM value of 4, thinking it may help on certain 7135's -- had to back that change out. It's now restored to a default moon mode level of 3 (not 4). 3 is the value documented in the reference manual, so now the code matches.
