Insane monster build!! :+1:
These are dedomed XPL V6, so already higher luminance than available XPL HI bins.
Wow amazing work, who needs a tn42 when you can have this
Xpl hi only goes up to V3 bin. Xpl v6 throws more when dedomed.
Xpl hi is nice for choosing what tint you prefer and not having to dedome emitters
Yeah, but does it tailstand?
My god man, get a grip on it! That is one cool build!
Heh. The beam should be like a TN42 but with 4x the beam area (twice the beam width).
It does tail-stand. I also left room on the tail cap to make a lanyard/shoulder strap hole.
Great build and very BLF
To could also carefully drill 3 holes in the lens around the center reflector and fix the lens with bolds (rubber rings under the heads) in the led base plate.
That’s an interesting idea, thanks.
OK, I got some beamshots. The location is a lake. There are small docks with benches distributed along the shore. The distance between the two I’ve chosen is about 500m. You can just make out the dock in the beamshots. Unfortunately it cooled down today and tonight so there is a bit of moisture in the air.
This is what one of the docks looks like.
I have beamshots of 4 of my throwy lights, widely distributed in candela. All photos have the same exposure settings and, at least on my computer, they look roughly what it looked like in real life.
First is an Eagle Eye X6 with dedomed XPL V6 1A with Ledil Iris TIR. It has about 95Kcd.
Next is my fresnel lens Convoy C8 conversion with dedomed XPG2. It has around 166Kcd.
Next is a larger fresnel lens light (60mm active diameter) with dedomed XPG2. It has around 310Kcd.
Next is the monster 7x C8 high output thrower with ~740Kcd.
It puts a lot of light downrange and really is in a separate league compared to my other lights.
Impressive!
Impessive? I’ll up that one and go super impressive.
Lux that high with a hotspot that big is just awesome Great job
That’s one heck of a thrower!
Whoa! Heck yea, that’ll do it!
Well said. This is what l was thinking but couldn’t put it in words.
nice!
super? no hyper impressive!
dang what wall of light, no more a train of light
Not nearly bright enough for me but I guess it would be “okay” for walking the dog or something.
I’ve been thinking about my next very high output light and decided upgrading the emitters in this 7xC8 light is a good route. I will replace the dedomed XPLs with sliced XHP50.2s. With 2 high drain aspire 26650s I should get around 5.5A per emitter (6V ). I just tested a sliced XHP50.2 in a C8 at 5.5A and got 3100 lumens OTF and 69Kcd, so the full light should output around 22000 lumens and do 480Kcd. Will update when I get the mod done. :sunglasses:
Sounds absurd. I love it!
