I use Narsil v1.2 so I can have the lvp, but you can’t have that and thermal monitoring at the same time.
Maybe v1.2 has a timed stepdown?
That’s no big deal as I use my hand to monitor temperature. For normal use I adjust to slightly below turbo output. You still get bright output, but much less heat and battery load. That’s much more practical. Then as the voltage runs down I go back to full output.
I save the full output with fresh cells for testing or showing off. Lol
The stock driver is a buck driver, tailcap amps are basically a useless measurement for buck and boost drivers.
Buck drivers keep a constant output current but the input current will vary with voltage. Higher input voltage = lower input amps and vice versa. So in this case the lower the amps, the better the battery.
Cool write-up Jason! When I want to mod my L6 I will find my inspiration here. The lighted switch will certainly be on the list! (and XHP70.2 and SMO reflector).
It’s funny because I’ve done a ton of amp draws on the FX30 and never noticed the amp draw at the tail increase as the batteries went down. In fact, as the batteries went down I could notice the output (both amperage and lumens) dropping. It did stay pretty bright at first, but below 3.7v or so it was noticably dimmer.
I wonder why these driver specifics were never mentioned before in any of the L6 threads?
I and others have mentioned them before many times. Even put the driver though a full test on the bench to see exactly what it did.
The output remained more or less constant from an input voltage of 8.4V down to around ~7.8V. The output them spiked a bit for some reason from 7.8-7.6V before dropping back to normal until it could not maintain regulation anymore. Somewhere in the low 7V range (which would be about 3.7v per cell). Although all of this is from memory, so don’t take those voltages as gospel.
At that point it was just a high resistance direct drive driver and output would drop as voltage dropped.
This is exactly what you would expect from a cheap buck driver and how it is supposed to work (minus the spike in output in the 7.7V range).
I did try the xhp50.2 with the FX30 and wire across the resistors. I didn’t have my clamp meter then, but I think the amp draw was 9 or 10 amps. I didn’t even think the FX30 could handle that much without smoking something.
They are very similar, but you can’t have both low voltage protection and the indicator led on the 2 cell version of this driver.
Narsil v1.2 has LVP, but no temperature support or indicator led support.
Narsil V1.4 does not have LVP, but does have temperature support and indicator led support.
Basically the indicator is a little fancier than the power indicator. It can be programmed to stay on when the rear switch is on or you can manually turn it off. When you do a battery check the main beam as well as indicator led blink at the same time.
With my light I only needed the power indicator so that I know when the rear switch is on and off. So I chose to have the LVP and no indicator led or temperature support. I can measure the temperature with my hand. Lol
Which is better between what? V1.2 and v1.4 or do you mean both of them compared to M?
1.2 and 1.4 are equally good, they just have different options. Narsil M is supposed to have the ability to let you assign pin 7 so you can choose between temperature sensors or lvp. I’m not an expert in Narsil and the M version was not ready yet when I ordered my drivers.
Is Lexel making you one? If so, I would ask him which version suits your needs.
