This seems to be for the 18650 configuration. Is there one for 18350?
I have one and the S41 W/18350 fits if you leave the head above the elastic sides
being elastic you can push the entire body into the case and hit the bottom
butt the light is not secure and could conceivably fall out the open area at the base
works fine W/18650 tube installed
add…I had tried it with my S41S and it stayed in the upper position fairly well due to its grippier knurling
on trying it with my S41 it can by a little shaking, fall fully to the bottom part of the case
I can’t recommend this for use W/18350 configuration
Thanks for your input.
I am looking for a spacer/battery case that could be placed in the lower part of this case to hold the S41 in position in the upper part of the case
might work a-treat as these pocket rockets can eat a battery pretty quick in showoff mode
~1.75” length seems optimum, same as 10440 /AAA :+1:
the width is partially flexible due to the elastic sides, as is square/round/oblong
as long as it can fit 1, or better yet, 2 18350’s
might make a very field-able case out of this genre
Sorry; no, not as far as I know.
Anyone have their order ship yet? Stock was due 31st, but I notice they now removed date from the web page.
They helpfully cancelled my order for extension tube, even though it came into stock that day…
If anybody is wondering they said that the nichia 219c LED’s are “about 90 CRI”.
Oh, I’ve never read that.
Have you a link Spinuch?
What range includes “about” in China? –15% to +0% ??
I think the normal 219C is 80 CRI.
Are there magnets on a tripod screw? I think a tail magnet is more useful than this emergency hammer.
mine is now shipped
Mine is on its’ way, too! :+1:
Mine shipped today too!
if this thing turns off by a long press
I’m gonna need an oven mitt
Just use a key or a pen.
Well my Nichia one is still showing “backorder” but the XP-G3 I also ordered as a gift has shipped (from Seychelles?). Better re-order those 18650 tubes they cancelled…
Grr, tubes now out of stock again.
Ordered on 25th, they cancelled it on 30th - tubes in stock when I looked at website the next day, been away last week with limited access and now I check they are on backorder again… which is why I ordered on the 25th to beat the rush!
I’m quite impatient to see how it behaves on high and turbo since there are reports about the Manker version E14 II (with copper head) becoming dangerously hot - even burning a desktop. well that was with a 18650. I think i’ll be VERY cautious with this one.
That burned desktop is by leaving the light on turbo on the table with leds down, all high powered triples and quads will do that
The BLF-A6 driver that Astrolux has used for their previous lights has a 40 seconds turbo time-out, which was still not good enough to keep the lights under uncomfortable temperatures. If they skipped even that insufficient time-out in the S42 it really will becone dangerously hot if the user does not interfere.
