Lol I’m in the same boat. I love that the FW3A is cheaper than building your own Convoy triple, and the Q8 is cheaper than building your own SRK clone.
This light is so close and yet so far from what I want….
For me a modded S2+ seems like a better option. But I decided to give some feedback on I find right and I find wrong with this light.
I’m looking for the ultimate capabilities/size, with capabilities defined as the whole output vs. runtime curve.
Lux-rc’s Minion R1 is probably the current leader here, though quite heavy and can’t be used one-handed. And is very expensive.
This light would be second, yet some design decisions make it significantly larger than it could be. And too large for me.
#1. I don’t understand why the tail and the head need to have so large diameter. 24 mm lights are plentiful. Some accessories (like headbands) assume 24 mm, so here you lose compatibility. #2. I have a feeling that a switch in the head would add less volume. I guess it would be cheaper too. #3. With a switch in the head, you could make the threads compatible with Jaxman / S2 and enable users to use cheap short battery tubes. I would surely go with that. #4. I wonder if with a switch in the head it could have a 21700 battery inside 24 mm tube. I see there are no high-capacity batteries in this size yet, but if they appear, such light would be quite interesting. Guess that’s not compatible with #3
Well, if you look at the cross-section of the light you see that there isn’t very much material you could take away when you still want to have a decent wall-thickness (0.75mm).
A good part of the charm of this light is the e-switch in the tailcap. There are masses of lights out there which use a clicky-switch at the tail or an e-switch in the head.
You sacrifice 3/4 of the battery capacity if you go for an 18350 tube. So the idea is to make the light so compact that there is no real need for a smaller battery tube.
An 21700 battery in a 24mm tube will get very close. You need at least 21.5mm inner diameter, then 2x0.5mm wall-thickness for the body, 2x0.5mm wall-thickness for the tailcap/ head and then you’re left with around 0.5mm for the threads and that doesn’t work out…
So it seems like the Manker E14 ii or the Astrolux S42 would be the better choices for you, considering that you want a smaller body. Otherwise look at the foursevens atom series.
Understand. Though personally I strongly prefer efficiency over originality.
And actually the love of efficiency makes this light so interesting for me. In many places the design is super-efficient. But because of other choices, the final light is not so much really.
More like 1/3 nowadays (real 1100 mAh in Aspire 18350). But anyway, sometimes this 1/3 is simply enough.
My current light has 1/10th the energy of 18650, yet it’s enough too. So anything extra is just unnecessary weight and bulk.
Right. I missed the fact that there’s no good place to have threads. Thanks for the explanation.
My pick is S2+ triple. Shortened. Similar output to FW3A in ~70x24 mm, 1/3 smaller than FW3A. If I did the same with 18700 tube, that would be ~105x24 mm - similar volume to FW3A despite seemingly less dense interior. Well, strictly speaking, FW3A is smaller than 94.8x25.5 cylinder that I use in calculations because of the cutout in the middle - but it doesn’t make it more packable.
I told my sister that her newborn baby was really cute, but that she’d be even cuter if her face weren’t so round and her head not so bald and her eyes weren’t so squinty and if she didn’t smell quite so- peculiar. She said she’d try to do better next time.
94mm long has gotta be the smallest single-18650 light with a tailswitch. Well done!
To get shorter than that you pretty much have to use a twisty or an electronic side-switch (like the DQG18650), or sacrifice battery capacity and output while switching to a smaller battery type.
I’m really looking forward to the FW3A. The design looks amazing. :sunglasses:
If I were changing anything about it, the changes would be minor. Maybe add knurling on the body tube and some heatsink fins at the head.
It doesn’t have a tail e-switch in order to be original. I designed the light with a switch in the tail rather than at the head because I much prefer tail-switches and am willing to sacrifice these 0.8 or something millimetres in diameter for that. Given the big interest in the light, many feel the same way. So it is just unfortunate for you that you feel differently.
And in the end it all comes down to personal preference and the willingness to make compromises. That’s why I don’t really think it makes sense to discuss the design further with you, since we just have different priorities when it comes to EDC lights. I don’t mean to be rude or just dismiss your suggestions, every form of feedback is appreciated, but what you are suggesting goes quite against what this light is meant to be or designed for and would require some more or less drastic design changes.
Anyway, thank you very much for your feedback!
I am so looking forward to this light! I love the little AAA Lumintops with the tail e-switch and to me this is a natural evolution in the tail cap clicky world. Tail cap clicky lights have to be my favorite, since I edc in jeans and would rather not screw with locking out a light. Can’t wait!!!
The Nitecore HC50 is 86mm long and has a 2-stage switch on one end… but it has the LED on the side instead of the head. It’s also 32mm wide, so that adds a lot of bulk.
I don’t think the FW3A is really meant to compete with a S2+ triple, but it could be seen as an alternative to a Sinner or Okluma or Oveready or other similar high-end light.
If someone wants a really small version with a side switch and a smaller battery, perhaps the Olight S Mini?
I see the FW3A as competition for the Convoy/Jaxman/etc… mechanical switch tube triples. I think it has two significant advantages over those:
I prefer well-designed e-switch UIs over anything that’s possible with a single mechanical switch. The main thing for me is shortcuts from off to various useful modes (no, almost every Chinese flashlight company ever, strobe is not a useful mode).
The mechanical switch is a current bottleneck and likely failure point. FET triples generally draw several times as much current as the switch is rated for. (Ok, so they often also draw several times as much current as the emitters are rated for, but that’s the fun part.)
And like the Convoys, it’s in the large-EDC size class, which is certainly how I plan to use mine. I’ll probably get several so I can match the emitters to my mood each day.
