Review : Utorch UT02 Flashlight (XHP35 / 26650 / usb rechargeable)(in progress)
mine steps down too
shame like you said for a heavy duty light
the dam things still ice cold after several reruns on turboā€¦ā€¦ā€¦
I agree 325lm is pretty bad for a XHP35, it has all the right stuff going for it why didnā€™t they just improve the driver.
Which Convoy C8 are you comparing to, XPL with 8 drivers? Or XPL with a FET?
How then me and Dale got 950 lumens for NW, and 1090 on CW? Not that I am discrediting yor measurements, but we had same Amperage on tail as you do 2,4- 2,5A and 0,7A on led
ā€¦.
I use mine on 10 minute walks pretty much weekly, taking the trash down to the road for collection in the morning. It makes nice light and doesnā€™t step down like what youā€™re saying yours does. I tested it side by side with a Manker U21 and liked the UT02 better.
Just pulled mine off the shelf, well rested, and it does 1070.2 lumens for 2 minutes then takes 30 seconds to ramp down to 745.2 lumens where it sits stable for over a minute and I cut it off, the head is warm to the touch.
There is a step down after 3 min but from 950 to 640 lumens with my NW but you canā€™t actually see it with bare eyes. Anyway if you dont like it just go to secret mode and switch to turbo and it will stay in turbo until battery can handle it, also it will get hot after 10 minutes
Forgot about the hidden mode, thanks Nikola for reminding me. No turbo step down when in that mode. :wink:
When Peter and I pm'ed, I forgot the standard tail amps on these things is 2.3-2.5A amps now. Used to be over 5A when they did a true 1,300 lumens, like the Manker U21 did in my review: https://budgetlightforum.com/t/-/40242.
So the new 2.4A version does about 1,000 lumens. With Peter's doing ~650 lumens, I'd suspect the LED, LED mount, and/or optics, but could still be a driver problem I suppose.
He's right though - they downgraded the light but never downgraded the specs, but if the measurements are good, his is performing below par of even the downgraded model, but the amps drawn from the cell is not producing the same output.
From post #179, earlier this eveningā€¦
ā€œJust pulled mine off the shelf, well rested, and it does 1070.2 lumens for 2 minutes then takes 30 seconds to ramp down to 745.2 lumens where it sits stable for over a minute and I cut it off, the head is warm to the touch.ā€
I may not be a mathematical genius but even I can garner that 1070 well rested lumens is much more than half of 1300 ANSI rated lumens. The well rested cell in question is an OLD Moli 26700 sitting at 4.02V.
Edit: For the record, my UT02 with a Sanyo 20700B cell at 4.15V makes 1107.45 lumens. As tested moments ago before plugging the light in for charging.
Edit II: With the 20700B cell charged in the light, it makes 1111 lumens.
Received another ut02 (cw) some days ago , and this particular light is making 1040 lumens .
FWIW, without the lens mine is making 1159.2 lumens, so there is some 48 lumens blocked via the lensā€¦ which actually speaks very well for the lens of choice they put in this one! :wink:
DBā€¦ā€¦I canā€™t remember. Is your UT02 stock or did you mod it (resistor mod, bypass etc)?
Itā€™s stock, kept it that way for the comparison to the U21 and find I rather like itā€¦ donā€™t want to replace the driver due to the 3A built in charger.
Or thatā€™s what my memory tells me, Iā€™d have to open it up and look to be 100% sure.
2A battery charger .
Btw , modded a lot of them , and if someone wants could probably keep the charger , Iā€™m now working on one like that ā€¦
Confused now, sure thought it was the UT02 that had a 3A built in chargerā€¦ now I canā€™t find if thereā€™s one I have that does or if I just got it wrong. Thanks Giorgo.
Mine rises slowly up to 1.9A. 3A would be quite difficult for most USB power supplies.
But of course, with most USB outlets having a 2A max. Seems there was a light that had more than one USB charging port that could be used simultaneously to charge faster although thatā€™s not where I got the 3A figure, mustā€™ve just made that one up. Sick and tired of being sick and tiredā€¦
Yup, the MecArmy PT60 for example goes to almost 3A with three micro usb charging ports (or just one if the charger is up to it).
mine makes close to 1100 lumens, and 99 k lux, its nw
I ordered last week an UT-02. I will be interested in the details of your build to keep charger and make better driver. Please inform me when you do it. So then If I will be unhappy with performance I can make an upgrade. :smiley:
I just got mine. It only does 2,2A at battery :frowning: The lowest I ever seen for a UT02 in this topic.
