✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Lumintop Ant Stainless Steel/Brass XP-G2 R5 120LM EDC Mini LED Flashlight is now in preorder for $25.90 (brass version) and $26.90 (stainless version). BG points are working so it’s possible to lower the price even further to:
Brass version:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$22.02
$21.76
$21.50
$21.24
$20.72
Stainless version:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$22.87
$21.60
$22.33
$22.06
$21.52
Lenovo ZUK Z2 5.0 inch 4GB RAM 64GB ROM Snapdragon 820 2.15GHz Quad-core 4G Smartphone is in promotion for $175.99 and BG points still work, so having enough points it’s possible to lower the price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$149.59
$147.83
$146.07
$144.31
$140.79
Update: Deal expired.
KEWEISI 3V-9V 0-3A USB Charger Power Battery Capacity Tester Voltage Current Meter is now for $3.27 and using BG points price can be lowered to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$2.78
$2.75
$2.71
$2.68
$2.62
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight is right now for only $23.95. All three LED options available.
Coupon code is now available: use code 8a955d to lower the price to $25.50
18650 extension tube available here:
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $2.49 (BG points can be used to lower price further).
BlitzWolf® Graphene Earphone BW-ES1 In-ear Wired Control Earphone With Microphone
Good value earphones with graphene diaphragm converters now for $11.99
ARILUX® AL-SL06 Solar Powered 62 LED PIR Motion Sensor Light Outdoor Waterproof IP65 Wall Lamp
for VIP2 and above at only $19.99 and using BG points it’s possible to lower the price to:
VIP2
VIP3
VIP4
VIP5
$16.79
$16.59
$16.39
$15.99
$1.28 for Outdoor Portable Silicon LED Light Night Running Mini Safety Hanging Lamp Warning Light and using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$1.09
$1.08
$1.06
$1.05
$1.02
$19.95 4PCS NCR18650B 3.7V 3400mAh Protected Rechargeable Lithium Battery using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$16.96
$16.76
$16.56
$16.36
$15.96
Nitecore MT06MD Nichia 219B 180LM LED Pocket Medical Penlight Flashlight
Using coupon code price drops considerably. »Request deal info via PM here«
The flashlight uses 2xAAA cells and Nichia 219B LED with CRI over 90 at CCT=5000K. It has 3 modes and always starts in low (4lm), medium is at 45lm and high at 180lm.
$39.99 EKEN H9 WiFi Sport Action Camera DV Car DVR SPCA6350 4K 25fps 1080p 60fps 720P 120fps New Version
This is the new version with round lens housing.
$44.99 EKEN H9R Sports Action Camera 4K Ultra HD 2.4G Remote WiFi 170 Degree Wide Angle
This version is equipped with mini remote control.
Other Eken cameras
For the ones without dedicated promotion use EKEN20%1 and/or EKEN20%2 coupon codes to lower price by 20%.
Following deal has expired. Send me a PM for a valid coupon code.
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight is now in preorder for $42.95 but using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$36.51
$36.08
$35.65
$35.22
$34.36
XP-G3 and Nichia 219C hight CRI available. Registered shipping included. Colored version is also available in the same price - links below:
Astrolux S42S Colored 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
To utilize LEDs to max extent and be able to get the most light it’s best to use 18650 high current drain cell.
Matching extension tubes are available:
Astrolux S41S/S42S Colored LED Flashlight 18650 Extension Tube Body Tube for $9(silver) / $11(heat colored) and using BG points it’s possible to lower price as well:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$7.65/$9.35
$7.56/$9.24
$7.47/$9.13
$7.38/$9.02
$7.20/$8.80
note the opposite orientation of the tube on the 18350 tube
that is the wrong way to use it as the threads are not long enough on that end to have the body reach the contact ring
it works on the stainless because the threads are not anodized so current goes though them to the copper head
it won’t work on the black tubes
even though I think it looks more balanced the way it is
with the stainless model you can have a reversible clip position by reversing the tube :+1:
That’s true - black aluminium tubes work only in one position - cannot be reversed. Same goes to Astrolux S41.
Deal expired - now coupon available: details here
All colors Nitecore T Series Tube 45LM USB Rechargeable LED Light Keychain using this link lowers the price to $6.28 and you can still use BG points to lower the price even more:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$5.34
$5.28
$5.21
$5.15
$5.02
Note: if the link did not lower the price and reloading the page doesn’t help, clear cache/cookies and use the link again.
Astrolux Flashlight Protected Bag Holster For Astrolux S41/S41S/S42/S42S 12.8x3.2cm
Very good single 18650 flashlight holster now for only $0,99! Fits all Convoy S2/S2+/BLF A6 sized lights perfectly.
Lumintop ED25 XM-L2 620LM AA 6-mode Tactical Outdoor LED Flashlight use code LMTED25 to lower the price to $17.95 (-$7.05).
Holster is included, registered shipping as well.
This is one of the brightest 2xAA lights, has 3 normal and 3 blinky modes (those are hidden: need to loosen the head 1/4 turn to access -> no way to accidentally activate and provides fast access at the same time :+1: ).
Machining and overall quality is truly incredible for this price range. Hard to beat value for money.
Lumintop IYP365 XP-G2/Nichia AAA EDC LED Portable Pen Flashlight is for $12.00 using code LMTIYP365 (-US$13.00).
Cree XP-G2 R5 or Nichia 219BT high CRI options available.
Mode order is medium≫low≫high, no mode memory. If you want similar pen light with low≫medium≫high mode order with Nichia LED see Nitecore MT06MD
Lumintop SDmini XP-L HD/XP-L HI 1000LM Rechargeable EDC LED Flashlight using code LMTSDMIN lowers price to $39.99 (-$9.91)
Holster and USB charging cable (standard micro USB) is included. Flashlight has 4 constant modes and 3 hidden blinkies, max 1000lm, two LED options are available: Cree XP-L HI for better throw or Cree XP-L HD for more light.
Raspberry Pi 3 Model B ARM Cortex-A53 CPU 1.2GHz 64-Bit Quad-Core 1GB RAM 10 Times B+ is now at $39.99 and using BG points it’s possible to get price as low as:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$33.99
$33.59
$33.19
$32.79
$31.99
»New deal available here«
BlitzWolf® BW-ET1 XP-L V6 750LM Stepless Dimming Mini EDC LED Flashlight 14500/AA is now in preorder for $28.95
300 orders only, then the price will rise to $30.55 and after another 300 order to $35.95. Target price is supposedly set at $39.95.
Matching extension tube is now in preorder as well for only $1.15:
BlitzWolf® BW-ET1 LED Flashlight Extension Tube for 2xAA
