All 4 cells are in series and it pulls 6.5 amps at 16 volts. As the voltage drops the amp draw ramps up to a max 7.5A at 14 volts, then starts to ramp down again below that voltage. So I think that’s 7.5 amps max per cell.
I have a question:
I switch the light on, then I double click.
I am now in the 10k mode and group 2.
What happens if I click once and what happens if I click twice?
How do I get back to group 1?
I personal would like to see the 10k mode in group 1
Yeah, my bad, probably shouldn’t call them problems, but tweaking things like the mode spacing (which I would have considered initially as a problem) will definitely make this a light worth buying.
