Perfect fit and exterior finish. Clean and battery tube threads well lubricated.
Pretty good interior finish for the most part
Nice heft, weighs in at 404 g (no cells). The latest SRKs are around 300 g.
Clean reflector, lens, LEDs, MCPCB, interior
Looks like a good quality PCB for the driver
Good button with crisp action
Good thermal performance. Can sense some heat on the exterior very rapidly.
3D tint, or extremely close to it, as per specification
2 mohm FET on the driver, as per specification
The āgoodā type 7135 regulator on the driver
LED wires are AWG 18 or larger
The neutral:
More aggressive knurling than usual, but well done
The SS bezel on mine came dirty. Some glue or similar that comes off easily though.
The glue used for the plastic finishing rings around the brass +contact ring is a little fragile. Very easy to remove these rings.
LED centering is OK, but not great.
The not so good:
De-laminating MCPCB. Apart from the mask lifting at one edge, there is also an air-bubble around the -wire pad.
Two inclusions in one of the four reflectors
The now known issue with the tail springs. A 2 ft drop onto its tail on a soft surface interrupts the cells.
Driver is obviously hand-soldered. Hopefully this is just a prototyping issue. It is mostly a case of too much solder and there are no signs of dry joints or bad connections.
OK, photos. These are as the light came out of the box, no clean-up, no rework of any kind.
Banggood style bag, but I am not expecting anything from BG?
Apparently we have an SKU already:
Simple but functional packaging, of course the retail version may end up improved:
Oh nice!:
Not something you will see on any other SRK light:
Less nice inside, but still pretty good:
Tail board:
Tail cap:
Tripod threads:
Some boobed flat-tops:
We would need 2-3 mm extra on those springs for a secure fit with short cells:
Plastic rings. The brass ring stands ~0.5 mm proud of both:
WOW, now thatās a great rundown of the light :+1: Thanks a lot
Have the other proto3 lights the same issues as the one DEL received? Except for the LEDs being off-center and the spring issue I donāt remember any mention of the other issues.
I haven't even removed the MCPCB on the round 3 light, but I've even reflowed LED's on the round 1 and round 2 lights. Not the same exact MCPCB, but looks the same (round 3 made it wider and thicker). Haven't seen this problem or anything close of the peeling layer.
Haven't seen reflector issues in the 4 prototypes I've gotten.
I didn't notice the plastic rings could be removed easily. I had to pry off the ones on the round 2 lights and thought they were glued pretty good, but the plastics were very different in round 2.
I agree with the hand soldering, but truthfully it's hard for me to tell, so I couldn't say for sure. DEL has way more experience and expertise in that area.
#7 is back together. Tricky not to touch the reflector.
Those crappy solder-blobbed laptop pulls are giving 5600 lumens on start, 5300 after 30 s. I can accept that .
The inclusions in the reflector surface is an irritation, but it is cosmetic only. Springs should already be fixed. Plastic rings are not an issue, they stay in place even without glue. Solder is ugly, but functional. Had to clean up the pads to re-attach the LED wires, looks like mediocre lead-free. My only real concern is the durability of the MCPCB.
Edit: Parasitic drain is only 0.14 mA, even with the fairly bright side indicator on.
