Tear Down: Manker E02 / E02H (same as E03H)
69 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 week 6 days ago
Hey all,
Just got my Manker E02 in, and it’s a lovely little light.
One little ‘problem’ though:
The camera didn’t catch it so i had to photoshop it, but this is the thing:
On the lowest mode the XP-G3 seems to have a darker area on the die / phosphor.
This gets less noticable on higher currents.
Besides that, the XP-G3 has some tint shift going on, making the centre of the beam quite a bit warmer.
Not abnormal in modern LEDs though, but i’m considering an emitter swap.
But maybe i’ll settle for a diffuser film.
Either way, i had to open it up, also to satisfy my (and your) curiosity.
This is as far as i could get:
Parts list:
- tailcap (PCB with spring and magnet on the bottom apparently glued in place)
- battery tube
- ‘light engine’ retainer ring.
- Light Engine (contact board, driver and LED board, copper heatsink)
- Head (with switch boot and its SS retaining ring)
- LED / reflector gasket
- Aluminum OP reflector
- O-ring
- Glass lens (not coated)
- Bezel (stainless steel, with its O-ring)
Close up of the Light Engine:
Big piece of copper there, nice.
Fits inside the head with some thermal grease.
The copper heat sink seems to protrude through the PCB, so that the LED thermal slug is soldered directly on to it.
I think it’s possible to swap the LED by heating the copper heat sink, but i’m not certain parts will not desolder themselves from the PCB when i try that… Facepalm
(edit: pics re-uploaded)
Edited by: Jerommel on 01/10/2020 - 19:28
LightRider
LightRider's picture
Last seen: 2 years 1 month ago
Wow. Very interesting design. I’m kind of shocked they would go through the trouble of soldering the led directly to the pill.
Jerommel
Jerommel's picture
I guess the pill (the copper piece) is ‘just another part’ on the back of the PCB, but going through the PCB too.
You can see on the close up there’s a piece of it sticking through between the C1 and R5 marking, to the left of the LED.
You can see a copper circle there.
I should add a picture with an attempt to capture the bit under the LED.
Maybe later.
sbslider
sbslider's picture
Last seen: 5 hours 55 min ago
I have not seen many (any?) tear downs of cheapish AAA lights, but this is impressive.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Trevi_lux
Trevi_lux's picture
Last seen: 11 months 3 weeks ago
Thanks, nice pics. Very, very interesting, great aaa flashlight, no doubt!
ballard
Awesome! Have you torndown an E01 yet?
CRX
CRX's picture
Last seen: 37 min ago
Thanks Thumbs Up
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
Jerommel
Jerommel's picture
I have an Astrolux A01 form the first batch, which is (i think) identical to the Manker E01, including the lovely tinted 219B.
It’s a pretty straight forward construction:
Pill screws in the head, pushes lens and reflector forward.
sbslider
sbslider's picture
yep, that is how my Manke E01 went together
Jerommel
Jerommel's picture
So, i was messing around with a small TIR optic, and then i destroyed the XP-G3…
This was a while back actually.
Today i decided to remove the XP-G3 remnants.
I can confirm the copper heat sink protrudes through the PCB, giving the LED a direct thermal path. Thumbs Up
The XP-G3 was badly soldered to the heat sink though, but probably good enough for the <2 Watts power consumption.
I just finished reflowing a 219C 4000K CRI90 onto it.
First the centre pad to the heat sink, and then the + and – traces from the sides.
(had to scrape some masking paint off the PCB first)
…it could still do with a diffuser though…
AnhTran
Last seen: 9 hours 37 min ago
The XP-G3 was badly soldered to the heat sink though, but probably good enough for the I just finished reflowing a 219C 4000K CRI90 onto it.
First the centre pad to the heat sink, and then the + and - traces from the sides.
...it could still do with a diffuser though...
How did you remove the old Led and reflow the new one? there are many other components around it. I really want to replace mine with a nichia 219 R9080 but still can’t open the light yet
Pablo de Llama
Last seen: 1 year 6 months ago
Are the threads of the head of the light glued to the battery tube threads? I can't open my E03H by hand.
Lacerta
Last seen: 2 weeks 1 day ago
How did You manage to screw out the bezel ring?
My E02 is not so well centered and I’d like to justify it. But I cannot remove the bezel ring…
…well, without tool. But I avoid using any metal tool because I am sure it will scratch / dent the ring.
Goread Y-20 ( XHP50.2 mod ), UF-2220 ( XP-L2 -> SST40 mod ), Thorfire PF01S, Sofirn SP-10B, Manker E02H X 2, Manker E03H, Imalent HR20 ( XP-L2 & TIR mod ), Rofis R3 ( SST40 mod ), Skilhunt S3 Pro HD, Utorch UT01 ( XP-L2 -> Osram Osconiq P8 mod ), Lumintop tool AAA ( XP-G3 -> SST20 mod ), Skilhunt H04R RC ( SST40 & TIRs selection mod )
Niko
Last seen: 12 hours 18 min ago
Sorry but this pcb look like amateur project. Solder bulbs and dislocated parts are ugly
AnhTran
Just use a tape to increase the friction, i managed to open mine here http://budgetlightforum.com/comment/1306069#comment-1306069
Lacerta
Oh, good idea, I will try it, thanks!
varbos
Last seen: 2 days 6 hours ago
Does the bezel come out easily? It just screws out from the front by pressing against it with some friction? Or is there some glue to soften?
Just got one of these in the mail and there are lots of dust behind the glass
Jerommel
Jerommel's picture
Hi,
Mine had no glue.
Yes, pressing down on a slab of rubber and twist.
I used a bicycle tire inner tube.
Posts above yours mention tape.
Jerommel
Jerommel's picture
I’m sorry i hadn’t read your post earlier.
Now it’s more than 8 months later..
And also, i don’t really remember how i got the old LED off…
It was damaged and i think it came off with a little force, but maybe i put a soldering iron on it..
Lacerta
varbos wrote:
Does the bezel come out easily? It just screws out from the front by pressing against it with some friction? Or is there some glue to soften? Just got one of these in the mail and there are lots of dust behind the glass
No glue at all, just friction.
I used self-adhesive masking tape to screw it.
Be careful, there’s no centering washer in the lamp, it is a little difficult to tighten the bezel back with proper emitter centering.
Jerommel
Jerommel's picture
mine does have a centring gasket.
It’s in the bottom left corner of the 2nd picture in the OP.
Lacerta
Yes, that’s a gasket but it’s not centering. It does not guide the reflector from the side when it is screwed down.
Jerommel
Jerommel's picture
Mine is a centring gasket.
It has a raised outer rim that fits around the reflector base.
Maybe they /you put yours in upside down by accident?
Maybe you have a different one.
Jerommel
Jerommel's picture
It’s the best AAA light i have.
Definitely the brightest too.
Lacerta
Mine also has a rim but the diameter is too big / the rim height is too low to center the reflector properly.
Originally, I removed the bezel and the reflector because the factory centering was not good enough. And after that I had to play a lot because it is really not easy to tighten the bezel without moving the reflector from the adjusted position. Finally, it is done, and I am satisfied.
Maybe an other type of gasket is in mine, maybe I more sensitive to centering. Big Smile
This is a very good AAA light after all, I really love it!
Jerommel
Jerommel's picture
I do agree that the centring is not perfect. But it’s good enough in mine.
Yeah, it’s a neat little light. Very happy with it. Thumbs Up
Jerommel
Jerommel's picture
Pictures re-uploaded.
Tinypic died, long live Imgur.
Also, i just took my E03H apart.
Just got it in, the price was low so i ordered one.
It has a cool white XP-L, and i’m gonna swap it with a LH351D.
It’s built exactly the same as its little brother.
Needed to heat it up near where the batt tube screws into the head, and then it was quite easy to unscrew it.
It’s a nice light. Thumbs Up
I immediately removed the diffuser though.
UI with 1 more mode, cycles: Moon – Low – Mid – High – Mid – Low – Moon – Low – Mid – High – Mid – Low – Moon – ….etcetera….
The rest is the same as the E02.
Funny, the clip doesn’t fit too well on this light either…
Maybe one day Manker Mateminco Astrolux U-torch will learn how to make clips, or order them from a factory that knows.
It’s not as bad as i expected though, but it’s still not right.
raccoon city
raccoon city's picture
Last seen: 2 hours 25 min ago
Thanks for the re-up!
Lacerta
Please share your adventures in Manker emitter swapping. LOL
I ordered a second E02 and an E03 ( coluld’nt resist the price Cash ), and I think that replacing the XP-G3 and the XP-L to an SST20 and an Osconiq P3737 would be a great idea. Cool ).
Jerommel
Jerommel's picture
Osconiq P3737
I had to look that up. Smile
Kaidomain has them.
Do you know these LEDs?
Are they any good?
Okay, i’ll make sure to take pictures of the reflow.
phouton
Last seen: 6 hours 17 min ago
Thanks for documenting and keeping the pictures up-to-date.
I really love the E03H. The beam profile is great for me. And I actually don’t mind the XP-L cool white as implemented in the E03H. A bit warmer with better CRI would be nicer, but I find I’m actually ok with it as-is.
The feel and build quality, the diffuser, the UI, and the size… I’m just so happy with it.
Since the E02/E03H are out of production, I wonder if there will be a successor.
