Clemence has already found the R9080’s difficult to obtain, while he has a very direct contact at Nichia. It would be quite an achievement if Hank was able to get Nichia to release to him the few that they make.
So… the D7 (instead of D17) has seven emitters. Maybe like DQG with single 26650 (Well it could be seven XH-P70 emitters buuuut I doubt that)? So I do assume Nichia option is then available for the D7.
I did some pixel counting. It’s not accurate, but I guess the tail cap is 26.5 mm, battery tube: 24 mm, head: 28 mm + protrusion. Head would be 24 mm long, tail - 23 mm.
This adds up to ~48 cm^3.
For comparison, DQG Tiny 4th 18650 is very roughly 38 cm^3, 21% smaller.
If shortened to 18350 size, this would be very roughly 34 cm^3 vs. 26 cm^3, 25% smaller.
Whatever happened with the rumors of the new Meteor I believe it was or something similar, read about a new light on the Meteor thread some time back ? Last year I believe.
Great new light Hank, and still wishing you’d start remaking some of your lights from the early days again,
