Soldering gear thread
Sure.
Will post links and answer any questions in 1 hour (right now I have no access to my PC so browsing from mobile phone)
Thank you. No rush at all… just when you have time. :slight_smile:
It does indeed look quite nice. Please forgive the stupid question but do you blow air on the LEDs or below the MCPCB? And is there anything you can’t do with one of those that you can do with an iron? I’m looking to replace my old underpowered iron and I’m not sure yet if I should go for a soldering station or hot air. I don’t really do enough soldering to justify having both. Just some occasional flashlight assembly and toy repair, although I would eventually like to put together a driver or two from scratch.
Can we get more info on the hot air station? I use a spare soldering iron but a hot air station might be nice.
@ fixed it
If you only want to get one station go and get an iron. You can do more with it. The hotair is nice to have. Its easy to desolder things with a hotair and reflowing a driver with a hotair is also nice. But most drivers could also be put together with a iron. The hotair makes things easyer sometimes.
I got a cheap one (YOUYUE 858D+ ~40:money_mouth_face: and then i got a new mcu with complete new firmware (http://blog.spitzenpfeil.org/wordpress/projects/youyue-858d-hotair-station-modifications/). Makes it a lot more save and presize. The standart cheap china hotair could easy overshot 50°c and more. With the new chip (if i remember right it was ~15€) this is all gone.
Can we get a link to yours MILSPEC? Thanks…. :slight_smile:
You can get both a iron 30watt can be had for $5 and a hot air gun for $8 online
Guys…. please post some links to these good deals you know about and are mentioning, as well as the things you use and like. That way we can check them out & know for sure we are looking at what you mentioned.
Thanks in advance. :slight_smile:
Well
some background at first.
I did not use my soldering staff often so had only cheap Chinese iron with solid cooper tip for a long.
Then I was presented with Yihua 939d
The price was about 30USD.
It was much better that previous. But still not as good as I expected. And after some research I desided to go for T12 soldering irons
After maybe 6 months I caught flash sale for Bakon BK950D
For about 14USD it was must have.
There were still some issues with usability (buttons was definitely not the best solution there) and performance (less powerfull that stated 75W). But still it was better than 939d.
The only thing I did not owe was hor airgun. And as far as i was about to build several custom drivers for SRK I started looking for it.
While searching I’ve found few very inspiring reviews on STM32 based soldering stations from taobao.
At first it was story about bying DIY set with 0.96 inch OLED scren
https://mysku.ru/blog/taobao/45851.html
Then story about upgrade to 1.3 inch screen
https://mysku.ru/blog/taobao/48640.html
And finally STM32 based airgun controller
The latest one is 2in1 iron/airgun controller but all agreed that it is not the best choice now, way too expensive. And it is better to have 2 separate stations.
You can follow the links and check photos and/or use google translator to read some ysefull info.
I’ll try to put main info in a nutshell:
Soldering Iron:
- price is about 45USD + shipping for complete set (controller board, psu, box, soldering iron…)
- AL box ~150х88х38mm
- stm32 based controller board
- 72W+ PSU
- T12 handle
- OLED screen
A lot of features:
- temperatures 150÷480 ℃
- Cold junction compensation 9÷99 ℃
- PID temp control
- standby, sleep, boost mode
- temp 3 point calibration for your tips
- tips databases with presets
- clock
- buzzer
  • screensaver lol
Hot airgun:
- price is about 50USD + shipping for complete set (controller+psu board, box, airgun handle…)
- stm32 based controller board with integrated PSU
- airgun handle + stand with magnet sensors
- OLED screen
The list of features is more short:
- temperatures 100÷550 ℃
- airflow 20-100%
- temp control
- 5 presets + manual controls
- standby mode
- timer
- buzzer
  • screensaver
Overall impression is very good for both.
Some links for iron tip:
controller board + screen DIY STM32 白光 T12 OLED 鮑魚 牛肉 數顯 恆溫 焊臺 控制 主控板 - Taobao
power socket https://world.taobao.com/item/536927327500.htm
box with front and rear panels CANRU oled1.3焊臺 電烙鐵可調恆溫防靜電焊臺電烙鐵焊臺配套外殼 - Taobao
finished t12 handle https://world.taobao.com/item/543586547794.htm
dont have link for psu but there are a lot that would fit.
Can be also ordered on aliexpress but price is much higher there.
Fel free to ask any as I do not know what migh be interesting for you about that staff.
Wow!!! Thank you strango, that is some good info ….
…… with plenty of detail too! :slight_smile: … I appreciate that. :+1:
Here is some of my soldering/desoldering gear
Looking good abtglenn…… :+1:
Thanks my friend. Pictured is:
Hakko FX-888D soldering station
Hakko FX-901 battery powered soldering iron
Hakko 808 desoldering tool
Weller WESD51 soldering station
Weller WM 120 12 watt soldering iron
Weller 100P 100 watt temperature controlled soldering iron
Sparkfun 808D hot air SMD rework station.
Sure thing Glenn.
From the looks of that I’d guess you are either addicted to soldering equipment or do a lot of soldering. :open_mouth:
My pick would be the latter… a lot of soldering. :+1: … :slight_smile:
I’ve been building audio kits since the late 60’s. Most of it professionally working as a technician in a stereo store, and then working in the printing industry fixing DC motor controllers and control circuits. I’ve been retired since 2013. Since then, I’m not as active a I used to be. I still fix tubed audio equipment on occassion. Mostly for myself and a few freinds.
That would explain it then……. :wink: … Thanks again for sharing, you have some nice equipment.
Thanks again my friend. I’m still active and love the latest equipment. One thing I need to do is get a scope. It’s the one thing I haven’t had in my personal arsenal in all these years.
[/quote]
Now your talking—Tube Audio Gear—I use to be heavy into Vacuum Tubes —Still have a Dynaco 70—Citation V and a pair of 845 SET amps—Bottlehead preamp——nothing better
[/quote]
My first kit was Dynaco MKIII 60 watt mono power amp and a PAM 1 Pre-amp I built to use as a bass guitar amp around 1969. I later built 2 Dynaco Stereo 70’s and a PAS 3X preamp. Then I went on to build several Heathkit’s. The list goes on and on. I still use tubed audio equipment these days. Solid state doesn’t come close sonically.
Albeit I've had an early heater failure (don't really know if no tight fitting low quality aftermarket tips may have played a role there), these work nicely if you invest in some genuine T18 or new old stock 900M tips:
