yaa,he needs to upgrade the fan which he appears to be doing and also provide easily accessible replacements.
For me, I would not use his stock fans in mine anymore unless the newly designed one coming out has ZERO STOPPAGES during discharge. Even then I would probably put the Delta in. I love the results and actually listening to its impressive CFM!
I have 2 X Delta fans and I have a source[speaker_joe] to get more.
Opus would never put that high quality of a fan in because of costs.
The reason the TOP of the fan protrudes more than the bottom[which is actually flush] is because when tightening the cover plate it pushes on the bottom of the fan and with no grooves to keep it in place, the top pushes out and protrudes.If the fan had grooves it would still stick out with the additional 1.5mm in depth. It would just be an even protrusion! lol!
I do not recall how ārdanaā and HKJ explained it,but it works.
EDIT: Here is ārdanaāsā answer. He is the ONLY one who sells the BT-C3400 V3.1
The original fan has an inline resistor added to it, this is why the fan is 5v, the terminal on the pcb is probably providing unregulated 12v (obviously the external PSU is regulated). The 5v fans is a probably the cheapest they could find and they just added a resistor to divide the voltage, I would think the gearbest fan is better at least in that regard. Do not use a 5V fan directly on that board, it will almost certainly blow out or die within days.
_
However, I will say that all my other tests with new batteries were under 1% and the other 30Qās were a 4 slot median of 2890,Only 6mah off of HKJ! That was based on HKJ 2884 with FT not BT.
2.5 months old is basically new.Not 2.5 years old!
Age has nothing to do with it in this case[very little wear] ~20 cycles in the TN42vn carrier.The difference is in HOW they are built.
Bottom line which the picture illustrates, is that the Liion BT is a bigger button top and obviously made by a different company and looks more durable.
Hmmmmā¦. As far as I am concerned there aināt a dimes worth of difference between them from what can be seen in the picture.
The one on the right (Liionwholesale)is just a taller button top than the button top on the left from MTN.
While, if given a choice; Iād choose the taller one because of preferenceā¦ā¦ It does not mske it better or worse if both are installed in the same manner.
You contradict yourself! Your saying there is not āA dimes worth of differenceā, then you say the Liion one is a taller BT! That is the difference and is my whole point.
The Liion BT is more robust and in time has a better opportunity for contact.
I have some older Eātac that look like the Mt. Elec. battery and sometimes when inserted in my charger there is no contact and I have to jiggle it so there is contact.
If there was no difference then WHY would it be your preference?!
Is the one cell longer or is it the insulator from MTN put on top of the shrink wrapā- I looked at some of mineāThatās what it looks like to me
They make good contact in my lights and chargersāseems like you would have trouble with flat tops in that charger as wellāthey are slightly recessed
One being taller is only about a pennyās worth of differenceā¦ā¦ IF THEY ARE BOTH INSTALLED THE SAME!!!
IF BOTH BUTTON TOPS EXTEND ABOVE THE CELL INSULATOR/WRAP TO MAKE PROPER CONTACT!!!
NOWā¦ READ WHAT I SAID!!!
I am looking at a photo. Both button tops appear to extend enough that contact would be no problemā¦. so IF that is the case and ALL else is equalā¦ one can be no better or worse than the other. THATā¦ is what I am saying.
1. Why does the body of the left cell appear longer?
2. What is the overall length of each cellā¦. top of button to bottom of cell?
There is no rhyme or reason to my āpreferenceā in this case. I am assuming the things I mentioned are ALL equalā¦ so this preference is based on nothing but the choice of the moment.
Why do I choose Vanilla Icecream some days & Chocolate the other. But YET Butter Pecan might just trump them both many days.
OR, on a hot summer day Orange sherbet may very well get the nodā¦.
BUTā¦ā¦ they are all good icecream of the same high quality. Just a slightly different flavor.
One is no better or worse than the otherā¦ the choice is based on āpersonal preferenceā, not quality.
I am kind of new to this flashlight stuff but this is the charger I got. An Opus 3100 2.2. Do you think I should change the fan now or wait to replace it with the new one? Also, is it difficult to rewire the fan like DB did?
I wouldnāt worry about it till it starts making noiseāi have one thats 2 yrs old still going strongāget the upgraded power supply thoughāNo big deal modding fanājust splice in the old connector on the new fanā- I cut some of the slats out of the bottom case to let more air throughāalso most guys are lifting the charger off its feet with something for better air flow
