Have you determined if the on and off of the light will be through the rear switch (like S70) or through the side switch (like S70-S)?
50$ sounds more reasonable, glad to hear kronos is listening to the given advice
Please add me to the list for:
Two Units
Thanks
Slow
Put me on the list please.
please add me!
I would like one please.
Now I’m interested, put me down for one…
In for one, thanks.
Interested!
In for 2! Thanks!
Add me for a second one, two holsters and two batteries !!
The best low budget loader wich I know is the Liitokala Lii-202. This loader could charge with 2x 1 A.
Greets
Carsten
Illumn is having a sale on the Xtar Sv2 rockets. They can do 2x26650 at 2 amps each. I just bought 2 at $19 each.
More than likely the rear switch will be the main on/off, with standby on/off for the side-switch.
You are already on the list at #126…did you want a second one?
And 6 Holsters.
Sorry, it looks like the sale is over now.
Maybe we could get a store to do a group buy on the SV2 charger? These chargers really are ideal for lights like the L6, S70 and K70.
I’m in for 1 if there is still room
Thanks!!!
https://liitokala.aliexpress.com/store/133859
Lii500 charger and 2 x 5100mAh 26650 cells set one back ~$30
(if the Kronos tube is done the same way with good inside anodisation a magnet is safe to use, Kronos needs to confirm this via a continuity test though, I missed what cells Kronos is selling for $15 a set, if theses are button tops this could be an indication of different finish on this tube compared to the S70(S) yet the Lii500 for ~$20 is still a good charger, who would ind having a charger capable of charging 4 cells instead of just 2 for the same price at before mentioned right )
The difference is the SV2 charges at double the power. 2 amp x 2. When it comes to high capacity cells, the extra power really reduces charge times.
The Lii500 is perfect for 4x18650
and the SV2 is perfect for 2x26650
Please add me to the list for one. Thanks
