Interested!
In for 2! Thanks!
Add me for a second one, two holsters and two batteries !!
The best low budget loader wich I know is the Liitokala Lii-202. This loader could charge with 2x 1 A.
Greets
Carsten
Illumn is having a sale on the Xtar Sv2 rockets. They can do 2x26650 at 2 amps each. I just bought 2 at $19 each.
More than likely the rear switch will be the main on/off, with standby on/off for the side-switch.
You are already on the list at #126…did you want a second one?
And 6 Holsters.
Sorry, it looks like the sale is over now.
Maybe we could get a store to do a group buy on the SV2 charger? These chargers really are ideal for lights like the L6, S70 and K70.
I’m in for 1 if there is still room
Thanks!!!
https://liitokala.aliexpress.com/store/133859
Lii500 charger and 2 x 5100mAh 26650 cells set one back ~$30
(if the Kronos tube is done the same way with good inside anodisation a magnet is safe to use, Kronos needs to confirm this via a continuity test though, I missed what cells Kronos is selling for $15 a set, if theses are button tops this could be an indication of different finish on this tube compared to the S70(S) yet the Lii500 for ~$20 is still a good charger, who would ind having a charger capable of charging 4 cells instead of just 2 for the same price at before mentioned right )
The difference is the SV2 charges at double the power. 2 amp x 2. When it comes to high capacity cells, the extra power really reduces charge times.
The Lii500 is perfect for 4x18650
and the SV2 is perfect for 2x26650
Please add me to the list for one. Thanks
Please put me down for one please. Thanks
How much interest is there in a SMO (smooth) reflector? We believe that one can be done, but would like to know the interest. Yes? No?
Edit: If interested, please indicate if you are interested in the SMO reflector, the K70 light…or both.
Regards,
krono
Updated in OP
I would be interested in SMO reflector supplied as an extra,ie: light would come with both an SMO and OP reflector.
interested
Sorry for the confusion I might have started here.
Are you interested in the K70 light in general, or only interested in it if with SMO reflector?
I’m on the list already and I’d definitely be interested in a smooth reflector. I’d prefer a SMO reflector over OP but I would take both if available (for future mods).
I would be interested in a SMO reflector, but as gehrmo mentioned above ^
I would be interested in it as an additional purchase. My reflector of choice, would be the original OP reflector though. If you are asking either or?
If two were offered? I would want the flashlight to come with an OP installed, and the SMO reflector packaged and purchased separately.
Thank you for asking.
Any thoughts to making the box big enough, to ship both in the same package?
Definitely would prefer an SMO reflector in place of the OP, not in addition.
