REVIEW - Zanflare F1
46 posts / 0 new
old4570
Last seen: 4 weeks 1 day ago
Provided for review by: https://www.zanflare.com/
Product page: https://www.zanflare.com/category-flashlight-zanflaref1
For review I have the Zanflare F1 and I have to be honest and say I could find nothing of consequence to complain about . What we have here is a flashlight that is well made and works as it should , as well has the blinky modes hidden which makes me ever so pleased . A quick description = Single 18650 / 2x CR123 or 2x RCR123 ( 16340 ) with a USB charge port that charges either a single 18650 or 2x RCR123 . I have tested the USB charge port with a single 18650 but not as yet with 2x RCR123 . ( More latter ) .
Using the F1 is as simple as turning the light on with a press of the tail clicky , then clicking the mode switch once to change light levels . What I absolutely love is no matter how hard or fast you click the tail switch the light will not change modes , you need to click the mode button for that . To get to the blinky modes just hold the mode button down for about 3 seconds and to get out of disco mode just hold the mode button down for about 3 seconds again . Now this light also has a hidden TURBO ( I’m calling it that ) mode , so no matter the light level your at , a relatively quick double click of the mode button will put you into TURBO mode and a single click will then return you to the light level you were in . I have been taking the F1 for nightly walks for the last 3 days and I am seriously impressed with the user interface . I find low mode just about right for most instances ( 58 Lumens by my light box ) , and higher levels are a simple click away . Also every time I turn the light on , I know exactly how much light I will be getting as the light will not change modes because of the speed with which I turn the light on or off . ( A lot of lights suffer from this = Turning on and off to fast changes modes ) .
Modes = Moon mode – low mode – Medium mode – High mode – TURBO mode – STROBE and SOS modes .
Changing modes is as easy as clicking the mode button .
TURBO mode is accessed by clicking the mode switch relatively quickly twice and once to exit
Disco and SOS are accessed by holding the mode button down for about 3 seconds and the same again to exit
Light Levels
Moon Mode = Too low to measure / 0.002 Amp
Low Mode = 58L / 0.116 Amp
Medium Mode = 288L / 0.58 Amp
High Mode = 556L / 1.36 Amp to 1.49 amp ( Varied according to location of probe )
TURBO mode = 1050L / 2.1 Amp
TURBO mode and thermal protection
A lot of lights that do 1000+ Lumens suffer heat related output sag . In the old days when 1000 Lumen became a reality the current the light pulled was north of 3 Amps . With many lights pulling up to or more than 5 amps and it became quite a bragging right to be pulling lots of current . Now this current often did not equate to light output as the emitter would over heat and drop output as energy wast turned into heat rather than light . With the F1 I was able to run TURBO for 45 seconds before the thermal protection kicked in . In that 45 seconds the light went from 1035 Lumens to 995 Lumens . That’s about 1 lumen per second which is a lot better than I have seen from other lights .
Measurements are what I was able to get at the time of taking the reading ( so please accept as ball park )
Recharging VIA internal USB port
There is a ring that unscrews just bellow the head / mode button , turn it anticlockwise to expose the USB port ( When I got the light it was unscrewed )
I used my slightly better USB monitor ( charge doctor ) to keep an eye on the charge cycle . With the 18650 at 3.7v the charge current ( what the USB monitor saw ) was about 0.40 Amp to start with and after a while it settled to 0.39A until the battery went over 4v then the current began to drop . When the USB monitor showed the charge current at 0.0 Amp I pulled out the 18650 to check on the voltage level achieved using the internal USB charge port . ( it was 4.16v ) . The USB monitor showed some 1900mA having gone in for some 5 hours and 26 minutes charge time .
I have not at this time attempted to use or charge 2x RCR123 , so when time permits I will update the review with the relevant information .
Zanflare F1 :
I am really impressed with this light , especially with the mode switch and the simple fact you can hammer the tail clicky like rabid monkey suffering Tourette Syndrome and the F1 will not change modes . For quite some time this has been a pet peeve of mine for normal flashlights as using the light quickly to just take a peek changes modes ( so annoying ) . The F1 has simply proven itself to be the best night time walkies light I have used to date . The UI is simple to use , reliable and frustration free . ( What more can you ask for ) The light levels are really good , I found low and medium modes the most useful in my urban environment with high giving me more than enough light for when needing a little power . 1000 Lumens is nice to have , but where I was walking ( suburban streets ) it did light things up better but there was so much glare from car windows and house windows it was a little overkill compared to 500 lumens .
With the battery at 3.7v I decided to see how much light I got .
Low mode = 58L
Medium mode = 273L
High mode = 556L
TURBO mode = 758L
I was very surprised to see such good light output with the battery at 3.7 volts , especially Low / Medium / and High . A drop in performance was certainly expected for Turbo mode , but I was pleasantly surprised by the performance showed in the regular modes . The F1 comes in one of those boxes you will want to keep ( cos its so well made ) , as well a clip , lanyard , USB charge cable and a belt holster / bag that is made from the nicest softest wet-suit style of foam . How can I describe just how nice this light is ? The anodizing is really good ( and scratch resistant ) , the threads are really well cut , there is no slop fit here . The tail clicky is really nice and firm and solid without being a bear . The mode button is just the right tension , not to hard or soft , almost perfect . There is no battery slop with the 18650 nor is there any binding . I have found nothing to complain about ! For the last 4 days the Zanflare F1 has been the only flashlight I have used , and the more I use it the more I like it . With some lights the more you use them , the more things you find that might be less than impressive , not so with the F1 . The more I use it , the more I like it and I think it has just became my go to light . ( I keep a flashlight on my desk for when I need such , and said position is usually occupied with my Favorite flashlight ) . What can I say , I have a few flashlights to chose from and at this time I chose the F1 .
Conclusion :
First I would like to thank Zanflare for sending me the F1 for review , because this light ROCKS hard ! It has been a while since a light has impressed me so much and with nothing to complain about , not even a niggle of an issue , nothing ! As well the F1 ticks all the boxes and simply surpasses expectation .
Who would want this light ?
With on-board USB charging – Anyone that travels or is in a car / truck a lot . Security / police / fire personnel that want a reliable fuss free light ( a lot of these folk relied on single mode lights because of the light level ? mode issue I mentioned before – when you turn the light on you need to know what you get ) . Anyone that is looking for a reliable easy to use light with a simple User Interface . ( One can use the F1 as a single mode light or as a multi mode ) . Now when it comes to a score , it has to be 10 out of 10 and I would add ( +1 ) because the F1 has gone to the top of my list of liked flashlights . I never thought there was a flashlight that could be better than a P60 host , well I have just been schooled !
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 47 min 48 sec ago
Thanks for the review mate!
I am interested in seeing inside your toy box looks like you have exciting stuff from looking at the USB meters and the drone lol.
firedome
nice review! thanks for posting!
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
The Miller
The Miller's picture
nice light!
(can you fill the (OPTIONAL) Relative Width (): field while placing a pic? say set it at 100, this way the pics fill out the width of a pag and are easier to see)
old4570
Toy Box ! = Yeah !!!! , this entire room is my toy box .
Images have been down sized , so are pretty much max .
Can visit my web to see the toys I play with old4570
USB power meter is also a variable power supply ! …. ( These are hard to find on Ebay – and I can’t find another At The Moment )
jimyk
Last seen: 2 years 3 months ago
good review. but if you edit the pictures to be same size, they look better.
SteveMidwest
SteveMidwest's picture
I bought one Thumbs Up
Thank you for such a great review old4570. Cool
huntking
Last seen: 2 years 1 month ago
how to test the lumen?
Lexel
Lexel's picture
Last seen: 16 hours ago
1050 lumens @2.1A seems impossible, not even a XPL W2 LED without reflector and lens gets that efficiency with 25dCelsius junction temperature
Newlumen
Newlumen's picture
Last seen: 5 days 2 hours ago
This light is picky.. it only takes flat top.. I tried lg mj1 unprotected button top and Samsung g 30q button top, and it didn’t work.. FYI.
postimage
Lightbringer
Lightbringer's picture
Last seen: 10 sec ago
Hm? Not mine. I’ve got a protected panny-B in it, one of the longest 18650s around at just a hair under 70mm, and it fits fine.
Dropped in, the cell’s maybe 2mm below the edge of the battery tube, and the tailcap screws down all the way for a nice snug fit but without binding or “pushing back” in the slightest.
Hmm, if I got a panny-B in this one, I’m just wondering which light I scrounged it from…
old4570
People’s are so funny ! http://www.cree.com/led-components/media/documents/ds-XPL.pdf
I do not claim in any shape or form a direct correlation between measurements …
I only offer them as the results I was able to get , with what ever variables are in place … ( and there are many variables )
old4570
Hmmm , my Blazar are 69mm long and go in no issue ..
jimyk
I have F1. I saw your question and test it with many kinds of 18650 batteries.some are flat top and some are button top, from 65 mm to 70.3 mm. All works well. I think you should screw down the tail tight.
Rolz
Last seen: 1 week 3 days ago
I too have one and I’ve not had any issues with button cells.
Trevi_lux
Trevi_lux's picture
Last seen: 7 months 1 week ago
Hello, Nice review!.
I have for some months ago one zanflare F1 (november 2016)
This are my values with a not protected high quality battery, estimated with my Trevi-Box :
Moonlight I think around 0.2 lumens (my box can not meassure less than 1 lumen)
Low 55 lumens
Medium 285 lumens
High 520 lumens
Turbo “flare” 925 lumens
Newlumen
Newlumen's picture
That’s good. I think it’s just my light that only like flat top such as lg flat top yellow, Sony vtc 4, , vtc 5 flat top.. I know what I am doing.. I have 60 lights. Lol..
Lightbringer
When you drop the cell into the tube, does it stick out above the edge, or sink down into it a mm or two?
That’s what Bubba Zanetti said, and look what happened to him
Newlumen
Newlumen's picture
U guys know unprotected button top is longer than unprotected flat top.. someone told me I didn’t tighten the tailcap all the way. Lol.
My opinion is the button top didn’t make contact with the head..
I am at work. Tonight I will try with all the different type of battery and report back.
I had a scroll through your website mate good to see you updated since I last visited. I think I need to buy an rc car now look like fun lol. I have been on hobbyking a bit lately but the shipping is stopping me. The aus warehouse has sh*t all stock.
Firelight2
Firelight2's picture
Last seen: 9 hours 39 min ago
After lubricating the o-rings at the USB port and cycling it a number of times the port cover is now much smoother. It no longer requires gorilla muscles to open up like it did when I first received it.
Much better!
old4570
Hehehehe , yep !
Sometimes the stock levels for the Oz warehouse are disappointing ..
Try Banggood.com or possibly gearbest for your RC needs ..
I have recently started to play with Micro quads like the Eachine EO11 and the JJRC H36 bound to my Turnigy 9XR pro VIA a multi protocol module .. https://goo.gl/v37FxQ
These things can be flown inside or outside .. ( And for the $$ are just a boat load of fun )
My JJRC H36 set me back $17 AUS … RC is cheaper than smoking these days
Newlumen
Newlumen's picture
Ok.. here we go. All the 18650 are unprotected.
Lg he4 flat top. Work
Samsung 30q flat top. Work
Sony vtc4 flat top. Work
Samsung 30q button top. Not work
Lg mj1 button top. Not work
Sony vtc6 flat top. Work
Lg mj1 solder blop. Not work
Sony vtc5 solder blop. Not work
Lg mj1 flat top. Work
Sony vtc6 button top. Not work
postimage
old4570
postimage
Looking inside the light , the driver / contact board has a contact nipple on it ( solid ) . So I can’t see that end being the issue …
Take a MM or some wire , and pop the battery in and then run the wire or MM from the back of the battery to the body ..
Does the light turn on ?
Newlumen
Newlumen's picture
I dont know how to do that. Lol.. but anyway.. i am not here try to complain or cry.. i love this light. It cost $31.79 and received in 15 days.. ( fast ).. i used to have an olight m1x striker xml led cost $60. This zanflare f1 is great deal.. latest led. True moon light. I can navagiate around the surounding in low mode.. i also like how the tailswitch operate.. while the light is on, half press the tailswitch will temporary turn the light off.
Conclusion. I love this light for what it is. Great price. Xpl v6. Great construction. I will buy zanflare light again.
I just dont understand why my light doesnt like unprotected button top or solder blop. Thats all.
old4570
One needs to isolate the issue !
Is it the driver side , or the clicky side that is the root cause ….
If you have some electrical wire , one merely runs it from the back of the battery to the bare aluminium at the tail cap end , all you are doing is completing the circuit … ( Much like the clicky switch does )
If the light turn on when completing the circuit , the problem is not the battery ..
To find solutions to problems , one first needs to know what the problem is ! ( Because I am using a flat top battery in mine )
If we eliminate the battery or the front of the flashlight , then that points to something entirely different .
And after (?) is it almost 10 years now , one of the major reasons for issue for most people is the tailcap / clicky / assembly . ( And often the fix is as simple as tightening the retaining ring ) .
Lightbringer
You sure you charged ‘em? Big Smile
old4570
Ok , 16340 ..
I charged up some 16340 , these are really old unprotected 16340 , but always performed well .
They came of the charger at some 4.09 volts ..
Low / med / high output was a match for the 18650 ..
What surprised me was the output on Turbo , 1300+ Lumens which ran for all of about 5 seconds before the thermal protection kicked in …
I get the feeling that perhaps this light might be meant for the 3v rechargeable 16340 … ( 3.6v ‘ish fully charged ) ?????? Because Turbo on the 4.2v Fully charged 16340 ( well , 4.09v ) really pumped … There does not seem to be any advantage using 16340 ( 3.7 nominal ) for output in the other modes . And 5 seconds of Turbo is ( ? ) … I dont have any Primary CR123 that are new .. I have some old ones in my Surefire .. Yep , pretty much spent after all these years .. ( Just tested ) Might have to order a 17650 for the 6P surefire …
Sorry about that guys , all my Primaries are like seriously old and I should probably toss them .. ( Confirmed )
huntking
Hi Zanflare, I visit your website. How to get a F2?
huntking
Thank you, Zanflare. I will check out them .
huntking
ordered it
