Correction GXB20 is 93% efficient at this level. Also, I miscalculated temperature.
Linear driver with 350 mA PWMed to 203 will run for 345 minutes.
GXB20 v1 9V 67 mA using your efficiency numbers over a smaller voltage range (93% efficient): 448 minutes
GXB20 v1 9V 67 mA using your efficiency numbers over a smaller voltage range (85% efficient): 410 minutes
Still hopefully conservative 20% runtime increase.
One thing which just a while ago came to my mind with this ∅17mm and ∅20mm dual design is that, in flashlights with generous 20mm driver shelf height, it should be possible to install (at least) an additional ∅17mm driver board above the ∅20mm base one, running both in parallel. I do not really know how much would be the total driver team height, yet I suspect that even if power handling would need to be restricted for the floating board(s), this could be rather interesting for XHP70s and/or power freaks.
Of course, with this massive power handling from a 1S source a good low RDS(ON) MOSFET tail switch would be advisable/required.
Oh! Another related thing. I must admit I find a smidge bit irking the usual practice of specifying a “nominal” single output voltage for constant current drivers. In my honest opinion, I'd specify the effective output voltage range. For example: GXB17 3A 4.8-7.4V.
Now, for the folks who may complain, it is best for it to be this way so we can educate the philistines.
P.S.: wanting to check out what happens to products with poor labeling? Take a peek at those 3×3 10W “12V” led arrays at Banggood, plenty of customer reviews with fried leds after hooking them to random 12V constant voltage supplies. Just remembered this (LoL!).
Pretty phenomenal work loneoceans. Driver development has been a strong suit here in recent years thanks to members giving their time and skills to the process. It wouldn’t happen otherwise. Thank you for these
Another calculation, linear driver’s favourite 350 mA. 170 OTF lm. If I’m doing 18350 calculations, the body is small and I should increase host’s thermal resistance, so this time I’m using 15 C/W. It was 10 before.
linear driver: 200 minutes
GXB20 v1 with the measured 98% efficiency: 272 minutes
GXB20 v1 with 90% efficiency: 250 minutes
If you are going to do ATtiny841 firmware to share, my I suggest you use Atmel Studio and share that code instead? I know you did the 84 firmware for Arduino as you wanted to make it more accessible, but the majority of people here, myself included, learned how to flash drivers by following the many excellent tutorials here using Atmel Studio and AVRDUDE. To my knowledge, no one else here has released flashlight firmware for Arduino before. And you did say you preferred Atmel Studio, so releasing in Arduino is actually making it more inaccessible, at least for most of us here.
I have an Arduino myself, I used it to make a high voltage serial programmer, but being used to Atmel Studio I refuse to use it for flashlight firmware. I haven’t built drivers from the GBX20 boards I got from you yet. I was going to “port” your Arduino firmware to Atmel Studio for Attiny841, but haven’t gotten around to it yet. I haven’t dug into the details yet, but if I understood correctly, the GBX20 is a momentary switch driver only? Or does it have support for clicky switch only lights? I’m interested in making a clicky switch (and dual switch) compatible version of the GBX17 with Attiny841 firmware, but if you already support this I’ll just wait for yours to become available.
The problem with Atmel Studio is that it’s windows-only. If my memory serves me right, I’ve seen some Linux-specific makefiles, so I suppose not everything is going to be happy with Atmel Studio.
Porting for AS XML to Makefiles is possible; if you know what to do, it’s not very hard really. But with Arduino, you install the IDE and at least you can compile the code right away.
Personally, I did use Atmel Studio. I never used Arduino. Still, I fully support loneoceans’ choice. I’d rather learn Arduino than have to fork to use Makefiles on my OS.
I was under the impression that the .c file from Atmel Studio could be used on a Linux environment without modifications at all. You just have to have the Atmel toolchain for Linux.
C file - yes it just works normally (if they use ASF there’s extra work, but I haven’t seen ASF use in flashlight). But you need to extract the compilation / linkage flags from the atmel studio project file and put them in makefile.
I see. Anyhow, there are a few folks here using Linux and the regular flashlight firmware that others use in Atmel so I can’t imagine it being that difficult, but ultimately I can’t say as I don’t use Linux.
What I can say is that besides the GBX20 firmware I haven’t seen a single flashlight firmware written in Arduino. In terms of being accessible to BLF members, Arduino is hardly used here. But yes, there is a world outside of BLF (so I’ve heard) so I guess Arduino is the better choice for the masses. I’ll just make my own 841 firmware once I get around to building my GBX20 boards or get some GBX17s, my Arduino is collecting dust and I aim to keep it that way
Since this is open source I wonder if RMM could pick this up and be willing to sell built drivers like he does. He would be the one that could order a couple hundred boards at a time. And he uses a reflow oven he could produce a good bit at a time
GXB17 PCBs arrived. Got one assembled; time to put it to test. For this run I was able to use OSHpark's 0.8mm 2oz copper process. This should give better performance..
