Lumintop IYP365 XP-G2/Nichia AAA EDC LED Portable Pen Flashlight is for $12.00 using code LMTIYP365 (-US$13.00).
Cree XP-G2 R5 or Nichia 219BT high CRI options available.
Mode order is medium≫low≫high, no mode memory. If you want similar pen light with low≫medium≫high mode order with Nichia LED see Nitecore MT06MD
Lumintop SDmini XP-L HD/XP-L HI 1000LM Rechargeable EDC LED Flashlight using code LMTSDMIN lowers price to $39.99 (-$9.91)
Holster and USB charging cable (standard micro USB) is included. Flashlight has 4 constant modes and 3 hidden blinkies, max 1000lm, two LED options are available: Cree XP-L HI for better throw or Cree XP-L HD for more light.
Raspberry Pi 3 Model B ARM Cortex-A53 CPU 1.2GHz 64-Bit Quad-Core 1GB RAM 10 Times B+ is now at $39.99 and using BG points it’s possible to get price as low as:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$33.99 |
$33.59 |
$33.19 |
$32.79 |
$31.99 |
Update: Deal expired.
»New deal available here«
BlitzWolf® BW-ET1 XP-L V6 750LM Stepless Dimming Mini EDC LED Flashlight 14500/AA is now in preorder for $28.95
300 orders only, then the price will rise to $30.55 and after another 300 order to $35.95. Target price is supposedly set at $39.95.
Matching extension tube is now in preorder as well for only $1.15:
»New deal details here«
Astrolux MH10 XPL HI 18650 1000LM USB Rechargeable Outdoor LED Flashlight for VIP2 and above accounts is for $29.99 and using BG points it’s possible to lower the price further:
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$25.19 |
$24.89 |
$24.59 |
$23.99 |
The flashlight features micro USB charging port, backlight LCD screen and is capable of delivering anywhere from 1lm to 1000lm of cool or neutral light using Cree XP-L HI. Package includes holster, charging cable, lanyard and spare orings. Registered shipping included as well in the price.
Deal expired - coupon code now available - details here.
HaikeLite SC02 MTG2 5000K 26650 2000LM EDC LED Flashlight is in preorder for $42.95 and using BG points price can be lowered to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$36.51 |
$36.08 |
$35.65 |
$35.22 |
$34.36 |
SKILHUNT M2 2016 Li-ion Ni-MH Ni-CD Universal Multifunction Charger for VIP2 and above accounts is for $10.99 and using BG points it’s possible to lower the price to:
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$9.23 |
$9.12 |
$9.01 |
$8.79 |
According to excellent HKJ review it’s good and simple to use charger:
Test/Review of Charger Skilhunt M2
BLF A6 XPL 1600LM 7/4modes EDC LED Flashlight + INR18650-30Q Battery is in promotion for $21.95 and BG points still work so it’s possible to lower price even more to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$18.66 |
$18.44 |
$18.22 |
$18.00 |
$17.56 |
This is probably the lowest price for the set with battery to date.
4pcs NCR18650B 3400mAH 3.7 V Unprotected Rechargeable Lithium Battery is for $17.99 and using BG points it’s possible to lower price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$15.29 |
$15.11 |
$14.93 |
$14.75 |
$14.39 |
LUMINTOP LM34C Micro-USB18650 Protected Rechargeable Li-ion Battery for $6.99
It’s easiest way to convert flashlight into micro USB rechargeable one. Internally it uses Panasonic NCR18650B 3400mAh cell and is longer like all protected cells at 70.7mm so be sure to check if it will fit.
Using BG points price can be lowered even more to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$5.94 |
$5.87 |
$5.80 |
$5.74 |
$5.59 |
Astrolux S1/BLF A6 A17DD-L FET+1 2.8-4.35v 7/4 Modes Flashlight Driver is for $4.29 and using BG points price can be lowered further:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$3.65 |
$3.60 |
$3.56 |
$3.52 |
$3.43 |
This is exactly the same driver that powers Astrolux S1, Astrolux S41 and BLF A6 flashlights. It’s capable of delivering 6A of power (with quality high drain cell of course) and also features one AMC7135 for efficient low and moonlight modes. Sub lumen moonlight is possible with XP-L (3-4mA which would be about 0.2-0.4 lm). User selectable memory and two mode groups (3 and 7 modes accordingly), hidden blinkies include bike flasher and voltage indicator mode.
UI is very ergonomic - using short click you can go one mode upwards and using medium tap (0.5-1.5s - very intuitive once you try) you can change the mode backwards - no need to circle back whole mode bank.
This driver was conceived here at BLF, designed by Wight and the firmware was written by ToyKeeper. It’s open source and available here: ToyKeeper BLF A6 Firmware
How do you get the S41 for $23.95? It shows $30 when I click the link.
HaikeLite SC02 MTG2 5000K 26650 2000LM EDC LED Flashlight using the coupon code »Request via PM here« lowers price to $40 (-$24.95).
This flashlight has micro USB port for cell charging - it’s located on the head screws so when flashlight is used it’s completely covered.
HaikeLite MT01 Trekker XHP50 V2 CW/5000K NW 2500LM LED Flashlight using coupon code »Request via PM here« lowers the price to $38.95
HaikeLite MT02 XHP35 HD CW 2500LM Thrower EDC LED Flashlight using coupon code »Request via PM here« lowers price to $37.50 (-$14.50).
HaikeLite MT03 II Devourer XHP70 2SPS 8760LM CW/NW High Power LED Flashlight using coupon code HLMT03 lowers the price to $96.95
HaikeLite MT07 Buffalo XHP70 5000LM CW/NW High Power LED Flashlight using coupon code HLMT07 lowers the price to $79.95.
That deal expired - I updated the details. Now you can either use coupon code 8a955d to lower the price to $25.50
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight
or BG points to lower the price depending on your VIP status:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$25.50 |
$25.20 |
$24.90 |
$24.60 |
$24.00 |
All colors Nitecore T Series Tube 45LM USB Rechargeable LED Light Keychain using coupon code b00e77 lowers the price by 30% (to $6.93).
Update: Deal expired. Now coupon code available - leave me PM for details.
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight for VIP1 and above is for $23.56 and using BG points it’s possible to lower the price even more to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$20.03 |
$19.79 |
$19.55 |
$19.32 |
$18.85 |
18650 extension tube available here:
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $2,49 (BG points can be used to lower price further).
