Interested.
Interested.
Thanks
Interested.
Sample has arrived!
interested.
I love AA lights!
Bought some new batteries for our new light!
Interested.
Sent PM
interested.
Does this have noticeable PWM?
No visible PWM for all levels. Tested with Li-ION and Ni-MH.
Estimated max lumens with 2xAA please
I am unable to provide accurate results because there is an installation issue with emitter. I have already reflected to BG a few weeks ago regarding this matter. They replied me that my sample was upgraded by the factory before sending it to me. They reassured me that it was isolated case, and it would not happen to the actual production units. I will follow up with them on that.
According to the manual, XP-L V5 AA is 180lm max. No increase in brightness (measured from my sample) if you choose to run 2xAA, what you get is extra runtime only. Please take note.
Ok thanks
Still interested… But the coupon does not work if you leave the free extension tube in your cart.
It gives an error: “This coupon cannot be used on gifts and accessories.”
Managed to find some time to work on ET1 in the morning. I think i have the duty to inform you guys for what I discovered for my sample underneath the reflector :FACEPALM:
I have reported the matter but i cannot guarantee they will change the assembly method for mass production.
I’m not exactly sure what happened there, but it doesn’t inspire confidence in the quality of the light.
I guess it is a good thing that the coupon with the free extension tube still doesn’t work or I would have already ordered it. Today it doesn’t even add the free extension tube ‘gift’ to your cart. It still shows the ‘gift’ checkbox as you circled in your first post, but it doesn’t appear the cart.
How does the UI work? Any glitches?
OMG!!
Watching this photo
+1
I was lucky
Operation:
Short press:
Open or close the torch. (low brightness when first open.)
Long Press:Into Stepless Dimming:
100% brightness, indicated by triple flash
50% brightness, indicated by double flash
1% brightness, indicated by single flash
Light will flash when it reaches the Min and Max output
Note: There are two directions when stepless dimming
Click the button twice into the brightness light when the flashlight is off or on lighting mode.
Click three times to strobe and long press to SOS mode.
Click twice back to the previous mode or brightness when on strobe and SOS mode.
Coupon updated.
I was briefed that they have fixed the glue issue for the retail version. I will verify it again for you guys when i receive my 2nd sample.
