Old design magnetic tailcap, like S10RII was better.
You can use any 16340 and the light was able to charge it, and no live contact…
But I think the design was pricier for them because the charging circuit had to be integrated to the light.
Update: according to Olight’s engineers there’s over current protection on the battery at 27 amps. So shorting the tailcap contacts will not damage the battery or the light.
If they went through the trouble to put a [short] current limiting circuit, why would you set it at 27A? A lot of cells will still get dangerously hot and can still vent if ran continuously at that current. Seems silly.
And one more THANK YOU to maukka for your AWESOME reviews!! It's unfortunate that it took this long for light tests/reviews to start actually characterizing the LIGHT (beyond lumens/lux) and not just the physical torch/flashlight. Maybe this will get more momentum into the high CRI market. These days you don't need a CW top bin emitter to get practical flux numbers. 90CRI Nichias in a 3.5mm footprint are capable of 900 lumens with only moderate over-driving (~3.5A). I know that we all love our 2000 lumen headlamps, but lets be honest; how much do you actually get to use that? Until Lumens/W take a HUGE jump, there's a harsh limitation to heat dissipation in our compact lights. And in my experience, about 1200 lumens is a max for a practical and usable 'High' in an EDC/headlamp. Anything higher only makes sense as a momentary function. Just my $0.02.
Since the protection is in the bundled battery, which is a high current one, and only Olight proprietary cells can be shorted via the tailcap contacts, I see no problem. Other 18650 Olights compatible with the H2R charging system I have tested have had their OCP at much lower levels: if I remember correctly 5 A for the 3200 mAh (came with S2R) and 11 A for the 3500 mAh (S30R III).
Now, who has a clamp meter, an H2R and balls of steel? I want to know if a dead short using a thick wire actually trips protection on that battery. It doesn’t have low-voltage protection (WTF?), so I’m not sure I believe them about this.
THank you, because despite the price i like the light to be honest (WW tint), ......but now it seems i'm not able to understand something in the whole story. :confused
I received mines today in neutral white. Mine is definitely neutral white. If I had to guess, maybe around 4600 to 4700k. It’s just slightly warmer than my EC4SW’s (MT-G2) and much cooler than my Manker E14 II with 4000K Nichia 219C. I was actually looking forward to the warmer temp that I saw in this review and another review, but in the end I’m very happy with the temp and tint.
My new favourite reviewer! The lumen/hour comparison is very useful, give us to the technology used by each manufacturers. Would love to see medium and high runtimes and lumen/hour as well if you have the time (for future review).
The battery of my H2R died suddenly, no reading at all. I removed the wrap to discover it was a 30Q inside (I thought it was VTC6), and the reason it died was because the cell’s internal protection triggered after being shorted.
I must have missed it the first time round, but got here in the end, after ZoomieFan provided the link
I normally lean towards throw rather than flood, but I was still rather interested in the H2R until I saw that “neutral white” was actually warm white. Would have made a nice area work light. Oh, well.
