Okay, okay, I give in. Please put me on the list for 1 unit.
Thanks.
(I know, list will be updated soon)
Thanks.
First of all let me make it crystal clear I am NOT one that is pushing for, suggesting, or advocating a dual footprint MCPCB.
I simply want/would like to know what the ādesign differenceā is between a single & dual footprint board. That is all.
Some people are saying it would be no problem designing & making a dual footprint board.
Others are saying the exact opposite.
This leaves the mentally challenged, such as myself; confusedā¦. to say the least. :person_facepalming:
Both groups canāt be rightā¦. I donā think anyway.
Which group is correct??
Heckā¦ just leave the Q8 out of it.
That is ALL I really want to know.
They both are correct because the question was not clearly defined.
Is it easy to change the design of the mcpcb to a dual footprint board? Yes
Is it easy for Thorfire to change the mcpcb to a dual footprint board? No
The Miller elaborated on the many reasons itās not easy for Thorfire to do this.
I think anyone who said it would be easy for Thorfire to switch designs were purely speculating. I would have to defer to The Millerās answer.
Thanks Jason, that answers what I wanted to know. :+1:
AFAIAC the rest of it is a mute point.
The explanation djozz gave several post back as to why it was a very bad idea to change anything about the MCPCB made perfect sense.
Perfect sense in that it could lead to untold Q8 misery with what TF might come up with.
Nobody wants that possibility to be introduced any more than it already is.
And that is by far the best summary of the situation Iāve read so far! You are clearly enlightened.
^ This too ^
Phil
So itās just down to locating new springs and dealing with board delamination, right?
Iām crossing my fingers both can be addressed soon.
Yes, that is right
Springs
Board
Narsil latest version
Manual (4 pages 1 general manual and 3 on par with Narsil)
Pretty close now
and
Flag these to be elaborated for a ālessons learnedā reconsideration, once this is all over.
Now cue the ominous background music.
āWhat are they doing over there? Itās quiet. TOO quiet ā¦.ā
Somewhere out there, a bean-counting cheese-paring businessman is nibbling away at a design specification to make a little more profit on each piece.
https://www.google.com/search?q=scorpion+frog
You know things have gone a little too far when even Doctor Frankendale thinks itās dangerous.
I finally did some testing, now that Iām back from Asgard and have a working computer again. Not sure how much Tom will have time to change, or how much he wants to change. There donāt seem to be any important firmware issues, but there might be some small things to fix or some small improvements to add.
ā¦ and hopefully it wonāt turn out like the X6v2, where the units shipped with old firmware. That was unfortunate.
+1, yes it is! Simple, factual, to the point.
Pretty close now
Three great wordsā¦ā¦
Aside ā has someone checked how āphosphor bronzeā translates?
Thereās been so much confusion because copper, brass, and bronze all seem to translate poorly to Chinese.
éļ¼é»éåéé
TĆ³ng, huĆ”ng tĆ³ng hĆ© qÄ«ngtĆ³ng
It would be good for them to know how Djozzās phosphor springs made in Netherlands were specified ā alloy? unique identification numbers?
Googling the term, thereās a wide range of variation:
Phosphor bronze - Wikipedia
Phosphor bronze is an alloy of copper with 0.5ā11% of tin and 0.01-0.35% phosphorus.
Resources: Standards & Properties - Copper & Copper Alloy Microstructures: Phosphor Bronze
The phosphor bronzes are designated as UNS C50100 through C54200. Leaded phosphor bronzes combine good strength and fatigue resistance with good machinability, high wear resistance and corrosion resistance. They are used in applications such as sleeve bearings, thrust washers, and cam followers. They are designated as UNS C53400 through C54400.
Iām very pleased that the Q8 has a tripod mount, and Iāll credit myself for being the first to suggest it waaaaay back in post #25!
The Noctigon Meteor doesnāt have a tripod mount, so I made one out of a quick-release ātruss clampā used in concert and theater lighting.
This type of mount is rock-solid for attaching the Meteor to a bicycle, ATV, or anything that can have a screw or bolt fitted to it.
Iām hoping the clamp will fit the Q8, too.
Can someone with the latest Q8 prototype share the diameter at the center of the battery tube?
I realize the diameter may change slightly for final production, but the truss clamp works from about 1-7/8ā to 2-1/8ā.
Can I give measurements in mm? Inches are so strange to me.
Of course! I speak metric as well as imperial.
BTW, 1 inch = exactly 25.4 mm.
Ha how tired I am, the caliper has a button to switch so I can give both, tomorrow, the Q8 is next to the bed and I know I just donāt want to bring it from there before I slept a little
Ah and yeah thanks for giving us a hard time making that tripod hole a part
No joking, it is an awesome part, really thanks
The diameter in the middle of the battery tube, away from the flat bits is 50.0 mm.
Youāre very welcome! The Q8 will be an awesome work light when paired with a small tripod!
Thanks! :+1: Looks like a good fit for the truss clamp.
For anyone interested, the 2ā quick release truss clamps can be found on eBay for about $10 each.
To make two mounts, go with a ādual swivelā clamp like this:
