Olight H2R review (Headlamp/right angle, 18650, XHP50)
THANKS!
i really like your detailed reviews!
Since the protection is in the bundled battery, which is a high current one, and only Olight proprietary cells can be shorted via the tailcap contacts, I see no problem. Other 18650 Olights compatible with the H2R charging system I have tested have had their OCP at much lower levels: if I remember correctly 5 A for the 3200 mAh (came with S2R) and 11 A for the 3500 mAh (S30R III).
Now, who has a clamp meter, an H2R and balls of steel? I want to know if a dead short using a thick wire actually trips protection on that battery. It doesn’t have low-voltage protection (WTF?), so I’m not sure I believe them about this.
Question is, how can this be IPX8? if submerged and also maybe in heavy rain will this short?
Olight H2R torture test
THank you, because despite the price i like the light to be honest (WW tint), ......but now it seems i'm not able to understand something in the whole story. :confused
I received mines today in neutral white. Mine is definitely neutral white. If I had to guess, maybe around 4600 to 4700k. It’s just slightly warmer than my EC4SW’s (MT-G2) and much cooler than my Manker E14 II with 4000K Nichia 219C. I was actually looking forward to the warmer temp that I saw in this review and another review, but in the end I’m very happy with the temp and tint.
My new favourite reviewer! The lumen/hour comparison is very useful, give us to the technology used by each manufacturers. Would love to see medium and high runtimes and lumen/hour as well if you have the time (for future review).
Big thanks Mauri,
  • Clemence
PWM - mark of cheap lights.
That countdown could be very fast. One use of that magnet is stick the light to a metal surface.
Or imagine keeping it in you pocket with a few coins.
Sure is. Personally I really like the lm/W graph!
The battery of my H2R died suddenly, no reading at all. I removed the wrap to discover it was a 30Q inside (I thought it was VTC6), and the reason it died was because the cell’s internal protection triggered after being shorted.
A real shame that huge design flaw pulls down this light from high quality to medicore. Perhaps still good for walking the dog, but not as worklight.
A really good review, maukka - thank you :+1:
I must have missed it the first time round, but got here in the end, after ZoomieFan provided the link :slight_smile:
I normally lean towards throw rather than flood, but I was still rather interested in the H2R until I saw that “neutral white” was actually warm white. Would have made a nice area work light. Oh, well.
That problem has been corrected, they’ve re-designed the tail cap so that can’t happen anymore:
It was asked about recently (this month) in the Q/A section in their site: Olight | Illuminate Your World.
“With the new tail cap is there still a danger of shorting out with metal objects?”
OLIGHT answer:
“The new tailcap does not have a danger of shorting out with metal objests”
I’ve read other reviews where the H2R NW has actually been closer to 5000K. So it may be a gamble or the first production run used a warmer emitter.
I think it’s that first production used the warmer emitter and they’re all 5000K now. I want to say CalvinIS confirmed that, but I’m not 100% certain off the top of my head. My review sample from Illumn was 5000K, and I haven’t heard of anybody getting a warm one in the past 6 months.
The old tailcap used a PTC thermistor to reduce the severity of shorts. It wasn’t bad enough to make the battery explode, but it could easily ignite things. The new use uses a diode to prevent them, which was what they should have done from the beginning.
How do you tell if you have the old or revised tail cap? I sent two emails to Olight already and they just ignored me.
Thanks for one more amazing review, the runtime graph with temperature and that thermal camera makes the difference :+1:
Get some steel wool and touch it to the tailcap. If it ignites, you have the old one.
