Flashlights, spotlights, searchlights, we talk about all of them here.
OP didn’t specify just tube flashlights or EDC or anything like that.
You don’t seem to understand that there are lights with different designs that aren’t your typical “battery tube with big head” and actually have better heat dissipation, higher output, higher price, etc.
Oh well, the op’s main beef is “what light can sustain the turbo or its highest level without stepping down and will only notch down due to battery depletion”.
How it can do it is not the issue and perhaps deserves another thread.
The Q8 can’t do 4000 lumen continuously, it has not enough surface area for that. I have half an hour tonight and will try 3000 lumen, from cold start, and measure how hot it gets.
Edit:
I did a wee test at 3000 lumen (on GA cells), at 12 minutes the head temperature of the Q8 is 63 degrees Celsius, so still far from dangerous but too hot to hold.
May do a proper test later. My guess is that the sustainable output (=can hold the flashlight at room temperature with no active airflow?) is less than 2000 lumen.
The Olight X6 is 5k lumens, the PH50 is 4-5k lumens as well, the WiseLED Xtruder ST is 10k lumens, The XeRay LX70 does 7500lm, and there are probably a few more HID lights I’m missing.
Isn’t the Trustfire T90-2 a 2500-ish lumen light? (not nearly 4000lm )
The Lumintop SD75 is a very good light, and has some of the better heat dissipation fins, but has been tested by a few people, as only putting OTF lumen numbers of about 3150lm. Then even if it was a 4000lm OTF flashlight, its run time chart looks like a ski slope.
Do you happen to know where we can go to see some reviews of any of these lights, that may also incorporate run time and lumen tests? I am having a hard time finding much of anything.
I should try my 14,000 lumen TR-J20 with it’s very large additional heat sink. Sure, it’ll heat up some at full power but should run very well at half power or so.
It’s using 4 of the 9V variant MT-G2 powered by 3 6000mAh 32650’s. There is about a 1/4” thick slab of 6061 between the stock emitter shelf and the 4 20mm MCPCB’s, with a head filling additional heat sink underneath the stock shelf.
Should probably also run my DBC-05 with it’s triple XHP-50.2 set-up and the large copper midsection. It might fare well at half levels as well, which would be in the 6,000 lumen range. The copper pill started out as a 3.17 pound bar of Tellurium Copper.
Not factory lights, I know, but the additional mass is well beyond what might be called normal, will check tomorrow and see how this fares in practice…
Now with that, I have to disagree with your conclusion Enderman, You are of course correct though, when you state that “tube very far away”, and with “cross-sectional area of the battery tube is very little”, and also with your “causing bad heat conductivity” statement.
But, it is in addition. As an example here. The 220sq/cm is in addition, to lets say the 1000+. So lets say that is 20%. Of course its location is not prime real estate, near the emitter shelf. But additional none the less.
I have seen far too may thermal imaging tests of flashlights, to not know that the battery tube goes a long ways towards drawing heat away from the head.
We also have many other examples of how this works, but lets keep this thread on target. :+1:
Great choices DB Custom! I would love to hear what you find out.
Someone else here mentioned the Acebeam X65, which is a pretty big, heat dissipating flashlight, with a 6000lm level. It’s going to be close, but that one just may do it?
I have an Acebeam X45, with a 4000lm level, that will keep that pace for about 1.4 hours. So we could throw that onto the list as well. But I have not been able to find anyone who has documented its OTF lumens. I suppose it is pretty close to 4000lm, when on that level.
