Luminus SST-40, a N4 BA bin tested
363 posts / 0 new
djozz
djozz's picture
Last seen: 10 min 32 sec ago
I did not test a Luminus led before. The SST-40 is new, cheap for a Luminus led and has the XM-footprint so a DTP copper board for it is readily available. The specifications are also very similar to a XM-L2 led, but it is always the question what will happen when we go out of specs! Smile
The led that is tested was bought from Kaidomain, the output bin is N4, which is not the highest bin listed, the tint bin is BA which is just above 6500K.
The test was done like all my more recent emitter tests. I described it in detail in my XP-L test. , with two minor differences that should not matter significantly for the results: I used my Integrating sphere no. II instead of no. I, and for the current I used a clamp meter, which appears to measure 0.1A lower than the power supply current-reading that I used before.
In summary: 1) just one led was tested, reflowed on a DTP copper board (XM-KDlight 16mm),  2) I used my large version II integrating sphere with high quality luxmeter, 3) the output numbers and voltages were measured with the led close to 'steady state' for each current, so warmed up and settled, you should be able to get these numbers in a well heatsinked flashlight. Mind that these are output numbers of the bare led, in a flashlight there will be losses from light obstructions, lens and optic, 4) output is in 'djozz-lumen' defined as 1/550 of the output of my Sunwayman D40A on high setting, which I hope is close to the real lumen, but at least is consistent over all my emitter tests done in integrating spheres.
Here's what I found:
What can be seen:
*the output of the SST-40 does very well compared to the XM-L2 and XP-L. None of these 3 leds tested were the highest output bin so up to 6A it may well be a photo-finish, but above that the SST-40 seems the winner.
*the voltage of the SST-40 is way lower than both the XP-L and XM-L2, this means that at a given current it is more efficient at same output, and that you will more easily drive it hard in a single li-ion flashlight.
*the led died at 9.5A in a classic way: burnt bond wires, this is about the same current that the old tough  XM-L2's died at, but the newer ones go at a lower current:
Conclusion:
The SST-40 is cheap, can be used wherever you use an XM-L2, and performs better with both a lower voltage and higher output. This is a fine new led! Only drawback that I see is that although it does come in various colour temperatures and tint bins, it is all 70CRI.
And then of course for a led performing so well the question is: does it dedome and do you gain luminance by doing that? I leave the gasoline methods to the pro's and I tried a hot dedome, which actually went quite well: the dome material behaved a lot like the classic Cree domes (not as stiff as i.e. Nichia domes) and partly it separated nicely from the phosfor on top of the die, leaving some silicone behind on the rest of the die. But the phosfor layer stayed attached well, and I could scrape off most of the remaining silicone off the phosfor with a wooden tooth pick without visually damaging the phosfor. Not perfect at all but so far so good, this is better than any other non-Cree led that I checked for hot dedoming before. Here's how the die looked at very low current:
I had a Lucky-Sun D80 (BLF-edition) spare and put the dedomed led in there, with a BLF-A6 driver, tail-spring bypassed.
And it performs!  On a 30Q battery 7.5A from the clamp meter with tail off, 1626 lumen out the front (tail on). Pretty good for a dedomed single die XM-size led! The dedomed tint is really good, less yellow than most dedomed Cree's. Just the throw could be a bit better, I measured 103 kcd at 30 seconds on a 30Q. I'm curious about throw numbers of properly dedomed SST-40 leds.
The Miller
The Miller's picture
Last seen: 1 year 6 months ago
Nice test
Clear why Olight is using these.
EasyB
Last seen: 4 hours 5 min ago
Great results, thanks! I’m not familiar with the D80; what do other dedomed emitters do in this host?
RotorHead64
RotorHead64's picture
Last seen: 2 months 2 days ago
Very nice! I've been wondering about this one for a while.
I would love to see you review their new SST-10-UV 365nm
djozz
djozz's picture
RotorHead64 wrote:
Very nice! I’ve been wondering about this one for a while.
I’m a bit reluctant testing 365nm leds because I think my method is not good enough. But where do I buy those SST-10 UV leds?
djozz
djozz's picture
My other BLF-D80 has its stock XM-L2 dedomed and the same driver, it does 95 kcd. But it is an unknown bin, I can imagine that others have had better results with high binned dedomed XM-L2 and XP-L. Anyone?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 58 min ago
Thanks for the test mate. We may see these being used around here very soon. I’ll buy some soon should make a good pocket rocket flooder.
Agro
Agro's picture
Last seen: 1 day 13 hours ago
djozz, could you please add a table with individual measurements (preferably with power consumption and efficacy) to the chart?
djozz
djozz's picture
I could add the numbers but it will suggest an accuracy that is not there. My djozz-lumen was never properly calibrated so it is mostly useful when comparing it with my own measurements of other leds, and that is best visioned in a chart like above.
MRsDNF
MRsDNF's picture
Last seen: 42 min 21 sec ago
Thanks for the test djozz. More invaluable info. Smile
LightRider
LightRider's picture
Hmm? I would have though there would be better throw based on the output you have measured. More light that a dedomed xml2 from the same die size would make me think more lux. Maybe the phosphor isn’t as smooth and scatters light a bit more to the sides?
djozz
djozz's picture
Could be, I’m waiting for the dedome experts to do a clean dedome, should be possible. In my led there are bits of silicone still present on the die.
djozz
djozz's picture
Luminous efficacy would be nice, but can be derived from the chart if you extract the numbers. This parameter for flashlight use is a bit less relevant than you may expect though, many types of regulated drivers burn off ‘overvoltage’ which makes the efficiency of the flashlight a lot less related to the efficiency of the led.
Agro
Agro's picture
Yes, I know what can be derived. It’s just that reading data from the chart only increases the error.
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 week 2 days ago
I am always peaking on your reviews and hoping for… Well you know what…
But very valuable review to anyone on this planet.
And yes imho hot gas(or other suitable hot solvent – i use other solvent) is far superior and easier than hot de dome. I know that you are scientist but I can teach you that if you want Smile
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
The_Driver
The_Driver's picture
Last seen: 18 hours 48 min ago
Thanks for your efforts!
What is the diameter of the large opening of that reflector?
djozz
djozz's picture
The D80 reflector opening is 34mm
EasyB
Based on djozz’s measurements here, the D80 should do about 25% higher in candela than the X6 reflector, which is consistent with the ratio of their areas. A dedomed XPL V6 1A will do around 95Kcd in an X6, with the stock X6 AR lens. So it looks like the SST-40 falls short of the current best emitter for good output and throw (IMO), even with the higher current of the SST-40. But we will await additional results.
djozz
djozz's picture
Oh yes, the reflector project , it is still an ongoing project but the results are more exciting than doing the measurements so it has stalled Innocent
It is still a plan to test many more reflectors.
RotorHead64
I'm a bit reluctant testing 365nm leds because I think my method is not good enough. But where do I buy those SST-10 UV leds?
SST-10-UV 365nm
The great thing about your method is you have the data you gathered from the others to compare these too.
CRX
CRX's picture
Last seen: 37 min 47 sec ago
Very interesting, thanks Thumbs Up
leaftye
Last seen: 3 days 24 min ago
I need to figure out what light to put this in. Hopefully KD stocks better tints and bins soon. Thanks for another very informative test.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
pinkpanda3310
pinkpanda3310's picture
Last seen: 10 hours 1 min ago
Interesting that this sst-40 is the same size and thermal resistance as an xml2 but the maximum rated current is 5 amp instead of 3.
khas
Last seen: 1 hour 13 min ago
Nice test thank you for your effort Beer
I think it’s great emitter, I just hope it will be available in more neutral tints. I found a seller on Aliexpress selling them for $1.69 I have ordered some so I can practice my de-doming skills.
X6 SST-40 6500K (left) C8S XHP50.2 3A (right)
FmC
FmC's picture
Thanks for the testing Smile
If anyone has seen the N5 or P2 bin listed, I’m keen to grab a few.
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 4 weeks 1 day ago
Thanks for the test. I like what i see!!!! So the Q8 with VTC6, mod ledboard and SST-40 P2 Bin will draw something about ~30A. Maybe even more. Evil
The low Vf is really nice! The low CRI is not so. But i am curious how much output the Q8 would get with the P2 Bin SST-40? 8000+lumen?
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
Jensen567
Last seen: 4 months 1 week ago
Aside from the low CRI how does the light look? Is the beam ringy with color artifacts like the newer crew emitters, or is it fairly consistent?
djozz
djozz's picture
I’m sorry to say I don’t know, I had 2 emitters, one died in the test, the second was dedomed. The dedomed tint is towards a bit yellow, but a good tint, a quite uniform hotspot with a very thin blue-ish edge around it. Nothing of the problems of the new Crees.
One thing I seem to notice is that the led has a large tint shift going from low to high current, the good tint only happens at highest modes when the BLF driver mainly uses the FET.
Jerommel
Jerommel's picture
Wow, impressive graph!
7.5 Amperes seems to be sweet for this thing, at only 3.6 Volts. !
That’s 27 Watts, but ‘just’ a bit under 2300 Lumen.
2000 lumen at around 20.5 Watts though.
2Q19
Jensen567
Happy to hear the tint looks decent. I have one coming with my next order, got it just to play with, but I’m quickly thinking of uses.
18sixfifty
18sixfifty's picture
Last seen: 2 days 12 hours ago
Thanks for the most excellent analysis. Thumbs Up
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
