Copper & Aluminium Mule Build
14 posts / 0 new
CRX
CRX's picture
Last seen: 6 hours 6 min ago
Another wee torch for you today Wink
I built this copper & aluminium triple mule flashlight out of some 3/4” plumbers pipe, 1” aluminium tube and some other bits ‘n pieces I had with the usual hacksaw and hand files.
It has an S6 brass pill filed down and soldered into the copper tube along with a filed down brass retaining ring holding the reverse clicky switch.
I’ve used a slightly different design with this light, incorporating a sliding inner core held in place by friction and a magnetic battery door cover.
This light is 18350 powered and a companion light to my copper & aluminium zoomie build
XP-G2 S3 3C emitters on 20mm noctigon MCPCB
MTN 17mm driver
Reverse clicky tail switch
Magnetic tail
ARC glass
Felt lined battery tube
Carbon fibre bezel insert
Length – 60 mm
Width – 25 mm
Weight – 97 grams (with cell)
Max – 1400lm
Edited by: CRX on 05/07/2018 - 12:49
lionheart_2281
lionheart_2281's picture
Last seen: 2 hours 54 min ago
Another awesome little creation!
You need to make a album or thread with a compilation of all your custom built lights, just 2-3 of each one, they are soooooo good
CRX
CRX's picture
Thanks very much Thumbs Up
Click on the image in my sig Wink
leroycp
Last seen: 1 hour 18 min ago
Cute little thing it is. Are you going to use a carclo lens?
lionheart_2281
Lol!!! Way ahead of me it seems, that’s unreal
CRX
CRX's picture
No, for a few reasons.
I did think about it but this is the last cutting of 1” alu tube that I had and it was just not long enough for an optic to be installed.
I considered not using the brass pill and having virtually no heatsink but as this is a set with the larger zoomie light I felt the floody mule complimented that.
MRsDNF
MRsDNF's picture
Last seen: 12 hours 57 min ago
Very clever. What did you use to cut the section from the copper tube?
Ronin42
Ronin42's picture
everyone should have one of these.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
mattlward
mattlward's picture
Last seen: 5 hours 18 min ago
Once again, Wow!!!
EDC rotation:
FW3A, SST20 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
Emisar D4V2, SST20 4000k
Zebralight SC52w-L2
Zebralight SC62w
CRX
CRX's picture
Laservision Big Smile
I cut and filed a section from another piece of copper pipe Wink
MRsDNF
MRsDNF's picture
Neat. Beer
scrumpypaul
scrumpypaul's picture
Last seen: 4 days 14 hours ago
Stevi man………………….!!! STEVI!!!!
Just stop it will ya!!!!!????
Absolutely awesome – not just the execution, but the design as well – you don’t half think outside the box mate.
You know where I live. Big Smile
Paul
lostheplot
lostheplot's picture
Last seen: 2 days 9 hours ago
great work as usual
even a index of links to you different builds
sorry all images down
thanks photobucket
DavidEF
DavidEF's picture
Last seen: 8 hours 43 min ago
Once again… ART! Great job! Crown
- The YKK Philosophy
