Copper & Aluminium Mule Build
14 posts / 0 new
CRX
CRX's picture
Last seen: 6 hours 10 min ago
Another wee torch for you today Wink
I built this copper & aluminium triple mule flashlight out of some 3/4” plumbers pipe, 1” aluminium tube and some other bits ‘n pieces I had with the usual hacksaw and hand files.
It has an S6 brass pill filed down and soldered into the copper tube along with a filed down brass retaining ring holding the reverse clicky switch.
I’ve used a slightly different design with this light, incorporating a sliding inner core held in place by friction and a magnetic battery door cover.
This light is 18350 powered and a companion light to my copper & aluminium zoomie build
XP-G2 S3 3C emitters on 20mm noctigon MCPCB
MTN 17mm driver
Reverse clicky tail switch
Magnetic tail
ARC glass
Felt lined battery tube
Carbon fibre bezel insert
Length – 60 mm
Width – 25 mm
Weight – 97 grams (with cell)
Max – 1400lm
Edited by: CRX on 05/07/2018 - 12:49
lionheart_2281
lionheart_2281's picture
Last seen: 2 hours 43 min ago
Another awesome little creation!
You need to make a album or thread with a compilation of all your custom built lights, just 2-3 of each one, they are soooooo good
CRX
CRX's picture
Thanks very much Thumbs Up
Click on the image in my sig Wink
leroycp
Last seen: 3 hours 7 min ago
Cute little thing it is. Are you going to use a carclo lens?
lionheart_2281
Lol!!! Way ahead of me it seems, that’s unreal
CRX
CRX's picture
No, for a few reasons.
I did think about it but this is the last cutting of 1” alu tube that I had and it was just not long enough for an optic to be installed.
I considered not using the brass pill and having virtually no heatsink but as this is a set with the larger zoomie light I felt the floody mule complimented that.
MRsDNF
MRsDNF's picture
Last seen: 2 hours 56 min ago
Very clever. What did you use to cut the section from the copper tube?
Ronin42
Ronin42's picture
Last seen: 1 month 1 week ago
everyone should have one of these.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
mattlward
mattlward's picture
Last seen: 10 hours 19 min ago
Once again, Wow!!!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
CRX
CRX's picture
Laservision Big Smile
I cut and filed a section from another piece of copper pipe Wink
MRsDNF
MRsDNF's picture
Neat. Beer
scrumpypaul
scrumpypaul's picture
Last seen: 1 week 2 days ago
Stevi man………………….!!! STEVI!!!!
Just stop it will ya!!!!!????
Absolutely awesome – not just the execution, but the design as well – you don’t half think outside the box mate.
You know where I live. Big Smile
Paul
lostheplot
lostheplot's picture
Last seen: 3 days 2 hours ago
great work as usual
even a index of links to you different builds
sorry all images down
thanks photobucket
DavidEF
DavidEF's picture
Last seen: 1 week 4 days ago
Once again… ART! Great job! Crown
- The YKK Philosophy
