Q8 modding
Big brand lights often have battery carrier.
Also
I still dont see any difference in self-cost with boost drivers.
Well Bistro and Narsil offer such wide setup options and easy too, not matched by any manufacturer, these feel like the most modern UIs
On highest modes less bright does not seem like an issue for high end lights might not get less bright because of voltage drop in cells, they too won’t sustain max brightness because of stepdown.
No choice in UI feels outdated IMHO
Habkng manufacturer decide when or at what temp stepdown is instead of user feels outdated IMHO
Whining PWM feels outdatelights
Used a little Olight the other day, nice regulated output till BAM darkness without warning, first thing popped in my head, “dang the Q8 would have stepped down as warning and I would have had several hours to a day of useful light” that a brand method felt outdated IMHO
As a kid I needed the full amount of cells get get toys running, that was a long time ago, being able to use a light with empty spaces where cells ought to go feels so nice.
And besides all can say how safe series is, when I joined it wasade clear extra care should be taken for series lights and the exploding lights are series lights.
On longer lights the cell at the head gets more heat and thus wears different over time, I swap each charging cycle, this of course is less of an issue with the cells next to each other.
Oops, you’re right, I missed that little word, boost somehow. It was right there all along. Sorry. :person_facepalming:
Still, I’d say buck is better for one reason: it doesn’t strain the cells as much as boost, especially for high output. AFAIK, for cell strain, boost is the worst, then direct drive and/or linear, then buck the least.
How do you all calculate this?
I (in)=I (out)xU(Vf)/U(Vcell)хE(driver eff.) (fixed)
With same eff., there is no difference.
In real world processes are not so simple and input power is not linear and have some “ripples” but both boost and buck have this effect.
Also, how boost can be worst, if peak current will be always lower than DD with same cells-leds?
Well, maybe I don’t understand it well enough. But, I’d think that in converting voltage, the max current is also converted in the opposite direction. So, in a boost circuit, the max current to the emitter(s) is necessarily lower than the max current from the cell(s). For a buck circuit, it moves the other way. Since the voltage is being lowered from cell(s) to the emitter(s), the max current available to the emitter(s) is higher than the max from the cell(s). So, for any specific desired current draw at the emitter(s), a boost driver draws more from the cell(s) and a buck driver draws less.
As the cells deplete, the difference is even greater, as boost drivers have to convert harder, which works the cell(s) harder, at the same time that the cells themselves are getting weaker. Alternatively, buck drivers are actually working less the lower the input voltage goes. The cells have it easy the whole time, while the buck driver can keep the output to the emitter(s) in perfect regulation longer as well.
Like I said, I may not understand this well enough myself. Texas_Ace makes these statements all the time, though. Perhaps he can step in and explain this difference better than I can.
EDIT: Just wanted to address this last statement of yours as well.
In the world I live in, boost is only needed when the cell voltage is too low for the emitter. So, to use the same cell/emitter combo, you would either have to drive the cell harder to keep the same current to the emitter, OR else drive the emitter less hard to keep cell drain the same as DD. There’s no way to keep the same input current as DD while also keeping the same output current as DD. Am I wrong?
To have 80W output, you need 90W input (example).
Please show me difference between eating 90W of power with buck or boost drivers.
Not talking about watts, but current. If you want to talk about watts, the difference is made up in the voltage. So, 4V times 10A is 40W but 10V times 4A is also 40W. The latter case is easier on the cells.
Once again.
Four cells. 90W.
4P=90/4*4=5.6A each cell load
4S=90/16=5.6A circuit load
:student:
Yeah, there’s your difference. :wink:
Correct, sooner or later we will also. Till then we have to make do with what we are given.
The GT just might give us a good carrier to work with for future lights.
He is correct, the current draw from the cells will be the same in either case. The difference is what happens in the wires and traces.
For example in RMM’s mega M6 where everything is in parallel he has to use 3 FET’s, thick bypasses, multiple 18awg thick wires just to reach a max output of ~150w (about 45A) and he said he could bearly get the driver back in place with all the wires crammed into the cavity.
On the other hand my 4S Mega M6 uses a single FET, 22awg bypasses iirc, a single 18awg wire to connect all the LED’s and I then had to add 6 feet of 20awg wire to act as a resistor to reduce the current. I still am putting out ~200w (~60A if they were in parallel with high drain cells) while trying to reduce power.
This vastly improves efficiency and opens the possibility of using a buck driver for even larger gains. The TA buck will handle 15A but a buck driver to handle 45A would not fit in the flashlight.
Hey, we are talking about cells config. All agree that series is better config for leds.
I finally figured it out. Sorry kiriba-ru. What can I say? You caught me not using my brain. :person_facepalming:
No prob.
Im not arguing for buck or boost or else. I just know that it is very hard to short-circuit 4P SRK and much easier to do same with 4S cells without carrier.
I haven’t said a word about the UI. I haven’t said a word about modes, stepdown and other features. All this is great, I also liked it very much and I plan to use. But all this beauty is just a wrapper for the one really bad (for me) thing - for direct drive. And it spoils everything.
You love dragsters, but I prefer a good family car with cruise control - and therefore we have different views on Q8 :wink:
Please understand that I do not criticize Q8 and do not try to look for its flaws. Just users on this forum like DD and so they created just such a flashlight. Give them their due, take this flashlight and make it my version, with blackjack and … :slight_smile:
Yeah, no one is saying that the driver is advanced by any means. It is a crude driver for sure but it is effective and with the fantastic Narsil firmware for 90% of people it is more then they will ever need.
Exactly! Simply my untreated perfectionism does not allow me to use the flashlight quietly … :smiley:
Well, as long as we’re on this discussion, I have to admit, I’d have liked for the Q8 to have a triple channel driver instead of the more “primitive” FET +1 AMC7135 so that most (if not all) the middle modes could still be “regulated” for better efficiency. That discussion did happen at one point, but the decision was made and we’re still going to get a nice light out of the deal, perfectionism notwithstanding.
Agreement here from the “sedan with cruise control” section. Hoping to see people documenting what’s needed to make that sort of change.
I’m delighted that the actual Q8 is expected to be such a good foundation piece of hardwre, one that people can dream about building on.
OP updated with:
