Yes I also found that they mostly draw 3,6 - 3,8A in fet driver configuration. That is not bad for certain configurations cause battery will last longer and performance will be similar to dedomed xm-l2 or XP-L but they will of course draw more current.
And yes it really is greener and uglier than old one. But you will not notice that in reflector lights. You will only notice that in aspheric lights.
So Swib did you tried them in aspheric? If not than you will not notice ugliness of this new s41b emitter and it has nothing with de doming.
I know how to hot de dome(reported from plenty guys that it has least tint shift) and have tried all sorts of solvent methods until I find solvent that works best for me. Boiling hot solvent is best imho and I also can say with confidence that there is no difference in final result with properly(good luck with that ) hot de dome or hot solvent de dome of same S42B emitter except that solvent hot de dome is far superior and easier so I can for example de dome around 50 emitters at once in not more than 15-20 minutes.
So I would really like to see someone who does hot de doming to do the same.
I said several times that I use hot nitro paint thinner (I don’t know if you guys in USA have this).
So I use boiling hot Nitro paint thinner. It is that simple…
Ya I know. But that product is not available in the states nor are the chemicals it is made up of. Those of us in the states are apparently not able to self regulate this kind of product. We need some one like a government to be responsible and block its availability.
I think you just must try stuff in USA that is made for thinning a paint or cleaning brushes from paint.
And remember boiling hot stuff(it would better be to cook that outside because of smelly and potentially harmful fumes).
I had similar problem when I was trying to get how do you USA guys say… “mineral spirits”.
There is no such thing on our market…
I needed that for diluting true oil (an excellent gunstock finish). And at the end I find something that works great (zippo lighter fluid ).
I’ve also noticed that products in other countries like paint thinner and other similar chemicals have good documentation regarding its make up. In the us, i never know what is actually in the product. Sometimes it’s listed on the product itself but often not. So if I want to find a product with taurine good luck to me.
So you finally started to listen to me guys… Works each time, and it works perfect. 2 minutes dome off…
But if you want ultra clear dd die than 15minutes and after that put it in isoproply alcohol bath and blow with compressed air. Result like MEM or Mitko from this thread each time…
Guys. Any nitro thinner from your local shops should work. It does not have to be one I linked. Use from your own local market. For best results follow my mentioned method. My all come ultra clear so should yours…
Edit:
“If you want ultra clear dd die than do 15minutes of boiling(you must see bubbles if it is boiling hot) and after that put it in isoproply alcohol bath and blow with compressed air. Result like MEM or Mitko from this thread each time…”
And perfect method is revealed. :partying_face: For harder silicone base emitters that are hard nut to crack do the same but you can slightly and carefully cut them from side to side with scalpel which will allow better solvent penetration.
You will all thank me after this I did lot of experiments with my market available solvents to find that the best stuff is in front of my nose in basement and it is even not that harmful since a lot of guys cleans paint on their hands and even face after messing themselves with color they just use mentioned nitro paint thinner on the skin
P.S.
Did I mentioned that you can de dome them 5-15-50-100 or even 1000 if needed at once with this method? (just choose proper size pot)
