Hm. I ordered a couple of the tan S2+ with black steel switches.
Now I’ll have to order some more with the anodized switches.
On behalf of Simon I thank you for your support. :+1:
As thanks to BLF members like yourself Simon is going to throw in a free holster for the first 20 BLF orders placed for the desert tan S2+. I’ll include the details in the OP when the new batch is in.
Firelight2, if you miss that first 20 mark just send me a PM and I’ll make sure you get a holster just for making such a cool comment.
Cheers.
New batch? Is the first batch already sold out? I’ve been watching the Aliex store and it still hasn’t shown up there. I know its on banggood but I prefer to buy direct from Simon, no reason to cut banggood in on it.
apparently BG and FT bought up the first batch so none are left for the aliex store
Now I’m itching for the upgraded one. Anodized switch and upgraded firmware,yes indeed!
Thank you for this, I somehow missed that in JDub’s comment about a page ago. Reading comp fail. We’ve waited a long time for this light to be done, a few more weeks won’t hurt
I do admit a bit of concern over the improved aluminum switch though. I’m sure it’ll be fine for normal usage, but I tend to take my things apart and getting an anodized aluminum switch unscrewed from the housing without scratching it up sounds hard. I have no idea how much cost it would add, but I’d love to see him try for something like altin-coated steel. Honestly, even if they never made it into a complete light, if Simon had a batch of those made to sell separately I’d be on board for several.
Saw on BG @ $1.37 each
As mentioned, the stainless switches are now available for individual sale. The black coated steel switches are just not rugged enough long-term which is why he’s going to anodized. Simon is limited to what coatings and processes he can have done in his area and keep cost reasonable. I hear you but you have to realize that 95% of the people who buy this light will never attempt to disassemble the switch.
That reminds me…Simon sent me a picture of the tool they use to install and remove the switches. Unfortunately this is not a commercially available tool The factory that makes his hosts made this tool. I’m showing it just to give people an idea how they’re installed. This is not a switch design that is easy to remove and swap as emarkd could surely tell you.
These custom pliers grip the metal outer switch housing with even pressure so that it can be threaded or unthreaded without scratching everything up.
I’m thinking I may try thin needle-nose pliers with a rubber jar-grip between the switch and pliers to assist in grip and avoid scarring. Maybe there are better methods?
I figured something like that had to be used after trying to remove one of them.
J-Dub74, to sum a little bit so that I (we?) can keep this “on track”, can you confirm that, so far, the “Convoy S2+ Desert tan” version will have:
- DTP copper MCPCB is standard
- AR coated glass is standard
- XPL-HI in a smooth reflector (SMO) as standard (will OP reflectors and XM-L2 be available by request?)
- Biscotti driver as standard(will the 3/5 mode be available by request?)
- Black anodized aluminum switch as standard (no rubber switch, right?)
- Black pocket clip as standard accessory (new version?)
- Lighted tailcap ?? (I got lost about this one…)
Sorry, but as a newbie I need to keep some things on track among all the more specific and technic/technological aspects! :person_facepalming:
Please check what is right and wrong! And thanks for all your work along with Simon! :+1:
You are all guilty in my flashaholism!!! Eheheh
MascaratumB, I will attempt to answer all you questions…
- DTP copper MCPCB is standard Yes
- AR coated glass is standard Yes
- XPL-HI in a smooth reflector (SMO) as standard (will OP reflectors and XM-L2 be available by request?) Yes and Yes
- Biscotti driver as standard(will the 3/5 mode be available by request?) Yes, Yes
- Black anodized aluminum switch as standard (no rubber switch, right?) Yes
- Black pocket clip as standard accessory (new version?) Yes the black clip is included but there is no new version clip yet
- Lighted tailcap ?? (I got lost about this one…) No lighted tailcap
It’s hard for me to keep track of all this too but I do my best.
Is there will be short tube for the Clear also?
… you have to realize that 95% of the people who buy this light will never attempt to disassemble the switch.
Yeah I get that JDub, I’m not the normal customer. Most of us around here aren’t And I’m good with that. I was just saying that if something more robust happened in the future I’d be all over it.
Those pliers are awesome. I’ve definitely never seen anything like that. My method is basically what you said, but I actually keep a pair of pliers with rubber heatshrink tubing shrunk down over the jaws for that sort of work. Its generally very easy on things and I rarely scratch something, but it happens…
Why isn’t the link in OP ? I can’t find link.
- 18350 battery tube as optional Yes, but seperately
Thank you so much! You answered all my questions J-Dub! I know it must be hard to keep all on track but you are doing a great job on that and on letting us know how things advance! :+1:
I will order it from AliExpress store when the second batch arrives, but for any modification I’ll be wathcing this thread!
Once again, thank you! :+1:
Because it’s not yet for sale on the aliexpres convoy shop only on BG and FT.
That pair of pliers looks like it still might be dizzy from the time it spent in the lathe! Looks like a pair of needle (long) nose pliers that had the padding stripped of the handles, then mounted in a four jaw chuck to spin them down to the right size.
Not a difficult task for our talented machinists. The limiting factor is the size of the through hole of the chuck.
Can you make a special order for S2 tan WITH a lighted tailcap? Thanks for answers
I have tried it a few times but a lighted tail on a S2+ with metal switch cover is not very impressive, for me it is not worth the parasitic drain that comes with it when the light is off.
I totally agree with you, there’s no way to make a bright illuminated stainless switch on the S2+…
The space is simply too thin, what makes the rubber boot bright is their larger surface for light diffusion
