The dulling of the tool bits only really come into play when using carbide inserts or carbide tipped tools. It wonât help with a HSS tool. And itâs not really dulling it so to speak just take a stone and barely break the sharp edge.
Are you sure this applies to copper? I have read that the tools should be as sharp as possible, otherwise the copper starts to âsmearâ all over the place due to the rubbery consistency. I also experienced the same thing.
With brass however, it is common to dull up the tools so the tool doesnât get sucked into the material.
I go to a local place called Robert-Cameron. They are one of the few places here that stock a lot of odd materials and odd sizes not just the common ones. I might pay slightly less if I find it online but then I would have to wait for delivery :weary:
I got some work done on the switch. Itâs kinda big and doesnât mesh well with the head but oh well, add it to the list of âbetter ways of doing itâ.
I lathed up a hole punch to make the right size rubber boot
I also cut a foam packer to stop the batteries rattling since there is no spring in the rear.
I fitted the electronics tonight. My mind wasnât in the right headspace when reflowing the leds so it was a bit messy. I displaced a dome with tweezers on one of the leds, iâm considering dedoming all of them. I also couldnât figure out why it wouldnât turn on when I was finished so after some head scratching found I missed a solder jumper on the driver for 2s. So it is functional and iâll tweak it here and there a bit.
