Review : Thorfire S70S (2x26650 xhp70 flashlight)
I use Keeppower ICR26650 5200mAh 3.7v Protected with S70S, works great for me.
NW or WW version?
do you have a picture of the led shelf?
as far as i know, there is only nw 5000k version from banggood.
Yes , i believe it’s 5000K , a xhp70 n4 3a .
Will answer every question , but i will have to check them on the light first .
Thanks !
I have not tested if it goes immediately back into Turbo, from the user manual, Intelligent circuit memory – To save battery power and protect the flashlight from overheating, the flashlight will drop down into High mode after working about 5 minutes in Turbo mode. Therefor, the runtime of Turbo output is an accumulated time.
With a code you will still get it under $39 on Banggood No doubt its a very good deal.
:+1:
Steps down to high after 5 min, you can click back into turbo right after, light still wasn’t even hot for me.
Just did the test .
Steps down every 5 mins (4m 55s) from turbo to high , and as BeardedRaleigh mentioned you can enter Turbo right after that , again and again .
Review updated
This is a mystery: you measure it to only 3220 lumens, while Thorfire says 3960 and that “it is brighter” than the old one. The old S70 got these reviews: “the Thorfire has under-rated this one at 3000 lumens.” JohnnyMac measured it: “4,545 OTF lumens and 9.22A being pulled at the tail (2*4.61A). No mods performed and running KK 26650 cells.” - I have s70 and it is brighter than a headlight…. PD68 Review: Thorfire S70 - XHP70 Monster
Let’s start with this : On your example , amps at the tail are still 4.61 (same current goes though both batteries), but voltage is double (so it doesn’t draw 9.22 amps as you stated).
For N4 bin , Cree claims 3390 lumens at 4.8 amps , so i think 3220 otf lumens at 5.1amps isn’t wrong . I will have to take a deeper look…
Nice review...
I've tested mine with 30q's only so far, my lumen count was a bit higher.
I've got a couple of purple Efest 26650 high drain that should arrive today. (Actually should have got them yesterday it USPS didn't bring them)
I'm very curious of I get a higher tail cap reading or a higher lumen count.
We are trying to work a precise way to measure the distance.
I know half a mile worked out pretty well.
Thanks!
I will probably make some more tests too later today , I’ll report back.
Measured again lumens , now i get 3402 lunens* at the same amps , seems my initial measurement was a little lower (i think i measured lumens after i took the beamshots) .
*All of my measurements are taken 30 seconds after turn on . Manufacturer can claim lumens at the start-up , which i think it is close to 3600
You can always add a resistor to bump up the power on turbo. You don’t even need to unsolder the driver to do it. I’m awful with soldering small things and mine is working alright.
I don’t know how much it is putting out now but its definitely heating up quicker and is brighter. I don’t have a clamp meter to get an accurate reading on current.
It is a little harder to find the same size but I found a listing on ebay for it. Look for a 2512 r100
I have already installed a R100 on my L6 , works great so far ! Draws around 7.5 amps .
I would change it on S70S too , but i think stock mcpcb isn’t DTP so lumens will probably drop fast…
I can test mine later. I can’t measure lumens but I can see how much the output drops over time.
The drops at 5-minute intervals are of course from the turbo timer.
Started with fresh 18650 30q cells.
Ended at 3.8v after 15 minutes.
Head temp hovered around 140f.
thank you for your review.
I was considering the klarus g20 for my bike, which is also a nice choice. It is incredibly affordable price but incredible performance.
big size of this doesn’t matter. because very low price.
how about it’s beam size? i want to know if it is wide enough for bike.
