Sounds like this may be good to upgrade my Supfire m6 with
Thanks for the detailed rundown of this emitter. I got a itch to have a light with each worthy emitter, and I think this would be a good one.
I’m actually a fairly big fan of the SST-50 for it’s efficiency. At higher amps it’s heat can be a problem but for running at low amps it does a wonderful job. One of the lights I use most often is a cheap sharp eagle zoomie with a de-domed SST-50 in it. At low amps it’s still fairly bright and a good 26650 seems to go forever without needed a re-charge. I don’t have the equipment to test it but I always suspected that it must be VERY efficient at low amps. Too bad they are so pricey.
But good news on these new ones. I’ll have to get my hands on a few and see what I can do with them.
Either you’re very wrong or fonarevka’s calculator is:
(click ‘calculate’ button under that url)
SST-50 is not efficient, not at all.
Impressions are never ‘wrong’
I just received five SST-40 from this seller on Aliexpress, they turned out to be the real deal. There is of course no specific information about tint/bin but with my unscientific testing they seem on par with the one I bought from KD.
There is also a bit of green in the lower modes just like the one from KD. The MCPCB’s is not very good but that didn’t come as a surprise. The price has gone up a bit I payed $1.69 a piece.
Nice, I’m always a little leery of buying emitters for aliexpress, but they have done pretty well with flashlights and other things. One thing about them, if you order from them and they don’t come through, you get your money back, no problem.
Nice, the AE seller is really cheap.
And some nice dedoming you did there!
After luminarium iaculator revealed his metode in this thread and I happened to be in Italy so I could buy the “magic” fluid they turn out great every time
Put my SST-40 from KD in a Convoy M1 with a MTN-17DD fet+1 driver and I Really like it. The tint almost has a purplish color to it at higher amps, but not in a bad way, very pleasing to the eye, especially for low CRI.
Hey can you show us the sst40 dedome beamshot?? I don’t mind about the camera quality… you can use postimg.org for loading. Thanks.
I would, but mine is not de-domed, just installed as it came from the factory. Beam looks almost identical to a typical XM-L2 in the M1.
Tempting LED in all, but would be nice to have higher brightness bins available somewhere (for EU).
Still, 2000 Lumen at 20 Watts at 3.6 Volts and 5.6 Amperes is very nice.
Nice find. Thanks for sharing.
I got some from Arrow too: 7500k the highest bin,
The main difference is: when properly dedomed( its not that easy though, at least those samples) The tint didnt shifed much, like only 1000k or something , thus resulting in the best cool white tint( accoarding to the BLFers), like 6000k 1D or so, paired with an the AR glass even i like it.
I tried keeping it at about 7, 7.5 amps tops, to awoid burn-outs
Paied with a good fed dd driver it resulted at arround 2050-2080 lumens( at 7 amps) WHEN DEDOMED, measured with my spectrometer, candelas ( in most knows hosts) are as follows
C8 - 162000
X6 - 108000
L2 - 315000
B158 - 269000
I`ve modded a M3x torch with it too, using a boosted default driver at 7.1amps and it ended at 335k candelas
A very good emitter, especialy if you aint at a good cool white tint after dedoming, simmilar or even an idea better than W2-W3
Thanks Mitko! This is very nice to hear!
Seems like it will be perfect for a lot of builds:
Indeed
Something interesting: even with a battery at 3.45v( a never charged brand new VTC6) it still gives 3.8 amps and 98k candels in a C8 host, a result better than most even high driven XPL emitters in that host
And the hotspot is nearly perfect
How is the color rendering? Any different compared to those Crees?
Nice to hear that report Mitko. I guess I could machine tube for your(mine) Mitko’s thrower and put the buck driver in. 7A for DD fet is not a lot of fun to play but it surely shows potential.
Edit: or longer tube with parallel craddle for 2x18650 and fed dd for a bit longer turbo times…
Thanks for the update Mitko.
Looks good. The candela numbers seem consistent with djozz’s lumen measurements relative to the XPL V6. At 7.5A the SST-40 has about 14% more output than the XPL V6 at 6A (a typical direct drive current for this emitter). I usually get around 94Kcd from a dedomed XPL V6 1A in an X6, and 108Kcd from the SST-40 is a ~14% improvement.
Great new emitter. I’m still waiting on mine from KD.
