New 4XP Noctigon MCPCB for quad optic
You’re very wrong. See the joy after every post in the GXB20/GXB17 threads.
But there’s a place for FET+1 too. It’s cheap and for many uses - it’s good enough.
Personally I can’t wait for Emisar D4, though I admit I hoped for a 3-channel driver.
And at the same time I’m seeking for the absolutely most efficient driver that I want to have in another light.
I’ve been thinking about it too…
The reality is next. If you wanted to make diy driver, you probably gonna have lots of questions, so that would be rather hard even reading forum through traslator. So I can answer the questions and give a few tips etc. how to assemble some of the fonarevka drivers. For example me and “Serp” know how to calculate Indigo, we’ve passed through this way.
Shipping is not an issue from Ukraine it’s about 23$/1 kg by air to any EU country. Yeah… I wish it would be cheaper but drivers are rather lightweight. As always need people and good contacts to cooperate. Interesting topic, worth to think about that more detail.
Not really, flashlight market and users demands are different. Don’t think that all of fonarevka hates D4, many folks gonna buy it :slight_smile:
It is nice to see so many russians (and ukrainions :slight_smile: ) chime in in this thread. I do not understand much of electronics but I like what is going on on Fonarevka, and if the forum was a bit more accessable (the language is a barrier for reading, but certainly for posting there, and perhaps also the culture is different) I’m sure there would be much interest from folks on BLF.
I agree, I am a little interested in trying them as well. I have been trying to get enough info from google translate, but it is not very helpful. I have not even found where to source the boards yet.
It is necessary to create a topic about Indigo 5.2 here on BLF.
There are at least a few ready-made solutions that have been implemented by mag_vitaliy.
http://forum.fonarevka.ru/showthread.php?t=36000
http://forum.fonarevka.ru/showthread.php?t=35427
http://forum.fonarevka.ru/showthread.php?t=30582
http://forum.fonarevka.ru/showpost.php?p=999143&postcount=550
The most difficult thing is to make a circuit board (for me).
Plus there are some moments for calculating the inductance and capacitors.
The basic principle of layout of elements on the board is considered. To ensure that the power part does not interfere with the signal.
http://forum.fonarevka.ru/showthread.php?t=26562&page=8
Reyden half a year ago delved into all the subtleties of building a driver.
But. Even if you assemble the driver according to the scheme that in the indigo theme on the most common elements - it will also work :slight_smile:
This is a very cool driver :slight_smile:
INFERION, the creator of indigo, these are the main points (for me, they were important)
http://forum.fonarevka.ru/showpost.php?p=421591&postcount=436
http://forum.fonarevka.ru/showpost.php?p=421619&postcount=438
http://forum.fonarevka.ru/showpost.php?p=421635&postcount=440
http://forum.fonarevka.ru/showpost.php?p=847002&postcount=202
http://forum.fonarevka.ru/showpost.php?p=845141&postcount=193
This is very interesting and deserves a separate topic :slight_smile:
If this had been a mini-Meteor, I would not have bought two. However, it is reflashable with inexpensive tools, if you would like to port Indigo to it. I would be happy to include that in the repository to help everyone find and access alternate D4 firmwares. I’m planning to make some alternate firmware for it too. :slight_smile:
Don’t worry, outside links are cool here. :slight_smile:
I have Indigo 5.2, dated 2013-12-17. It is old, and is not the same code that the Meteor uses. Do you have a copy of the Meteor code to share under an open-source license?
Exactly. The D4 has no such technical issue.
I made that graph. It shows the output levels for three lights on a visually-linear scale.
Not buying a Meteor is a good way to convince a businessman to make a mini-Meteor. :smiley:
The M43 has smooth transitions between levels. It gives a nice imitation of ramping smoothly, especially when adjusting levels in UI3. However, it can only stop at 9 discrete levels. The in-between levels are inaccessible due to the technical issue, and that is what the graph shows.
The D4 has actual smooth ramping, or pretty close anyway, with 150 discrete levels. It has stair-steps, but they’re very small and very close together.
Unfortunately, Indigo is not the same as what the Meteor used. Indigo also has no published license, so I cannot legally distribute it in the firmware repository. Indigo-compatible drivers are not easy to find or buy in most of the world. Assembly code may also limit its use somewhat, since it raises the barrier to entry.
Can you help with any of these, to make it fully open and available?
“Open Source” means more than just putting code on a web site. It also means giving the code a license which explicitly allows people to use and modify it. There are several open-source licenses to choose from, but I recommend GPLv3 for flashlight drivers.
I like where this is going. :slight_smile:
Am I the only one who finds ads on fonarevka extremely annoying?
Anyway, back to reading.
Very interesting links. Thank you Serp!
Typically there are as many recommendations as there are recommenders. :wink:
I tend to recommend CC0.
Registered users have the option to disable forum advertising in their profile.
Of course Indigo is not a Meteor. In the Meteor, improved algorithms and other modes. And Meteor commercial product. The firmware have only manufacturer.
If I understand correctly, the D4 might be able to do 60W with XP-L HI emitters and a high-amp cell. It’s like a smaller version of the Q8, and the Q8 does over 20 amps. I have a single-cell triple-XPL which does 15 amps. Limiting it to just a few amps would be practical but kind of boring.
The high modes are not intended for long-term use, and if it’s too hot or too bright, there are 100+ lower levels available. Hold the button until it is bright enough, then let go. It does not need to be on “wow” mode all the time.
Many people feel exactly the opposite about this.
In general, I would really appreciate it if people would try not to phrase personal preferences as if they were true for everyone. They’re not. Different people like different things, and it appears that all the recent drama in this thread exists only because the D4 caters to a different population than the M43. It’s a matter of taste, not quality.
Below are a few more examples of things which could be considered over-reaching or rude:
Many people feel this is a good modern driver, not cheap or bad, and that it will be great for everyday use. It’s just a different type of modern driver than what you wanted. Me, I was hoping for a 3-channel driver, like a FET+N+1. But I’m okay with a FET+1.
I’m sure insulting people is the best way to make things go your way in the future.
Comparing this to Astrolux and Manker is a false equivalence. The Astrolux attempt in particular was a disaster.
The D4 is not an Astrolux. I’m sorry you didn’t get a mini-Meteor, but a mini-Q8 is a silly reason to go around insulting people. Even if the runtime graphs aren’t perfectly flat, and even if it might be a few percent less efficient in some modes, it excels in other ways and is still better than most torches in the world.
You have never touched a D4, and claim it is low quality? You claim the UI is bad without trying it? You reject anything with PWM or DD, even though the FET+N+1 multichannel PWM technique is virtually the same as what some premium brands use for current control? Maybe this is just a translation issue, but it sounds like hot air.
It seems almost nobody named AEDe interesting in productive discussion , and respecting other cultures. Hyperbole and insult are the main thing here.
We can stop phrasing exaggerations and personal taste as objective universal truths, please?
Ok, so how does it work? There is ramping from min output to max output, and then there is the FET turbo. So do we know approximately how low low is? And there is a gap between max and FET turbo right? So how bright is max?
This version is free for non commercial use. Newer than M43 firmware version has been developed but it’s not wide spread and avaible only locally to support diy community. Indigo and M43 schemes are almost the same, disadvantage of the fist one is Attiny85 which has not really good built-in amplifier vs Attiny45, that’s it.
40W driver costed me 20-25$ using best end components from digikey and local stores. Here’s original Indigo interface description. Simple words there are 3 main modes with discrete and smooth regulation.
Yes, as you said there are many types of open source licences, this question should be discussed with the author. I’ll try to clarify this topic. What’s your goal, you wanna share drivers and do bussiness? At the moment we’re not allowed to do this.
Yep… that was crazy days :slight_smile: Got a tons of experience.
I don’t have a D4 to measure yet, but as far as I can tell it will likely go from about 1 lumen (maybe lower?) up to about 3000 lumens (ish, depends on emitter type and battery type). My light box maxes out at about 3000 lumens, and I would not be surprised if the D4 exceeds that. If it does, I’ll measure it in some other way.
There is no gap in the ramp. It is a smooth slope all the way from 1 lm to ~3000 lm, with 150 steps between.
This is only an estimate, based on my Q8 prototype which should be very similar, but I expect the 150 output levels will be very similar to this:
1: 1.00 lm
2: 1.30 lm
3: 1.64 lm
4: 2.05 lm
5: 2.52 lm
6: 3.05 lm
7: 3.66 lm
8: 4.34 lm
9: 5.09 lm
10: 5.94 lm
11: 6.87 lm
12: 7.89 lm
13: 9.01 lm
14: 10.23 lm
15: 11.56 lm
16: 13.00 lm
17: 14.55 lm
18: 16.22 lm
19: 18.02 lm
20: 19.94 lm
21: 21.99 lm
22: 24.18 lm
23: 26.51 lm
24: 28.99 lm
25: 31.61 lm
26: 34.39 lm
27: 37.33 lm
28: 40.43 lm
29: 43.70 lm
30: 47.14 lm
31: 50.76 lm
32: 54.55 lm
33: 58.53 lm
34: 62.70 lm
35: 67.06 lm
36: 71.63 lm
37: 76.39 lm
38: 81.36 lm
39: 86.54 lm
40: 91.93 lm
41: 97.55 lm
42: 103.39 lm
43: 109.46 lm
44: 115.76 lm
45: 122.30 lm
46: 129.08 lm
47: 136.10 lm
48: 143.38 lm
49: 150.91 lm
50: 158.70 lm
51: 166.76 lm
52: 175.08 lm
53: 183.67 lm
54: 192.54 lm
55: 201.70 lm
56: 211.14 lm
57: 220.86 lm
58: 230.89 lm
59: 241.21 lm
60: 251.83 lm
61: 262.76 lm
62: 274.01 lm
63: 285.57 lm
64: 297.45 lm
65: 309.65 lm
66: 322.19 lm
67: 335.06 lm
68: 348.26 lm
69: 361.81 lm
70: 375.71 lm
71: 389.96 lm
72: 404.56 lm
73: 419.52 lm
74: 434.85 lm
75: 450.55 lm
76: 466.62 lm
77: 483.07 lm
78: 499.90 lm
79: 517.11 lm
80: 534.72 lm
81: 552.72 lm
82: 571.12 lm
83: 589.93 lm
84: 609.14 lm
85: 628.77 lm
86: 648.82 lm
87: 669.28 lm
88: 690.17 lm
89: 711.50 lm
90: 733.25 lm
91: 755.45 lm
92: 778.09 lm
93: 801.17 lm
94: 824.71 lm
95: 848.71 lm
96: 873.17 lm
97: 898.09 lm
98: 923.48 lm
99: 949.35 lm
100: 975.69 lm
101: 1002.52 lm
102: 1029.83 lm
103: 1057.64 lm
104: 1085.94 lm
105: 1114.75 lm
106: 1144.05 lm
107: 1173.87 lm
108: 1204.20 lm
109: 1235.05 lm
110: 1266.42 lm
111: 1298.32 lm
112: 1330.75 lm
113: 1363.71 lm
114: 1397.22 lm
115: 1431.27 lm
116: 1465.87 lm
117: 1501.02 lm
118: 1536.73 lm
119: 1573.00 lm
120: 1609.83 lm
121: 1647.24 lm
122: 1685.22 lm
123: 1723.78 lm
124: 1762.93 lm
125: 1802.66 lm
126: 1842.99 lm
127: 1883.91 lm
128: 1925.44 lm
129: 1967.57 lm
130: 2010.31 lm
131: 2053.66 lm
132: 2097.64 lm
133: 2142.23 lm
134: 2187.46 lm
135: 2233.32 lm
136: 2279.81 lm
137: 2326.94 lm
138: 2374.72 lm
139: 2423.15 lm
140: 2472.24 lm
141: 2521.98 lm
142: 2572.38 lm
143: 2623.45 lm
144: 2675.19 lm
145: 2727.61 lm
146: 2780.71 lm
147: 2834.50 lm
148: 2888.97 lm
149: 2944.14 lm
150: 3000.00 lm
^ Aha! And the intervals are probably made to make it (quasi) visually linear I guess?
I would love it if you could talk to the author. :slight_smile:
My goal is a healthy collaborative community with a solid foundation of open projects that anyone can use and build on. The idea is that a rising tide raises all ships. Instead of trying to make any individual ship taller, I hope to raise the tide for everyone.
It’s nice to have things which are free for non-commercial use, but it’s nicer to have things which are free for any use. If someone takes my code, modifies it, and sells it, I am not harmed. Especially with a “copyleft” license like the GPL, which requires people to give back their changes under the same license. Share and share alike. It may seem strange, but it has proven itself to be a very effective tactic in an information economy. Even traditional institutions like banks are catching on these days:
As someone in the study put it: Open-source makes sense because “You get what you pay for, everyone gets what you pay for, and you get what everyone pays for.”
Not really.
The higher the output, the smaller the % increase per step up.
Thanks. I just put the data in excel, and in single log it’s a declining line. Not sure if it’s supposed to be a straight line in single log to be visually linear; I have to look that up.
