Wish I had more to say but, wow.
Wow. What a read on one amazing light. The effort put into this I can only imagine. Thanks for the comprehensive write up and report. Well done to you both. :+1:
Wow this is amazing
Krasses Teil! 0.o
thanks for sharing !
Excellent job, I’m glad to see more people making these crazy throwers
I had no idea about the Q9WP/Q8WP, thanks for the info.
Very impressive effort. Everything looks really clean; the machined driver section and the internals. :+1:
The size is not too different from the BLF GT.
This hobby is funny. As you noted, that beam is too narrow to be used for most purposes. We flashlight modders sometimes make lights and hope there is a purpose for them, rather than designing a light for a purpose.
The original short-arc bulb in this reflector must also make a very small beam, right? What was its intended purpose?
wow, impressive!
thanks for sharing and showing!
Awesome!
Thanks for the nice words, guys!
Please be careful with the exact designation:
Q9WP is the older, less bright model.
Q8WP is the newer, very interesting LED.
Please send me a message if you ever find a reliable source for low quantities!
I also calculated the spot size of the maxabeam with short-arc bulb above (in reality it’s a bit bigger because the arc is 3D and I only calculated the size of the brightest part of the arc on the tip of the anode). But yes, the beam is amazingly tight.
Applications:
- signaling over long distances (for this the tight beam is perfect)
- blinding people with the strobe mode to stop them (for example the driver of a vehicle)
- funnily: finding things (not so great in my opinion)
Here is a longer list from the manufacturer.
Thank you “The Driver” for the excellent presentation !
I build the light for him during the last 4 month and i am glad to see the result and the response here in BLF.
best regards,
Michael
Welcome to BLF RC-Lights
Great work!
Well my congratulations to The Driver and of course to you Michael. You are expert machinist and the driver is future doctor. His idea and your machining work created something spectacular so my hat down :+1:
Yup, I realized that and edited my post Confusing!
I checked all distributors, nobody has them in stock.
I assume it is because of how recent it is, the datasheet was just made in 2017.
I’ll keep an eye out to see if they get in stock some time, and I’ll let you know if they do. If you see it in stock before me, then you let me know too
Use Octopart.com, it searches all distributors like mouser, digikey, arrow, and many others so you can save time without going to every site.
“UW Q8WP” is what to search for, if anyone else wants to watch for it.
What a fantastic post! It was great to read about the thoughts and challenges and then BAM! Such cool beamshots!
An amazing build and I even learned a few things, though I must admit that most of the technical stuff is far above me.
It is not so much trying to build a useful light, but to build the one you wanted to build
Well done there!
Phil
Dam, this makes the BLF GT like a joke
Impressive
Just finished reading through the whole post
It’s a pretty big coincidence that we both build a light with the black flat at almost the same time
I am almost finished my build, just waiting on some liquid metal thermal paste.
“Minimum distance for accurate measurement of luminous intensity:
Many of you know that one cannot measure the true luminous intensity (throw) of a thrower in 1m distance it the value is supposed to be accurate. The reason for this is that in this distance in some lights the reflector is not completely lit up by the LED as seen from the sensor of the lux meter. One has to go further away and adjust the value for the longer distance. TLF member sma once studied this in more detail here (link is external). We both have the theory that it depends on the difference in size between the reflector and the LED. I have tried to calculate this for my light based on his results with an Olight SR-95 UT.”
I have done some testing, it’s pretty interesting actually.
If you take a piece of paper, poke 3 small holes in it, and put it in front of the reflector/lens of a flashlight you will get 3 separate squares (the die image) projected onto a wall.
In “infinite focus”, which is what you want for ideal maximum throw, these three squares will be centered exactly at the 3 points.
To get a proper lux reading when focused like this, the lux meter needs to be placed at the center, and the flashlight needs to be far enough away that all squares overlap in the middle, including the ones from the outer edges of the lens/reflector.
With this exaggerated huge LED example, all squares would overlap at 1.1m (so you would measure slightly farther than that)
However, with a focusable lens or reflector, you can actually change the focus and make all squares overlap at the luxmeter.
When they are all overlapping is when you get the “sharp die projection” image.
This allows you to take the measurement at a closer distance and get the same cd value when you calculate it back to 1m.
You need to keep in mind though that focused at the luxmeter will not give maximum throw. It should be collimated using that template I posted above for best throw.
For your flashlight, I calculated a minimum distance of 28.5m when it is collimated correctly.
If you want to know how I calculated this stuff just let me know, I can make a separate topic explaining everything.
To measure the maxabeam, I’m not sure how far it would need to be, because unlike an LED the small burning point is not all the same intensity like the surface of an LED is.
That’s a neat method with the 3 holes in the paper, enderman. The condition that there is some overlap of all three squares is equivalent to all of the reflector area being used. Like if you looked straight into the reflector at that distance it would be filled with LED/light.
Exactly
I figured this out because you said that about looking into the reflector and seeing yellow.
best regards,
Michael
Hi and welcome Michael. I greatly admire your skills and abilities. You must be a very patient person.
