Will these fit the Convoy L6?
Probably not if they are big.
Unless l6 has changed
Probably not if they are big. Unless l6 has changed
...and they don't work well in series.
Making them work in series is easy enough, but if the cells are too wide for the L6 tube that is harder to fix. There is apparently some variation in the L6 tube ID. See here for some discussion: Convoy L6... XHP70 Beast! - #3980 by vestureofblood
The liitokala 5000mAh cells are also wider than a typical 26650.
From the discussion in the above link, some new keeppower cells were very wide at 26.9x mm, and these did not fit in some of the L6 tubes. I think people have used the liitokala cells in the L6 with no problem so I would think the shockli cells should work as well.
I do know that some of my customers have had the protected 5200mAh cells fit in their L6s, but I know that the initial copies that I tried them in definitely did not fit. There is indeed some variation in almost all Convoy tubes.
I use KP protected.
The gap i 0.00000mm airtight fit.
Richard,
What is the lumen output of the D4 and when do you expect the Aspire 18350’s to be available? I want to order a couple Shockli’s and a D4 and it would be great it I could order some of the Aspires at the same time. Thanks
Are the D4’s expected to be restocked at some point in the future?
Did you read the product page?
"We will have more stock in just a few days. Hang tight! "
Richard, What is the lumen output of the D4 and when do you expect the Aspire 18350’s to be available? I want to order a couple Shockli’s and a D4 and it would be great it I could order some of the Aspires at the same time. Thanks
I do not know the lumen outputs. I haven't tested them. They should be the same as any other direct drive quad flashlight --- 3,000+ (for a few seconds, anyways).
Aspire batteries should be here soon. They have shipped, but as many of you may already know they have rebadged the "1300 mAh" cells to a more realistic "1100 mAh" battery. It was very kind of them to tell me that after the order had been placed for almost a month and had already shipped.
That sounds good. I will place an order as soon as they get in. Are the Shockli 5500mAh batteries a lot thicker than the Liitokala 5000? I know that they are a tight fit in my SD26vn, but I would most likely use them in my U21vn and EC50vn anyway.
Ah, I only knew of the length issue with some batteries. I didn’t realize there is also an issue with some oversized cells. thanks guys.
Is it possible to stock the XHP35 HI E4-3C again?
Just got the D4’s. My first ramping lights, I like them.
The Nichias get extremely hot within seconds the same with the xpl hi the s4 2b is a little better. With the 18350 they are measure 2.5 inches very short, me likes.
Hey chooma, is the ui ramping only or does it also have presets (low,mid and high)?
Hmmm…… I ordered a Nichia in hopes that it wouldn’t produce as much heat as the xpl hi.
Only ramping, I cant find any presets.
As it ramps to its highest, it blinks, release button, press and hold to go back down. Been using a 30q and a 18350 purple efest.
:+1: thanks for answering. Too bad is doesn’t have presets though, ramping is nice and all but a pain to estimate run time while on the road.
I still might get one if it’s easy enough to reprogram the driver and if it gets available for EU customers.
I am pretty sure that the light can be programed to allow for different levels instead of ramping.
Put new purple 18350 efest at 4.20 in the green nichia ran it until I couldnt handle it anymore 33 seconds.
Checked cell voltage at 3.93 cell was warm. Checked it again 7 minutes later and it is now stable at 4.03
Cell is still luke warm 12 mins later.
Anyway cool lights I dig’em.
