Very nice outcome, & I enjoyed the detailed build post.
I can appreciate how difficult it is to focus such a large reflector on such a small point!
I think I’ll have to update one or two of my throwers with an Osram black…
:+1:
:+1:
I might have missed it but a few questions:
1 what is the depth of the reflector /or/ depth led mounted inside the reflector from the top?
2 what is this black thing in the center of the lens?
The LED is a 3V one right? Why choose this complicated driving engine?
Can you / do you want to give an estimate on the costs of this monster?
Thanks for the tip, we will take a look ;).
Concerning “the record”:
As far as I know this is the farthest throwing portable led flashlight which has a single LED with a reflector. Thats also what I meant when I wrote that it’s a lot of work and rather difficult to reach even higher values with this kind of light.
The farthest throwing led flashlight with multiple LEDs and reflectors is Lumensteins Lux Monster from Xandre. It is much, much bigger though (plastic spotlight host)! With around 6000 lumens it is also more practical, the spot is much bigger. It used to have de-domed XP-G2s and produced 2Mcd with 2000 lumens. Now it does 1.6Mcd with 6000 lumens.
The farthest throwing portable LED “flashlight” is Photons “Scheinwerfer”, it has a very large spheric lens and does 3Mcd.
I would have to check, I don’t know exactly.
The distance from the focal point to the outer rim of the reflector is 9.4cm (this is what I mean with “maximum focal length”).
Michael drilled a hole into the center of the lens because I had further ideas on how to increase the throw. There wasn’t enough time to implement this yet and we don’t know if it will work at all. I will keep it a secret for now ;).
Yes, the LED is 3V (technically it’s almost 4V, the Black Flat has a very high Vf).
This driver is of very high quality in terms of the components used. I don’t think there is a higher quality buck driver for LED flashlights. That is one reason why it is so expensive (also because it’s sold in Germany and the guy is trying to make money with it). It has all the features I wanted (over discharge protection, “nerdy” status LEDs, possibilty of connecting thermal probe) and can go up to a last 11A. I wanted to able to upgrade the light with a better LED and be able to utilize it fully. Newer LEDs are able to take more and more current.
No, not completely. One reason is that I was lucky on multiple fronts. If someone else were to build the same exact light they would pay much more money.
Most importantly you need a large, electroformed precision parabolic reflector and a matching head with large diameter. Where are going to get that and how much will it cost?
If you ask Peakbeam Systems how much a spare head with reflector costs, you will probably fall off your chair as we like to say in Germany. I have heard that they want around 170€/$ for just the glass lens!
- you need multiple Osram Black Flat LEDs for testing, not all are good (but we had more good ones than expected)
- the driver you can replace with a cheaper one, but it needs to be a buck driver (the Convoy L6 driver, FX-30, might be the cheapest, it does 5A from 2S cells, but I don’t know how well it works with 3V LEDs). Otherwise the mtn max buck driver would be a very reasonable option.
- you need a DTP PCB for each LED (for testing)
- you need a variable constant current source for testing (lab power supply)
- you need a way to electrically isolate the batteries from the center solder pad of the LED without negatively impacting the heatsinking (we used a battery carrier which I already had)
- you need a machinist who makes all the parts
- you need to anodize the outer part of the body and gold coat the contact plates
- you need a large UCLp lens (or other ar-coated lens)
You calculate youself what you would pay ;).
Thanks for the detailed answers.
Isn’t the large SST90 amp hungry at 3-4V? Big die?
Dang I hope you’ll be able to compare your monster to the GT when it is done, they are pretty close on a lot of sizes.
Yes the Luminus SST-90, CBT-90 and SBT-90 are 3V LEDs which can take high current (up to 18A). They are actually the LEDs which this driver was originally developed for, I think.
The CBT-140 and the new CFT-90 can take even higher amps, officially up to 28A, but probably even more.
Please do make a thread on your ideas!
I don’t understand how to “read” your graph yet…
My light was focused very carefully by running the LED at 30mA and shining it on a tree 30m away. The measuring was done in 12m distance (I originally thought 8m would be the minimum distance, so 12m sounded good enough).
Did you take a look at sma’s test which I linked to? He showed that 2.5m is the real minimum for the Olight SR-95 UT. What does your method tell you for that light?
I know that my conversion factor is not really based on anything, but 100m distance is something I have read in other places regarding the Maxabeam with it’s Xenon bulb.
The Miller, The plastic center is probably a plug covering the hole for the return wire in the original short arc Maxabeam
That super tight beam is sexy! I love throwers and I didn’t pick up this hobby for the sake of practicality!
This light is quite similar with the on-going BLF GT, and your beamshots can definitely satisfy our thirst of seeing the BLF GT beamshots lol.
This almost makes me want to build a big thrower light, very nice :+1:
The BLF GT has a very similar sized head, yes. But there are some differences.
Well known modder Vinz had a lot of difficulty getting a de-domed XP-G2 correctly focussed an an Olight SR-90 reflector (100mm diameter) a few years ago. He did manage to do it though and it held the “record” for over three years (900kcd). It originally inspired me to do this project. So putting the even smaller Black Flat into the even larger GT reflector might not work or at least be very difficult.
When you make a LED reflector light with such extreme focus, there are some unusual side effects. Many of you have probably noticed that most lights produce a slight donut hole when you hold them close to something.
Well, this light still produces a donut hole in 3m (9.8ft) distance!
You can see this on some of the beamshots, the beam looks “hollow” for the first few meters.
Here is a realistic white wall shot of the hotspot in 2m (6.6ft) distance:
Since you can’t see the corona in that shot here is another one with higher exposure (corona ist now realistic, the hotspot itself is overexposed):
The reason for this is the same as for the minimum distance where one can measure accurate candela values.
this is the most powerful light I have ever seen. congrats on the project! and thank you for sharing it.
I’ll have to repeat others in saying WOW!
Amazingly well done and very well documented. Bravo!
Truly excellent work from both of you. :+1:
A fine example of echt deutsche Gründlichkeit :student: Kudos!!
Everything is thoroughly prepared and documented (before and after).
And what now. Going for the absolute record?
Or just sitting on the sofa, hoping for a rerun of Schimanski?
Thanks guys!
Schimanski sounds good…
Although I prefer Magnum.
There are still some small annoying things to take care of:
- reduce current from 5A to 4.5A by replacing sense resistor
- solve problem of loose and cracked lens
- try to get rid of the high pitched whine by using an alternative firmware version
- change voltage set points of status LEDs to better fit the discharge curve of modern high-capacity 18650s
Also I want a nice looking beamshot which showcases the 2500m ANSI range.
What a gun :exclamation: :smiling_imp:
Congrats for building up this fantastic record breaking construction.
You really make it guys.
The only thing I would like to disagree with, is that this flashlight should be “completely useless though, the spot is way too small to find anything. laughing But then again that was never our intention. The only remaining application: cloud bounce! <img src= ” /> ”.
IMO this light is extremely sensible and very useful flashlight, as cloud bouncing and even spotting a small point of light on other far away objects are some of the really important themes in context with a lot of serious science, at least in modern physics. :student:
Not to forget the infinite eternal wisdom comments on the General Spot Size Factor Theories, that one of my grand-grandvathers used to proclaime while he had to manage a totally unexpected stormy, slippery and curvey late night sidewalk, caused by just one beer too much. But after some decades of nothing but hard work, he came up with his theoretical essence, which is a brilliant piece of mindbreaking cosmic beauty. :innocent:
The fundamentel law is genious and even simple.
As long as the spot size is big enough to enlite the key hole area of my castles front door, there is absolute no problem!
There was a thread where a BLFer spoke about using simple plexiglass
He measured better light pass through then his AR coated glass and a stock lens.
I don’t know who or where but maybe somebody else does for it was met with some disbelief so he posted his exact measurements.
In this case maybe a little less good lens without that light blocking center would be just the same but better looking and much easier to replace (make a new) and cheaper.
Impressive!!! Nice read! Drooling……
Oh, and congratulations!
unbelievable!
