* Setups.h
* Created: 4/30/2017 9:27:32 AM
* Author: Tom E
#ifndef SETTINGS_H_
#define SETTINGS_H_
// Driver Board Settings
#define OUT_CHANNELS 3 // define the output channels as 1, 2 or 3
#define VOLTAGE_MON // Comment out to disable - ramp down and eventual shutoff when battery is low
//#define VOLT_MON_R1R2 // uses external R1/R2 voltage divider, comment out for 1.1V internal ref
// For voltage monitoring on pin #7, only uncomment one of the two def’s below:
//#define USING_220K // for using the 220K resistor
//#define USING_360K // for using a 360K resistor (LDO and 2S cells)
#define D1_DIODE 4 // Drop over rev. polarity protection diode: 0.2V normally, 0.3V for Q8
// For 2 channel (FET+1) boards:
//#define USING_3807135_BANK // (default OFF) sets up ramping for 380 mA 7135’s instead of a FET
// For 3 channel (triple) boards:
#define TRIPLE_3_7135 // Configure for 3 7135’s
//#define TRIPLE_8_7135 // Configure for 8 7135’s
#define ONBOARD_LED // Enable the LED support
// Temperature Monitoring
// Temperature Calibration Offset -
#define TEMP_CAL_OFFSET (–19)
// –19 For the OTR M3 (15 mm TA triple), –22 might be closer/better
// –2 try for the Manker U21 (LJ)
// –2 works for the Warsun X60 (robo) using the 17 mm DEL driver
// –1 try this for proto #1, OSHPark BLF Q8 driver
// 3 about right for BLF Q8 proto #2 and #3, reads ~20 for ~68F (18C)
// –12 this is about right on the DEL DDm-L4 board in the UranusFire C818 light
// –11 On the TA22 board in SupFire M2-Z, it’s bout 11-12C too high,reads 35C at room temp, 23C=73.4F
// 8 For the Manker U11 at –11, reads 18C at 71F room temp (22C)
// 2 For the Lumintop SD26 at –2, reading a solid 19C-20C (66.2F-68F for 67F room temp)
#define DEFAULT_STEPDOWN_TEMP (60) // default for stepdown temperature (50C=122F, 55C=131F)
// use 50C for smaller size hosts, or a more conservative level (SD26, U11, etc.)
// use 55C to 60C for larger size hosts, maybe C8 and above, or for a more aggressive setting
#define TEMP_ADJ_PERIOD 2812 // Over Temp adjustment frequency: 45 secs (in 16 msec ticks)
#ifndef VOLT_MON_R1R2 // if using R1/R2, change the LVP settings in the calibration header file
#define BATT_LOW 29 // Cell voltage to step light down = 3.0 V
#define BATT_CRIT 27 // Cell voltage to shut the light off = 2.8 V
#endif
// Stored Configuration Setting Defaults
#define DEF_RAMPING 1 // 1: ramping, 0: mode sets
#if USING_3807135_BANK
#define DEF_MOON_LEVEL 5 // 0…7, 0: disabled, usually set to 3 (350 mA) or 5 (380 mA) - 2 might work on a 350 mA
#else
#define DEF_MOON_LEVEL 3 // 0…7, 0: disabled, usually set to 3 (350 mA) or 5 (380 mA) - 2 might work on a 350 mA
#endif
#define DEF_STEPDOWN_MODE 1 // 0=disabled, 1=thermal, 2=60s, 3=90s, 4=120s, 5=3min, 6=5min, 7=7min (3 mins is good for Q8 production)
#define DEF_BLINKY_MODE 2 // blinky mode config: 1=strobe only, 2=all blinkies, 0=disable
#define DEF_MODE_SET_IDX 3 // 0…11, mode set currently in effect, chosen by user (3=4 modes)
#define DEF_MOON_MODE 1 // 1: enable moonlight mode, 0: disable moon mode
#define DEF_HIGH_TO_LOW 0 // 1: highest to lowest, 0: modes go from lowest to highest
#define DEF_MODE_MEMORY 0 // 1: save/recall last mode set, 0: no memory
#define DEF_LOCATOR_LED 1 // Locator LED feature (ON when light is OFF) - 1=enabled, 0=disabled
#define DEF_BVLD_LED_ONLY 0 // BVLD (Battery Voltage Level Display) - 1=BVLD shown only w/onboard LED, 0=both primary and onboard LED’s
#define DEF_ONBOARD_LED 1 // On Board LED support - 1=enabled, 0=disabled
// Operational Settings Enable/Disable
#define STARTUP_LIGHT_OFF // (default ON) for ramping from power up, main light OFF, otherwise set to max
#define STARTUP_2BLINKS // enables the powerup/startup two blinks
#define LOCKOUT_ENABLE // (default ON) Enable the “Lock-Out” feature
#define TRIPLE_CLICK_BATT // (default ON) enable a triple-click to display Battery status
#define RAMPING_REVERSE // (default ON) reverses ramping direction for every click&hold
#define OFFTIME_ENABLE 0 // 1: Do OFF time mode memory for Mode Sets on power switching (tailswitch), 0: disabled
//#define BLINK_ONLY_IND_LED // blink the Ind. LED, not main LED for: startup, config settings, Enter/Exit lockout blinks
//#define ADV_RAMP_OPTIONS // In ramping, enables “mode set” additional method for lock-out and battery voltage display, comment out to disable
// Timed Settings
#define RAMP_SWITCH_TIMEOUT 75 // make the up/dn ramp switch timeout 1.2 secs (same as IDLE_TIME)
#define STROBE_SPEED 14,41 // 14,41: 18Hz, 16,47: 16Hz, 20,60: 12.5Hz
#define SHORT_CLICK_DUR 18 // Short click max duration - for 0.288 secs
#define RAMP_MOON_PAUSE 23 // this results in a 0.368 sec delay, paused in moon mode
// One-Click Turn OFF option:
#define IDLE_TIME 75 // make the time-out 1.2 seconds (Comment out to disable)
// Switch handling:
#define LONG_PRESS_DUR 24 // Prev Mode time - long press, 24=0.384s (1/3s: too fast, 0.5s: too slow)
#define XLONG_PRESS_DUR 75 // strobe mode entry hold time - 75=1.2s, 68=1.09s (any slower it can happen unintentionally too much)
#define CONFIG_ENTER_DUR 200 // In Mode Sets Only: Config mode entry hold time - 200=3.2s, 160=2.5s
#define DBL_CLICK_TICKS 14 // fast click time for enable/disable of Lock-Out, batt check,
// and double/triple click timing (14=0.224s, was 16=0.256s)
#define ADC_DELAY 312 // Delay in ticks between low-batt ramp-downs (312=5secs, was 250=4secs)
// Strobe/Blinky mode Configuration
#define BATT_CHECK_MODE 80
#define TEMP_CHECK_MODE 81
#define FIRM_VERS_MODE 82
#define SPECIAL_MODES 90 // base/lowest value for special modes
#define STROBE_MODE SPECIAL_MODES+1
//#define RANDOM_STROBE SPECIAL_MODES+2 // not used for now…
#define POLICE_STROBE SPECIAL_MODES+2
#define BIKING_STROBE SPECIAL_MODES+3
#define BEACON_2S_MODE SPECIAL_MODES+4
#define BEACON_10S_MODE SPECIAL_MODES+5
// Custom define your blinky mode set here:
#define SPECIAL_MODES_SET STROBE_MODE, POLICE_STROBE, BIKING_STROBE, BEACON_2S_MODE, BEACON_10S_MODE
#endif /* SETTINGS_H_ */
