pkcell 14500. surprise! rated 750mah got 844@500ma
56 posts / 0 new
snakebite
snakebite's picture
Last seen: 15 hours 18 min ago
pkcell
got a pair of these to test.
844mah @ 500ma.
50mohm ir.
got some 10440 too.
they look to be the same cell efest relabels.
same ir too.
one set came from durnergy01.
other from fuspower2014.
orders were shipped together.
EasyB
Last seen: 1 hour 42 min ago
Nice find. I’m not sure about your IR reading though. How did you measure it? I ask because the best 14500 cells, like the windyfire, have around 70 mOhms.
snakebite
snakebite's picture
EasyB
Well if your measurements are correct this 14500 looks to be the best available.
snakebite
snakebite's picture
812@1a
snakebite
snakebite's picture
after 3 cycles my sample of 2 are 854 and 857 @ 500ma.
great performance from cheap cells.
AlexGT
AlexGT's picture
Last seen: 15 hours 45 min ago
Looks like a great find, What charger/discharger are you using?
$6.99 shipped for 2 pieces? I’ll give them a try!
Thanks for the headsup! Beer
snakebite
snakebite's picture
original triton.
charging at 650ma in a 8 bay “i8” blank charger.
they are rated for max of 1c charging so should be fine.
a lower rate would be better.
once my holders get here i will start on 10440 from the same seller.
650ma charge rate too high on those.will have to use a homebrew unit with a modified tp4056 or go slow by charging with the triton.
the pkcell and the efest 10440 both are right at 1.5a in my pf01s.
confidence is high they are the same cell without paying for a rewrapper middleman.
Muto
Last seen: 23 min 24 sec ago
Thanks for the heads up snakebite, ordered a set of both.
Got the 10440 with charger for less than the batts themselves:)
http://www.ebay.com/itm/2pcs-10440-AAA-Size-Li-ion-Rechargeable-Battery-350mAh-3-7V-Smart-Dual-Charger/132066536002?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Later,
Keith
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
mrheosuper
Last seen: 2 weeks 4 days ago
i still wait for more test, the wrapping look so cheap
Forgot my pen
EasyB
There are also several reports of similar high capacity in the reviews here:
https://www.aliexpress.com/item/4Pcs-PKCELL-ICR14500-Battery-3-7V-750mAh-Rechargeable-Li-ion-Battery/32619950898.html?spm=2114.search0306.4.7.B0riIl#feedback
But I’m still a little skeptical of the reported low IR. snakebite, do you happen to have a direct drive 14500 light that you can measure the current in to confirm the low IR?
snakebite
snakebite's picture
the 10440 happily pushes 1.5a into an xp-g2.
the ir reading i get from the dick smith esr is the lowest i have seen in a 14500.
i will do a quick dd test later.
as a reference a sanyo 14500 shows 90mohms on the esr meter.
tempo
Last seen: 13 hours 12 min ago
How did you measure the IR?
snakebite
snakebite's picture
Barkuti
Barkuti's picture
Last seen: 36 min 18 sec ago
Nice find!
Made a search looking for a seller with free shipping to where I live. Result summary for anyone interested: “14500” search in DURNERGY store
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
snakebite
snakebite's picture
10440 #1
366mah@200ma
snakebite
snakebite's picture
the wrapping is not cheap.if the effort to trim the bottom overlap on the 10440 is any indication they will hold up just fine.
Barkuti
Barkuti's picture
Well, just looking at HKJ's discharge graphs and crunching a few numbers my cold cell internal resistance estimation for the Sanyo UR14500P is almost 190mΩ.
Before HKJ reviewed the TrustFire IMR14500 (red-gold) I had already cooked a homemade internal resistance estimation for it, which came out at 80 & 82mΩ for the couple cells I had lying around at the time. Cold cell values, remember. Done by measuring cell resting voltage before and after applying charging current to it, averaging this value, and measuring cell voltage while charging current was being applied (at middle charging time lapse).
Also did that to six LiitoKala INR26650-50A cells, attaining nearly 23mΩ on average.
I'm not holding my breath with regards to discharge performance for these PKCELL cells.
JPLight
Last seen: 2 years 1 week ago
Yes, nice find !
I have been searching for some good budged 14500 for some days now. So I will give them a try.
@Barkuti
Found the store as well with free shipping to Germany … ordered one lot. Thumbs Up
snakebite
snakebite's picture
Barkuti dont hold your breath.
they fall on their face at 2a.
still beats the sanyo at 1a
they are rated at 1.5c max continuous.
remember these are icr.
and my sample of 1 sanyo droops even worse than these at 2a.
so its a cheap cell that still beats the sanyo at 1a
Agro
Agro's picture
Last seen: 1 min 15 sec ago
snakebite wrote:
10440 #1
366mah@200ma
So much more than Efest which is 308mah@200ma or 281mah@2A according to HKJ and 276mah@2A according to accudb.
I wonder what are the discharge curves…
bguy
Last seen: 7 months 2 weeks ago
The PK cells look to be unprotected ICR, where the Efest are IMR? That would account for the greater capacity.
I need more 14500, but I want either protected ICR or IMR chemistry.
snakebite
snakebite's picture
this is where things get muddy.
pkcell is an oem.
efest a relabler.
who has been caught in lies before.
pkcell calls this cell icr.
it and the efest tested within 10mah under the same conditions.
physically the efest and pkcell are identical.the ir is identical.
who is lying?
guess.
at the price point of these i know which i would buy.
dont need to pay a middleman to slap a fancy sticker on it and charge more.
pirate joe 22
Last seen: 1 week 13 hours ago
thx for info… still happy with your pkcell batteries ??
JPLight
Not yet … still waiting for delivery. Angry
alphazeta
alphazeta's picture
Last seen: 1 year 3 months ago
Has anyone here tried their luck with those PK RCR16340 cells? I’m tempted to grab a few…
JPLight
Tempted as well, but I will wait for those 14500 first.
Has anybody ordered Pkcell 16340 ?
snakebite
snakebite's picture
my 10440 and 14500 are fine.
need someone with test gear to test the others.
or some to find their way here.
Box
Got 4 X of their 18350 900mah. I’ll discharge test two and report back.
I’ll do some ceiling bounce test with a cheap lux meter against Keeppower 18350 too. Haven’t got the Aspires yet
snakebite
snakebite's picture
if i had something to use them in i would have gotten some.
looks promising if they are anything like the 14500.
jf_smm
Last seen: 1 day 10 hours ago
Box wrote:
Got 4 X of their 18350 900mah. I’ll discharge test two and report back. I’ll do some ceiling bounce test with a cheap lux meter against Keeppower 18350 too. Haven’t got the Aspires yet
got these in my watch list pending reviews from you guys Smile
