Generic AAA flashlight variants?
23 posts / 0 new
DoubleA
DoubleA's picture
Last seen: 13 hours 34 min ago
I recently bought a Geonaute OnBright 200 keychain flashlight from Decathlon. It’s a nice and handy flashlight and I like it very much.
It throws a small decent spot with rings and spill and the light is a clean white with no blue tint but not neutral white (5500K maybe). Beam never reaches max 10 meters, anything beyond that is not really visible. The light ain’t very bright but I don’t need a bright light, so the 8 lumens it throws is more than enough for me.
All metal body with a rubber grip in the middle. Both head and tail unscrews and AAA battery can be inserted from either direction. Came with an energizer cell but I use a Panasonic 750mAh eneloop and it works just fine.
Now here is the funny part. I have seen other manufacturers selling the same flashlight with different specs and colors. One of them was Rayovac(Value bright AAA, 5 lumens, 6 hour runtime) and the other was GP (Discovery, CREE led?? 8 lumens, 40 hour runtime on pack, 15 hour on website??? really). I’m pretty sure there are other manufacturers with the same product because this seems to be a generic AAA flashlight which some companies like these buys and rebrands them.
Here are some pics for easy comparison
If anybody has seen similar flashlights then please post it here. Smile
and on the first day he said "Let there be light"...
Edited by: DoubleA on 07/10/2017 - 11:12
Silent_Star
Silent_Star's picture
Last seen: 5 hours 38 min ago
 Genesis 1:3 "And God said, "Let there be light,"  and there was light."
DoubleA
DoubleA's picture
Yupp… that’s the same thing. I wonder who is the actual manufacturer.
It says 40 hour runtime on the pack but only 15 hours on the website. Big Smile
I believe Rayovac’s claim (5 lumen 6 hour) to be more realistic.
sbslider
sbslider's picture
Last seen: 2 hours 47 min ago
I would be surprised if the 5 lumens did not last 15 hours with a new alkaline battery. I ran my lumentop worm at 3 lumens out for 31 hours on a 750mAhr eneloop. At the current required for 5 lumens (likely around 50mA, maybe less) the alkaline is good for 1000mAhr or so.
DoubleA
DoubleA's picture
15 hours with an alkaline? I don’t think so. Even theoretically 1000mAh from an alkaline could run a 50mA (0.16W) LED for only 9 hours and that too only if the boost converter(or Joule thief) inside the flashlight is super efficient. I don’t think the circuitry in cheap flashlights could achieve such results.
As a matter of fact the converter draws a lot of current to maintain stable output voltage and this current draw will substantially reduce the alkaline’s capacity (alkalines can’t handle high current draw) which will in turn cause the alkaline’s voltage to drop rapidly because of it’s chemistry. With an eneloop you could basically get better result because the capacity of LSD NiMH cells are not seriously reduced with higher current draw unlike alkalines and also eneloops maintain a stable voltage output unlike alkalines.
What’s actually happening is the cheap converter is giving less current and the LED will run longer although with a reduced light output. Smile
sbslider
sbslider's picture
Maybe you are correct. I made my assessment based on data I have taken with flashlights I own. My Manker E01 ( a sort of cheap flashlight, but not as cheap as those above) draws 73 mA at 1.3V input to deliver 7 lumens with a Nichia 291B emitter. My Lumintop worm (even less cheap) draws 26mA at 1.3V to deliver 3 lumens with a Nichia 291B emitter. I use 1.3V as the alkaline starts at 1.5V or better, and decays during the discharge to 1V or less. I have tracked the discharge of an alkaline at rather low currents (5-10mA) over a 17 day period so I have some idea of how they perform. I don’t think the performance is significantly different in terms of the discharge curve at the currents I am talking about.
I rationalized that a 5 lumen device could consume 50mA, and with a 1000mA battery 20 hours is possible. 15 seemed easy. But I have not tested any current draws on the cheap lights mentioned above, so my numbers could be all wrong for that case. Not sure of the math you used to determine a 1000mAh battery can provide 50mA for only 9 hours though. Take a look at this: http://lygte-info.dk/review/batteries2012/Duracell%20Plus%20Power%20AAA%...
For 0.1A discharge, the battery lasts 9.5 hours to 1.0V. I think you would agree for a 50mA discharge, the duration would be at least 2x if not more, as alkalines do better at lower currents.
DoubleA
DoubleA's picture
You own decent branded flashlights which probably has really good and efficient circuitry and can provide good runtimes with consistent output. Mine is a cheap generic rebranded one.
Big Smile My bad here. I mistakenly calculated for a 50mA LED current draw instead of using device current draw. You are absolutely correct here.
Thanks for AAA discharge tests link. You can clearly see that the capacity of an alakaline (duracell) is 1000mAh at 100mA draw whereas it’s 500mAh at 1000mA draw. The capacity of Alakaline is heavily depending on it’s current draw. Eneloops fares better at higher current draws.
However the capacity in our flashlights won’t be affected due to low current draws, so yes you are correct once again that alkalines will perform better in these low power flashlights. Only on current draws above 300-500mA will eneloops be a better choice than alkalines.
So it is indeed possible for these flashlights to give 15-20 hour runtimes, that is if the circuitry is efficient. Have a look at this video and you can see that a poorly designed one can be very very inefficient as well.
sbslider
sbslider's picture
I enjoyed the video, thanks for sharing!
Manx
Last seen: 9 hours 35 sec ago
You’re right!
It’s a nice looking little flashlight, and I would buy it too (@Decathlon) but I don’t want to pay it 8/9 euro… Sad
www.youtube.com/channel/UCeDhMPm0L1yvr3LpygDPgMw my flashlights/knives/gear video reviews
www.absoluteblack.net my dark comics
DoubleA
DoubleA's picture
I bought it because in my country I don’t get any major branded ones. Fenix, Nitecore, Thorfire etc all are sold at double or sometimes triple their actual price because of import duty and other tariffs.
However if you really like it you can buy the same from other sources like I mentioned because this is just a rebranded flashlight. The original one may only cost half of what it the Geonaute one costs.
Cythras
Cythras's picture
Last seen: 2 days 4 hours ago
Interestingly, I have owned the Rayovac pictured above, grabbed it from Walmart many years ago. Used a standard 5mm LED with a collaminating lens, and was dimmer than the similar penlight model they sold at that time. Fairly blue tint as well, though maybe they have changed in the last 5 years or so.
DoubleA
DoubleA's picture
Maybe so, the head and tail of rayovac looks quite different. I have an old generic 3xAAA flashlight that has 9× 5mm standard LEDs with a blue tinted beam and this Geonaute throws more than half the brightness that old one gives sans the blue tint. So I guess this single 5mm strawhat LED used is an improved version.
Here’s the pics of the LED and the beam shot at 1 feet from wall (took using a crappy cellphone camera)
I also thought of mentioning the tiny knurlings/grip all around it’s body. Dunno if Rayovac or GP has them, couldn’t make out from the web images so please confirm. Feels damn so good in hands. Big Smile
Edit: just noticed it now, The head and tail section looks slightly different from advertised picture. Also logo is different.
managed to find a beamshot of the rayovac from an amazon review. Courtesy of “NLee the Engineer “
Cythras
Cythras's picture
Wow, that Amazon picture is quite the find. The penlight on the right is the one I was referring to, was tinted bluer than the other but had a clicky switch as opposed to the twisty of the other Rayovac. Obviously, the one you own does not have a Cree LED, just a generic 5mm. A similar type was in the Rayovacs. That “Knurling” you speak of is from the milling process, and is actually quite common on the cheapo penlights you can buy on ebay, commonly sold under the “Skywolfeye” name.
Are you looking for a good small AAA torch?
DoubleA
DoubleA's picture
You mean this one ?
Yepp, I do know that it’s no Cree. Actually it’s GP that advertises Cree LED, although Cree does make em 5mm LEDs I don’t think GP ever uses Cree LEDs.
I am looking for a small AAA light/lantern/beacon with color LEDs. If you do know anything good please tell me. So far I looked at Fenix CL05 but I don’t like it’s design, Glotoob seems fine but I guess I need lights to shine upwards, Thorfire KL02 I like the design but don’t want CR123 same with Fenix CL09. Nitecore LA10 looks good but I want a AAA version. I don’t want to fit a diffuser onto a torch.
dhvl1357
Last seen: 17 hours 6 min ago
I bought the same one from Decathlon a few years ago and it died (bricked, can’t even run it using an external power source contacting the terminals in the head).
I believe EDC lights must be extremely reliable so I then got myself an LD01 and haven’t looked back since.
These lights are large enough to be AA lights and dim enough to be incan Maglite Solitaires. Silly
Slow is smooth; smooth is fast.
DoubleA
DoubleA's picture
Oh crap.. I just bought another one a week ago. Facepalm
I was planing to buy Darkvim SK-C30 but then Decathlon reduced the price by 50% so I went for that one instead.
dhvl1357
There’s a code currently on gearbest for the lumintop tool at 9.99 USD. Code is ToolAAA. Buy a handful and you’re set for years. XP-G and Nichia 219, both. Wink
dhvl1357
Sorry for straying offtopic, just noticed you’re from India. Which part?
DoubleA
DoubleA's picture
I’m sorry I dont like the design of that light very much. I need something plain and simple, like nitecore AAA series, but I heard their build quality is not that good which is why I never bought them.
Kerala, where are you from? Smile
dhvl1357
Coimbatore, etta. Smile
DoubleA
DoubleA's picture
very near, anna Smile
dhvl1357
Aha, do ping when passing by/visiting. PM’ing you contact details.
Cheers!
Blazer296
Last seen: 1 month 1 week ago
My favorite EDC shirt pocket lights ( I have 2 w/different leds) is a modified Hugsby XP1. Decent little light for $9, even completely stock.
I got mine from this seller on Amazon both times, and received what I believe to be TRUE Hugsby lights.
https://www.amazon.com/docooler-Flashlight-Pocket-Torch-Switch/dp/B00NV6...
I tried a couple of the cheap $2-3 ones, and they are different inside the head. Have yet to mod one of those successfully. Ruined one, one in the wife’s purse, and on on my desk for cleaning the insides of my pc. (pet hair gets everywhere Facepalm )
Price goes up after mods of course. 12mm fet drivers , with a de-domed xp-g2 in one and currently a xp-l2 in the other. A 10440 doesn’t seem to push hard enough to get them crazy hot too fast (never have checked tail current). I haven’t timed either, but I have them around ~2 minutes turbo timer. Makes a good hand warmer by the time it steps down, but far from too hot to hold.
Cant say I am fond of the xp-l2 in this light though. It is getting swapped to a xp-g3 probably this weekend. We’ll see what I think of that one for a shirt pocket light.
Jim
