Which Flashlight parts can be combined with the Lumintop Tool AAA?
16 posts / 0 new
Coppet
Coppet's picture
Last seen: 16 hours 26 min ago
As already written in the headline, which lamp heads (or other parts) from other manufacturers can be combined (Legoed) with the Lumintop Tool or the Maratac AAA from Lumintop.
I know from own experience that the head of the Lumintop Worm fits on the Lumintop Tool, how about torches like the Thrunite Ti or the Olight I3E or I3S or other brands?
Someone has experience or does someone have these torches to try it out?
Sorry for my bad english:-)
charles lin
charles lin's picture
Last seen: 30 min 48 sec ago
Lumintop Tool copper won’t fit either Olight I3E or I3S
1.Lumintop Tool copper
2.Lumintop Tool with Acebeam PT10 copper head
3.Lumintop Tool with 4seven Preon P1 Copper head
djozz
djozz's picture
Last seen: 7 hours 16 min ago
It is surprising that the Tool does not lego with the small Olights because it fully (edit: not fully, the twisty swap does not make contact with the driver, it would need a solder blob on the ground ring) legoes with their predecessor, the ITP A3 (this is a Ti version)
Btw, you are aware of the what legoes with what thread?
Coppet
Coppet's picture
…maybe the Olight legos with a Lumintop Worm? Because the Tool head doesn’t work with a Worm, the Worm thread is too short for the Tool head Question
Thanks for the link!
jon_slider
Last seen: 30 min 51 sec ago
my Olight i3s has square threads, so won’t lego with anything
My Titanium Thrunite body works with my worm head
but nothing works on the worm body
My Maratac accepts my worm head (note the large gap due to worm having short threads)
My Maratac and Tool heads are interchangeable,
IF they are from the same generation. Pre Oct 2015 Maratacs and tools had shorter threads due to a two layer board. So a early 2015 Maratac body, won’t work w a later model head. Early head on late body, yes, with a wider gap between head and body..
Coppet
Coppet's picture
Thank you all for your help Thumbs Up
-X3-
-X3-'s picture
Last seen: 9 hours 8 min ago
Lumintop IYP365 and Tool heads are reversible Smile
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire : 30+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Coppet
Coppet's picture
The Acebeam PT10 and the Lumintop IYP365 are 2xAAA Flashlights, so did they really work with just one AAA on a Lumintop Tool?
g_sintornillos
g_sintornillos's picture
Last seen: 3 hours 49 min ago
I do not have the Acebeam PT10 but
A picture is worth a thousand words
The battery is an Eneloop white
Sorry for my bad English (gogole translator)
Coppet
Coppet's picture
Thank you and nice patina on your Lumintop Tool Thumbs Up
charles lin
Yap! Both PT10 and IYP365 works fine with Lumintop Tool.
Coppet
Coppet's picture
Thank you Smile Btw, the rubber thing on the Tool switch normaly is black, from where do you get the non black parts?
djozz
djozz's picture
Kaidomain has the most extensive collection of tailcps, but I do not readily know which one fits the Tool.
http://www.kaidomain.com/c/231.DIY-Flashlight-Silicone-Tailcaps
charles lin
I got 10mm(D) x 8mm(H) Glow-in-the-dark Silicone Tailcaps) from KD, you need shorten the nipple inside of Tailcap to fit on the Lumintop Tool.
Coppet
Coppet's picture
Great, thank you both Thumbs Up Time to get me some Glow-in-the-dark Tailcaps Smile
alistomasion
alistomasion's picture
Wow, after your guys disscusion, i know more about Lumintop's product
Lightsetc Amazon - Light up your life:  Decor Light | Flash Light | Christmas Light | Outdoor Party Light | String Light
