Which Flashlight parts can be combined with the Lumintop Tool AAA?
As already written in the headline, which lamp heads (or other parts) from other manufacturers can be combined (Legoed) with the Lumintop Tool or the Maratac AAA from Lumintop.
I know from own experience that the head of the Lumintop Worm fits on the Lumintop Tool, how about torches like the Thrunite Ti or the Olight I3E or I3S or other brands?
Someone has experience or does someone have these torches to try it out?
Lumintop Tool copper won’t fit either Olight I3E or I3S
1.Lumintop Tool copper
2.Lumintop Tool with Acebeam PT10 copper head
3.Lumintop Tool with 4seven Preon P1 Copper head
It is surprising that the Tool does not lego with the small Olights because it fully (edit: not fully, the twisty swap does not make contact with the driver, it would need a solder blob on the ground ring) legoes with their predecessor, the ITP A3 (this is a Ti version)
Btw, you are aware of the what legoes with what thread?
…maybe the Olight legos with a Lumintop Worm? Because the Tool head doesn’t work with a Worm, the Worm thread is too short for the Tool head :question:
Thanks for the link!
my Olight i3s has square threads, so won’t lego with anything
My Titanium Thrunite body works with my worm head
but nothing works on the worm body
My Maratac accepts my worm head (note the large gap due to worm having short threads)
My Maratac and Tool heads are interchangeable,
IF they are from the same generation. Pre Oct 2015 Maratacs and tools had shorter threads due to a two layer board. So a early 2015 Maratac body, won’t work w a later model head. Early head on late body, yes, with a wider gap between head and body…
Thank you all for your help :+1:
Lumintop IYP365 and Tool heads are reversible :slight_smile:
The Acebeam PT10 and the Lumintop IYP365 are 2xAAA Flashlights, so did they really work with just one AAA on a Lumintop Tool?
I do not have the Acebeam PT10 but
A picture is worth a thousand words
The battery is an Eneloop white
Thank you and nice patina on your Lumintop Tool :+1:
Yap! Both PT10 and IYP365 works fine with Lumintop Tool.
Thank you :slight_smile: Btw, the rubber thing on the Tool switch normaly is black, from where do you get the non black parts?
Kaidomain has the most extensive collection of tailcps, but I do not readily know which one fits the Tool.
http://www.kaidomain.com/c/231.DIY-Flashlight-Silicone-Tailcaps
I got 10mm(D) x 8mm(H) Glow-in-the-dark Silicone Tailcaps from KD, you need shorten the nipple inside of Tailcap to fit on the Lumintop Tool.
Great, thank you both :+1: Time to get me some Glow-in-the-dark Tailcaps :slight_smile:
Wow, after your guys disscusion, i know more about Lumintop's product
