Review: Haikelite MT02
83 posts / 0 new
rizky_p
rizky_p's picture
Last seen: 4 days 3 hours ago
HAIKELITE MT02
updated: 18th August 2017
Introduction
Haikelite is a relatively new player in flashlight business they just celebrated their first anniversary. I have Haikelite MT07 and it is a solid thrower that is the reason why i bought another Haikelite and this time it is the Haikelite MT02. I am planning on buy more Haikelite flashlights which i will be reviewing.
Pro:
Simple UI with 1 button only, i found MT07 to be more complicated with 2 buttons operation but not much
The Size is good for hand gripping.
Using 3×18650 in paralel but can also run on single 18650 but i would recommends at least 2 18650s.
Good Run-time, and usable High Mode without getting too hot.
Finishing is good, no obvious flaws
Small light but throws quite a distance this light can be classified as a thrower with good spill.
Tail-stand
Cons:
With 3×18650 MT02 is heavy.
Hot on Turbo.
Not enough flat surface to avoid rolling over your table, the flat side of the switch is barely enough to stop the light from rolling.
Soldering on the spring is not good, some user reports that the spring(s) come off. If you received yours it is recommended to re-soldered all of them.
No spring on the head so bumping/droping the light could switch it off and damage the battery positive
Data from Manufacture
—Emitter: CREE XHP35 HD
—Aluminum Alloy body with HAIII Anodize black surface Finish
—Battery: 3×18650 (Recommend Sanyo GA 18650 3500mAh )
—Aluminum Reflector
— Ultra Clear Double-sided AR coated toughened Glass lens (99%light transmittance)
— IPX8 Waterproof underwater 2 meters
—Max Brightness: CW 2500 Lumens
—Shot distance: 800 meters
—Full Current Regulation; Boost driver ; Real driver efficiency > 91%
— Build-in Anti-reverse protection in flashlight driver.
— Anti-discharge protection;
Accessories: Gift Box ;spare O Rings ; Landyard ;
Brightness Levels:
Low Low 50lumens 75 hrs
Low 250 Lumens 15 hrs
Middle 850 Lumens 5 hrs
High 2500 Lumens 105 minutes
Strobe: 2500 Lumens
User Interface:
Click on — Click off
Hold switch for 0.5 second to change mode
Dolbe click Hidden Stroble
With Last mode momery
LOCK-OUT Function:
When the light is on, fast single click + long press to lock out the switch. Fast click + long press again to unlock the light.
Attention: In turbo mode, the light will become hot , Please do not continuously use Turbo mode for over 10 minutes. If the light gets too hot in turbo mode, please switch the light into a lower brightness level to let the light cool down. The 500 Lumens medium mode is bright enough for daily use.
One thing to notice, the modes is not correct it should be:
Low Low -> Low -> Middle -> High ——> Turbo (double click)
The manual which come in the box is simply incorrect, And also the lumens figures in the manual are also wrong. I dont have accurate light meters but comparation to my other light i can say that Low low 30Lumens, low 220lumens, Medium 600Lumens, High is 1100 Lumens then Turbo is around 2000Lumens.
Attention!!
This have come to my attention that the soldering on the spring is not good (reported by few users) even on the last batch on my MT01. Solution is to re-soldered them. These boards came from both of my MT01 and MT02.
this is how the light is package from Haikelite. A rather flimsy padded plastic box, i supposed this is sufficient to protect the light in shipping and could also be use as a storage when the light is not in use but this is not your typical Pelican Box.
You got 1x MT02, 1 lanyard nicer than the one i got from MT07 and two spare o-rings with different sizes, unfortunately no holster. I prefer a holster with the light this heavy.
THE MT02.
A Distribution board at the tail of the flashlight, this is not the place to insert your batteries, dont be confused.
Tailcap, you dont need to remove this to insert battery. Batteries are inserted from the other side of the tube.
Notice the three spoke pattern on the tail, yes it can Tailstand and there is a hole for a lanyard too.
The inside of the tailcap.
Single button, this is an E-Switch with press or hold activation.
Smooth Reflector and XHP35 emitter. Clean reflector no dust found inside with purple AR coating.
Square thread and enough grease, but i added more anyway. Not easy to cross threading which is nice.
Thread also anodized so mechanical lockout is possible.
This is where batteries are inserted (facing the head) up to 3×18650 can be use for long run-time.
Use less than 3 for emergency only since the light draw plenty amount of amps.
The head, and the driver.
Inside of the battery tube, 3 springs are visible which soldered to the distribution board earlier.
Size comparison to my MT07, another Haikelite flashlight.
Side by side with MT07
MT02 in Hand.
Beamshots
The Hotspot is quite intense, this is a thrower with big spill. This is not a dedicated thrower but a thrower nonetheless.
MT02 Beamshot. (CW)
Convoy L6 (NW)
Haikelite MT07 (CW)
Burn Test on Turbo
0 Minute Mark, Ambient temperature 29c.
1 Minute
2 Minutes
Oh oh, not confortable to hold.
3 Minutes,
Getting toasty, it is already painful (for me anyway Big Smile )
Summary
This is a good light, it has a big intense hotspot probably not suitable for walking. i think SC02 and MT01 is more suitable for closer range since it’s hotspot should be less defined. The spill at the lower level is not bright enough, in the mode where the spill is bright the hotspot is too intense so if you are looking for a mid range thrower with small footprint this light is perfect and i also like the long run-time that the triple batteries offers (compared to single 18650) For a walking flashlight i think SC02 or maybe the MT01 will be more suitable especially SC02 with its flood character.
Additional data:
Battery draw Single Samsung 30Q.
low = 0.19A
mid1 = 0.57A
mid2 = 1.5A
High = 2.8A – 3A
Turbo = 6A(start) 6.15A(few seconds afterwards)
Update: Candela figures
Haikelite MT02: 69120cd / 525m (800m Claimed)
Haikelite SC01: 92160cd / 607m (600m Claimed)
Haikelite MT07: 163584cd / 797m (750m Claimed)
Video Review:
Edited by: rizky_p on 08/18/2017 - 08:42
HaikeLite Official
HaikeLite Official's picture
Last seen: 3 months 4 weeks ago
Thanks a million for the nice review. We will keep working hard to supply quality light.
A new haikelite EDC 18650 will come out soon.
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
hIKARInoob
hIKARInoob's picture
Last seen: 3 hours 55 min ago
The one with the display? Looking forward to it, as well as seeing more other offerings. Thumbs Up
rizky_p
rizky_p's picture
Cant wait to hear more of it. Sent me one Big Smile
eebowler
eebowler's picture
Last seen: 2 months 16 hours ago
Thumbs Up Thumbs Up Is it possible to compare beams and output to a stock C8 (convoy) for example? Thanks for the review. Smile
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
DBSAR
DBSAR's picture
Last seen: 9 hours 54 min ago
nice review Smile they look to be quality built lights. Thumbs Up
rizky_p
rizky_p's picture
unfortunately no, i dont have Convoy C8 but i have the old Ultrafire C8 with XML (not xml2)
The Convoy C8 with xml should have smaller hotspot.
This is Ultrafire C8 with the SMO reflector. It might not represent Convoy C8 in brightness but should be similar in beam pattern.
The Convoy C8 XPL should have even more throw i think and also smaller hotspot.
Pete7874
Pete7874's picture
Last seen: 3 hours 59 min ago
Does this light work with both flat top and button top batteries? Are unprotected cells OK to use in it?
rizky_p
rizky_p's picture
It work with Samsung unprotected 18650 30Q with solder blob, doesn’t work without it.
Fenix 18650 ARB-L2 (68.3mm) protected batteries is too long.
I think any unprotected 18650s should work if you add solder blob, but LG HE4 should work without it as it has slightly elevated positive.
Pete7874
Pete7874's picture
Thanks. I wonder if 18650GA protected would fit.
hIKARInoob
What might work if the batteries are a bit too long is the following trick:
- Remove tailcap
- Remove the 3 screws
- Place a ring (three times) on the screw, between the battery tube and the spring board
- Tighten everything, and make sure the o-ring is not exposed
- This increases effective battery tube length
Cheers. Party
rizky_p
rizky_p's picture
yeah that might work as there is a space behind the board.
- Remove tailcap
Cheers. Party
firedome
Last seen: 4 months 5 days ago
Nice review Thanks.
Wonder by recommend cell is Sanyo GA 18650 3500mAh ¿?
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
Lfatman
Lfatman's picture
Great review! Thank you!
Did you measure Cd?
I think Haikelite’s people are very optimistic. I achieved 127.000 Cd (712m) with original XHP35 HD dedome.
The original flashlight barely reached 500 m.
Pete7874
Pete7874's picture
Because it provides maximum runtime while delivering reasonably high current.
Pete7874
Pete7874's picture
Thanks. By ‘ring’ do you mean a washer?
hIKARInoob
Sorry, yes that is the correct term. Beer
rizky_p
rizky_p's picture
This is what i got:
haikelite MT02: 69120cd / 525m (800m Claimed)
Convoy L6: 78336cd / 559m
not sure why haikelite claimed MT02 as 800m throw lights? since other Haikelite throw is actually spot on.
yeah they seems overly optimistic regarding MT02.
Did you measure Cd?
!{width:90%}http://i.imgur.com/EPCuSM4.jpg!
Lfatman
Lfatman's picture
My readings on MT02 are very similar to yours. I thought mine was underdriven. I feel better now.
Thank you.
hIKARInoob
I thought they changed to XHP35 HD because they couldn’t get a hold of the XHP35 HI emitters. Perhaps they tested with the HI version and just used this lux value.
Pete7874
Pete7874's picture
rizky_p wrote:
This is what i got:
Well, that’s disappointing. My MT02 is en route as I was hoping for a nice budget thrower… I think I should have just saved the money and gotten a Convoy C8…
hIKARInoob
Pete7874 wrote:
rizky_p wrote:
This is what i got:
It still is a lot of throw, and you have a lot more output as well. I believe the spill angle is pretty wide, so the total package may be surprisingly positive. If you still want more throw you can swap to XHP35 HI as well.
Edit:
Check out this video where a modded C8 is compared to the Acebeam L16 (also with XHP35) The latter has an HI emitter, but it’s housed in a smaller reflector, so it’s in a way comparable to the MT02 with an HD emitter in a larger reflector.
There is more to light than just the lux number (check out around 8 minutes 40 seconds): https://www.youtube.com/watch?v=ChGaNA5jLnc
freeme
freeme's picture
Last seen: 29 min 41 sec ago
I got something similar reading too.
rizky_p wrote:
This is what i got: haikelite MT02: 69120cd / 525m (800m Claimed)
500m+ is pretty decent when you are talking about 2000lm+ OTF. It is totally different breed compared with C8.
Pete7874 wrote:
Well, that's disappointing. My MT02 is en route as I was hoping for a nice budget thrower... I think I should have just saved the money and gotten a Convoy C8...
rizky_p
rizky_p's picture
You still got a lot of throw i think, i am not sure how much throw a Convoy C8 XPL HI can make. But the one thing that MT02 is really good at is runtime, with 3×18650 in paralel and Samsung 30Q you have a total of 9000mah.
Haikelite SC01 throws better with smaller reflector and smaller hotspot.
Pete7874 wrote:
rizky_p wrote:
This is what i got:
Pete7874
Pete7874's picture
rizky_p wrote:
Haikelite SC01 throws better if you want more with 26650 the tube is nicer to handle.
Yes, I was debating between MT02 and SC01, but on paper the MT02 had more throw, so that’s what I went with. Also, I don’t currently own any 26650 batteries, so that would have been an additional expense if I had gone with SC01.
rizky_p
rizky_p's picture
Did you get your MT02 with coupon? They now have SC01 for $32 at gearbest with coupon.
Pete7874
Pete7874's picture
Yes, with coupon.
No big deal. I will just wait for it to arrive. I’m hoping I will still like it. I currently don’t own any lights with more than 1,000 lumen output, and none of them are super throwy, so this MT02 light might still be a significant improvement for me.
Hardusvd70
Hardusvd70's picture
risky_p what lux meter did you use to measure your Haikelite MT02, SCO1 and MT07?
Hardusvd70
rizky_p
rizky_p's picture
I made it myself, it uses Arduino nano v3, BH1750 sensor and 0.96in OLED display. Not the prettiest but gives results Big Smile
You can also use your mobile phone, with almost similar result, i dont have dedicated Lux meter.
Pete7874
Pete7874's picture
Got my MT02 today. I love the silver finish. The beam pattern is a bit rough, but I have not had a chance to take it outside yet at night to see what it can do.
- Remove tailcap
Cheers. Party
This actually worked, just barely. The screws are quite short, so you can only accomodate a very thin washer, but it was just barely enough to allow me to squeeze some NCR18650B protected batteries in there.
Thanks again!
hIKARInoob
Hey Pete7874!
Cheers man! I ordered the silver MT02 from Banggood as well. Hopefully within a week I’ll have mine. Less than $40 for such a beauty, haha! It’s my first Haikelite, so I’m stoked alright. Cool
And thanks for the recently uploaded videos rizky_p on youtube; I checked them all out. Thumbs Up
