Oh ok thatās why itās low.
The lens actually has a clear aperture of less than 120mm,
I would say maybe like 110-115mm because the outer edge is not properly aspherized, and just makes a big spill around the hotspot.
92% sounds accurate, since itās not AR coated, and itās just regular N-BK7 glass.
I get 487cd/mm^2 with 110 as the diameter.
Ok.
Why did you buy 10 LEDs if you only tested 2?
Price is cheaper per LED if you buy 10.
Shipping was gonna be like half the cost anyway, so I got 10 to have spares (I only killed one during reflow) and possibly use more in the future.
Maybe later if I feel like it and have some spare money I will buy more PCBs and see if thereās any that have better performance.
Originally I thought maybe just use the same PCB over and over to test all of them, but I didnāt have enough time or patience to do that.
Also it seems like the PCB gets damaged after a long time under high heat, with the top unsticking, so IMO itās better to only reflow an LED onto it once.
For a real test you definitely need to put each LEd on itās own PCB and reflow them all in identical fashion. Otherwise the test might be influenced by how good they were soldered.
Yup. Gotta buy more of those 32mm PCBs they arenāt that cheap!
dang a light bazooka
great detailed build log
very impressive!
Thanks
PVC sewer pipes make great flashlights!
Very cool build Enderman! :sunglasses:
Thanks for walking us through the entire project. Very well done. :+1:
Tips to save money:
I would try to buy the displays, the heatsink and the pvc tube on ebay and replace the battery with an 18650 battery pack from some local shop. I would also replace the blackout material with something much cheaper, especially since you stil have visible spill.
Thank you
I already had the battery from other projects, and the blackout material was from the previous build, it was pretty cheap too.
Cost isnāt really a big issue until it starts getting into the hundreds/thousands for a single part.
Which might happen with the next build I doā¦ :sunglasses: who knows.
Crazy light Mr. Enderman. Crazy light indeed. :+1:
It reminds me on N10Sivern Zombie Slayinator build which unfortunately canāt be seein this thread: N10sivern's Zombie Slayinator - 3rd Annual BLF Contest Hand Made - Grand Finale Posted! cause photobucket images disappeared but you can see his video forwarded at 3.09 here: The Zombie Slayinator - YouTube
Thanks Thatās definitely an interesting looking light, I think I came across pics of it many years ago when I didnāt even build flashlights yet.
I originally got my PVC idea from this guy:
Pretty sure everyone on this forum has seen that video
So you are now holding new world candela record when it comes to led flashlights.
So it throws around 2,2mcd without wavien collar?
Edit:
I canāt help myself thinking what numbers you would got with good XP-G2 here?
But since you only reflowed 2xOsram Black Flat maybe that means they are now more consistently build so maybe we donāt actually need to pick best of 5 or 10?
Excluding the big fresnel builds, yes.
You could argue that a big box with a giant fresnel lens in it isnāt really a flashlight, but a more clear definition is that this is the most powerful LED flashlight with a āless than 12ā size opticā
Also the lux for those freslen builds was measured relatively close, like 5-15m iirc, so unless longer measurents are taken Iām not sure how reliable those are due to massive spherical and chromatic aberration.
It might be that they can produce that high lux at close range because of the diameter, but when measured farther away it decreases at a faster rate than 1/r^2.
Not sure though, because I donāt have a fresnel lens to test.
What I do know though is that when I get back from vacation I will try to save up money for better measurement equipment so I can confirm my lux numbers at even bigger distances (you saw in the other thread how measuring at 5m gave a completely incorrect value)
Currently on my shopping list is:
-second luxmeter from a different brand to double check values with
ā150m laser meter (3x longer than I have right now)
ā1300m laser rangefinder (less accurate than a laser meter but can do way longer distances)
I would guess between 2-2.2Mcd without the collar, yes.
What I would really like to see in this monster aspheric light builds is zooming function. For example 300-500 kcd of very wide flood mode(pure large hotspot that no reflector in a world can compete to) but because of wavien collar flood mode would be very limited right?
The way the single long focal length lens system is set up, it would need to move a very long distance and only widen the beam to like 10-20 degrees instead of 0.
A multi-lens system would need to be used, especially if there is a wavien collar which prevents the lens from getting more than 35mm close to the LED.
In order to get the best throw, I stick to single-optic systems for the least possible loss, and large spill doesnāt really interest me.
Also, with less than 500 lumens coming out of the front, thereās no way to get 500kcd and a wide spot at the same time
500lm at front seems very optimistic also. I would say around 200
True, I just said āless thanā, cause I have no idea
I just checked and it looks very similar in brightness to my 240lm P5r.2.
Makes sense, itās probably close to 1000lm at the current Iām driving it, wavien collar leaves about half of that coming out at 60 degrees, and then about half of that actually hits the lens.
As you can see, lumen efficiency is not key here xD
Black = reflector flashlight
All are LED lights except the Maxabeam.
X axis = candela (cd)
Y axis = throw (m)
PS - the āLightCanon V2ā is this flashlight, which is now named OptoFire
I measured my fresnel box at 13 meter, with the spot focused at that distance. When used at 500 meter I had to re-focus quite a bit. But the shape of the hotspot and tint-gradient was the same for 13 meter and 500 meter, I do not expect a different kcd number for measuring at the two distances.
