I’d be down for one for sure if I knew what they’ve done about the heat issue. I posted about my TN36 getting too hot to hold after 15mins. Is this much heavier? Does it step down earlier.
There is no step down on the prototype and Utorch was asked to leave it that way on the next prototype/sample. So you will need to turn it down yourself when you think it’s getting too hot.
SS flat bezel is my idea, I feel that is more inline with modern lights design like X7, TN36 or MM25MB. SS bezel is much more durable and practical at the same time. After all, we are no creating a "tactical" class light here
X7R will be including a distance/ proximity sensor as a safety feature. Will be sick if they are able to incorporate such feature in UT03.
it is probably because of the BLF Q8 for most member either this or Q8 well i am simple person i take both
I hope we still get good deal even below 500.
What is the idea of the proximity sensor? Is that just a safety feature in case it gets set down while on a high mode? I could honestly do without that myself, but I’ve never seen it before in other lights.
XHP70 has more of the doughnut hole correct? The 70.2 fixes that but it has an inconsistent beam? I don’t actually know what I’m talking about. My only preferences on this thing would be something more neutral white, but I’m interested in the light either way. Still a great deal on a light that puts out around 10k lumens.
