[REVIEW] Sofirn SP32 (XP-L2 18650)
Hey all,
Sofirn was looking for folks to review their new lights, so i offered to review the SF32 18650 cigar shaped EDC light.
https://www.aliexpress.com/item/SP32-Powerful-LED-Flashlight-Tactical-18650-Cree-XPL2-V6-1000-Lumens-High-Power-Pocket-Light-Penlight/32809965513.html
They sent me one to review, so here it is, finallyā€¦
(had some camera issues, hence the delayā€¦)
This came in the mail a couple of weeks ago:
a box
Containing a light in a bubble bag, a micro USB cable, a single slot charger, baggy with 2 spare O-rings, a manual.
And there it is, the SF32. Looks good, i like the stainless steel side switch in particular.
No tailswitch on this one, but you can lock out by loosening the tail cap a quarter turn.
Pretty heavy, but thatā€™s becauseā€¦
ā€¦thereā€™s a battery inside it. :slight_smile:
According to my Liitokala Lii500 the capacity is (not yet finishedā€¦ will update later)
Without battery the light weighs 70 grams
The little charger which was included.
Lubed anodized square threads for the tail cap.
I personally prefer triangular threads because they centre the parts when tightening, but square threads seem to be popular with customers, so they use square threads. :slight_smile:
Itā€™s nicely machined though, i find the whole light nicely machined and assembled, Sofirn did a nice job.
Click for full resolution if you want to read the manual. :slight_smile:
Some highlights:
Seems legit, maybe a little exaggerated, probably LED lumens, but i have no way of measuring it, but iā€™ll compare it with another XP-L2 V6 light later in this review.
Surprise:
Apparently this light can also run on 2x CR123A.
The driver must be a buck driver then.
Unfortunately this is all i can show you of the driverā€¦
That nice brass retainer ring is glued in there, i tried but it wonā€™t budge.
I said i would do a tear down, but the head is also glued, it wonā€™t budge eitherā€¦
Maybe later when i have the courage to heat the lot up with a small butane torch, so that the glue will soften.
The pocket clip is strong and sturdy, maybe a bit too sturdy for my liking.
It will definitely hold the light in place.
The UI is identical to the ThorFire S70S.
But this driver ramps between modes, which is a nice touch.
So itā€™s long press for moon, but you canā€™t go to the other 4 modes nor to strobe from moon mode, you have to turn it off with a short press.
You turn the light on in low mode with a short press, cycling through the modes with short presses, long press is off.
Short press from off is the last used mode, so it has mode memory.
Double click for strobe, both from off and from the regular 4 modes, not from moon.
It seems to be a current regulated buck driver, so: NO PWM :+1:
Now for some more pictures:
It looks the part, between those two must haves. :+1:
ā€¦yeah, the picture turned out rather grainy, but i had to show off my lighted C8 tailcapā€¦
The glass lens is unfortunately not AR coated.
The manual claims it is AR coated, but it is notā€¦ :frowning:
Allright, a beam shot then, on a white structure painted wall:
My camera (i should get a new / better oneā€¦) didnā€™t pick it up too well, so i enhanced it a bit to represent what i see in real life.
I mean the tint shift of courseā€¦
I really dislike tint shift, but it seems the modern LEDs have a lot of it.
And not only the latest Cree LEDs, the Nichia 219C also has considerable tint shift.
So itā€™s no wonder the XP-G2 is still widely used in stock flashlights, or the 219B for that matter.
Shame really, but can be solved with a diffuser film or by replacing the reflector with TIR optics.
Since this light has glued head parts, i could only put some DC-fix on it.
ā€¦and so i didā€¦
Much better. Less throw though, but i like it like this for a 18650 tube / cigar EDC flashlight.
And hereā€™s my other XP-L2 light, i put a Kaidomain XP-L2 V6 ā€˜3Bā€™ in an Astrolux S1 with a Nanjg 105 8x 7135 driver and replaced the reflector with a 30Ā° (i think) TIR optic with a pebbled surface.
As you can see, the modded S1 is brighter.
You can also see itā€™s probably not a 3B tint, although TIR optics do usually have a cooler tint coming out the front, because the cooler light form the front of the LED is also focussed, unlike the cooler spill of a reflector light.
None the less, itā€™s quite a lot cooler tinted than the Sofirn, which is specified to have a 3A tint.
Since the Sofirn uses a buck driver, i didnā€™t bother to measure the tail cap current.
But i guestimate it pushes around 2.4 Amperes through the LED, maybe less, or maybe itā€™s not a V6 brightness bin, or maybe that TIR in the S1 is better than i expected, or is it the DC-fix that dims the Sofirn?
A lot of maybesā€¦ :person_facepalming:
CONCLUSION
I quite like this light.
It looks good, it works well, the UI is okay, itā€™s well built, thereā€™s nothing wrong with it.
But in my opinion they should have used TIR optics and NOT use glue !
This set i received costs around $ 24 on AliExpress.
The light only is around $ 18.
Hope you enjoyed the read.
I was sent the SF36 to review (coming soon!). One thing I noticed on it was the driver retaining ring is reverse threaded and was on tight. At first I thought it was glued, but a good strong twist in the opposite direction loosened it right up. Check to see if the SF32 is the same way?
Yeah i did check for that, but it just wouldnā€™t move either wayā€¦
Iā€™ll have to drill the holes larger for some more serious pliers, thatā€™ll probably work.
Iā€™m wondering whatā€™s inside the charger? :smiling_imp:
I think it actually shuts off when the battery is fully charged, no ā€˜floatingā€™, which is good.
Nice Review, Thanks! :smiley:
I think if this can be by section 18650 is converted to the length of the section 123 a battery I can according to demand to change the length of it It would be a perfect torch
thanks for the review, I saw these at some store at Alie, always browsing around there but didnā€™t even stop and look at these, guess you just never know, so thanks looks to be a alright light.
No. PWM is here :slight_smile: Frequency is 21 kHz.
Hmmmā€¦ Pityā€¦
I should have checked with a fan or somethingā€¦
After my positive experience with my review sample SP31, I bought an SP32 at full price from Amazon.
The SP32ā€™s interface is usable, but could be better. I prefer e-switch lights to have a shortcut to turbo that works from on or off. The light has shortcuts to moonlight, last used mode, and strobe, but not to turbo.
The 18350 battery tube for the Jaxman E2L fits this light perfectly no modification and looks like it was made for the light. The light looks and feels better to me as an 18350 light.
Completely agree with you! It may be the ā€œbiggestā€ flaw, not having the shortcut to turbo, to make this ā€œmyā€ perfect 18650 light!
Other than that, the output, mode spacing, tint and usability are realy good!! :+1:
Hum, nice to know that! I tried the Convoy S2+ 18350 tubes but the light didnā€™t turn ONā€¦
Butā€¦if it works well on Jaxmanā€™s tube maybe Iā€™ll give it a try :wink:
Thanks for sharing!
Since you consider ā€œlast used modeā€ as a shortcut, remember turbo is also memorized as a last used mode.
ETA: after reading your post thoroughly, I see you would desire it accessible from on or off
Actually my grey Convoy S2+ tube also worked without modification. Just make sure to put the tube in backwards with the silver un-anodized portion facing the rear of the light.
Hum, I tried both S2+ tubes I have (black version), when I received the SP32 and a few minutes ago, but none works uspside-down or normally! I guess itā€™s because of the anodization on the top/bottom of the thread, but I wonā€™t risk to scratch it and take it out as I want to use them on the S2+.
I guess Iā€™ll give the Jaxman tube a try :wink:
Maybe the grey version has something different that make contact better than the black one !
Thanks!!
Actually I donā€™t think the anodization on the threads makes a difference here.
If youā€™re having issues itā€™s probably what I experienced when I tried the same thing with my SP31: Even with the tailcap screwed down all the way there was an air gap between the top of the threads and the switch retaining ring. To fix that problem, I cut a thin strip of aluminum and bent it into a C-shaped ring and then inserted it into the tailcap to bridge the gap.
Yeah, I just realized that the anodization wouldnā€™t make the difference!
I took it out of the tube and tried it again and it doesnā€™t work!
I guess it is the contact between the tube and the tailcap or the head, as you said!
Iā€™ll try it later! The SP32 looks nice a shorter shape, so I guess Iā€™ll try to put it that way for sure!!
Thanks again :+1:
