XANES 600LM German Standard Bike Front Light 64 LED Intelligent Brake Warning Bicycle Taillight Set
Using this link you get $14.99 price for the set (promo price is $20.99 right now, “baseline” price is presumably $26.71).
Buying separately current prices are $9.99 for front light and $13.99 for taillight
Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350
Now in promotion - for next 5 days price is $20.95
Both 18650 and 18350 tubes are included, all LED tints (1A, 3D, 5A) available in stock.
Astrolux Flashlight Protected Bag Holster For Astrolux S41/S41S/S42/S42S 12.8x3.2cm
Very good quality single 18650 flashlight holster is now for only $1,29. Fits all Convoy S2/S2+/BLF A6 sized lights perfectly.
1PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery
For next 5 days the price is only $4.99
These are very good high drain cells ideal for BLF A6/Astrolux S1/S41/S42 and other lights with high current requirements (especially FET equipped with drivers).
Nitecore TIP 2017 XP-G2 360LM Metallic USB Rechargeable LED Mini Keychain Light
Use coupon code: f847b2 for 30% price drop ($20.96 at the moment).
Nitecore TIP CRI 2017 Nichia 219B 240LM Metallic USB Rechargeable LED Mini Keychain Light
Use coupon code f847b2 for 30% price drop ( $24.46 -$10.49 at the moment)
Leagoo T5 5.5’’ FHD Dual Rear Cameras Fingerprint 4GB RAM 64GB ROM MTK6750T Octa-Core 4G Smartphone
is now in preorder for $149.99 (target price supposedly set at $199.99) and using coupon code bgt520 you get another 20$ off for the final price of $129.99. This coupon is limited to 100 uses per day.
Specs hightlight:
- 5.5” Full HD 1920x1080 Sharp IPS 400ppi display with Corning Gorilla Glass 4
- 4GB RAM
- 64 GB of storage memory
- metal unibody construction
- Android 7.0
- MTK6750T Octa-Core 1.5GHz CPU
- support TF card up to 256GB
- dual rear cameras (Sony + OV sensors) with LED flash
- standard 3.5mm earphone jack
- 3000mAh LG battery
- front mounted fingerprint scanner
- dual 4G CAT6, dual sim, dual standby
- FDD-LTE: 800/850/900/1800/2100/2600MHz (Band 1,3,5,7,8,20)
- TDD-LTE: B40
Update: »New and better deal details here«
[Qualcomm Certified] BlitzWolf® BW-S7 QC3.0 40W 5 USB Desktop Charger Adapter With Power3S Tech
Use coupon code 25bws7 to lower price by 20% (-$4.80, $19.19 at the moment)
If you could share the coupon code for the NU05 with me, that’ll be appreciated.
PM sent
16% off for Astrolux brand promotion
Coupon code: BRANDATL
20% off for Nitecore brand
Coupon code: BRANDNC
14% off for Convoy brand
Coupon code: BRANDCV
15% off for Xanes brand
Coupon code: BRANDXS
Xiaomi Redmi Note 4 Global Edition 5.5-inch 3GB RAM 32GB ROM Snapdragon 625 Octa-core 4G Smartphone
use coupon code: 7note4ru 12% off.
Current prices are: $145.19 for black version ($19.80), $140.79 for gold version ($19.20).
This is official Global version (with european LTE band B20), and EU charger.
Specs highlights:
- 3GB RAM
- 32GB storage memory
- 5.5” Full HD screen (403 PPI)
- Snapdragon 625 (octacore, 8x ARM Cortex A53 up to 2.0Ghz, 14nm)
- FDD-LTE bands: B1/B3/B4/B5/B7/B8/B20
- 4100 mAh battery
- fingerprint reader
- all metal case construction
Note: BG specs omit TDD-LTE but I believe there’s no Note 4 version without B38 and B40 TDD-LTE bands.
Nitecore TM06S PALMTOP MONSTER 4x XM-L2 U3 4000LM LED Flashlight
Use coupon code d7e4a3 to lower price by whooping -$67.00 down to $92.95
EKEN H9 WiFi Sport Action Camera DV Car DVR SPCA6350 4K 25fps 1080p 60fps 720P 120fps New Version
Using coupon code BGXYH9 lowers price to $31.99 (-$8.00)!!! Best price yet.
This is one of the best cameras in budget segment and has best performance to price ratio.
Preorder deal ended - »Request via PM here« Now below $69!
Astrolux MF-01 18x XP-G3/Nichia 219C 12000LM Super Bright LED Flashlight 18650
is now in promotion preorder for $72.95 until August 08.
Price drop!
Use coupon code a3ee10 to lower price by whooping -$71.45 down to $88.50 !!!
Nitecore i8 Multi-Slot 5V USB Intelligent Charger For Li-ion/IMR/Ni-MH Battery
Use coupon code 347f56 to lower price by -$10.20 to $39.75
Lumintop Tool Ti XP-G2 R5 And Nichia 219B Titanium 110LM AAA Mini LED Flashlight
The flashlight price currently dropped to $42 and using coupon code 2017FNL price is further lowered by -$12.60 to only $29.40 !
Both Nicha 219 and XP-G2 versions are available.
VIOFO A119 1440P 160 Degree Wide Angle Car DVR With GPS-Black
Use coupon code: CE621F to lower price by 20% (currently $74.39).
This camera delivers good quality FHD recordings along with GPS location tracking comparable with products worth 3-4x times the price.
