I thought it was our job to find the bugs, haha! Oh I’m pretty sure you’re right about that I’m afraid… But you never know. I didn’t expect Haikelite to recover so well either.
I believe that DX80 will be close to the stated lumens at least for first 20-30 seconds. Saying this because that 8pcs XHP70 have domes in that last picture , not like DT70 which have shaved domes and automatically less lumens… In practice about 600 lumens less at 5-6Amp, around 3200 per led.
So if they leave domes on it will be 3800x8= 30400 possible lumens on start
I find this an interesting contrast with the DT70 or DN70; those lights are really bright, really compact, and really light. So the lights step down fast. The DX80 on the other hand is really bright, really compact… but really heavy (this is good in my book at this moment). Interesting… :sunglasses:
Maybe something that is bigger and does more than the X65? Seven XHP35 in two-inch diameter non-overlapping reflector wells? Head diameter would be huge, but that is needed for huge beam performance. Such an item, and this item are in my area of interest.
Before I forget, I always need to remind myself: I can always throttle back to middle mode for heat management and longer run time.
According to one picture, the light has 8 x 3000mAh battteries, so this light probably uses the same batteries supplied with the DT70/DT35 (= protected 30Q).
