Imalent DX80 32000 lumen monster
I have some teaser pics…
Just got to find a new image host first as I have binned Photophucket
I thought it was our job to find the bugs, haha! Oh I’m pretty sure you’re right about that I’m afraid… But you never know. I didn’t expect Haikelite to recover so well either.
Just put them on my google drive for now. Try and keep them on here if you can.
Ta
^ That is just stoopid bright (first pic), I literally giggled… And this is why I keep coming back to Imalent… My goodness that is bright… pfff…
That is exactly what i had in mind, our obsession with bright things are beyond our logical sense.
I also have to mention that to me Imalent has the X-factor as well.
When will this light available in the market!
CPU style heatsink.
I believe that DX80 will be close to the stated lumens at least for first 20-30 seconds. Saying this because that 8pcs XHP70 have domes in that last picture , not like DT70 which have shaved domes and automatically less lumens… In practice about 600 lumens less at 5-6Amp, around 3200 per led.
So if they leave domes on it will be 3800x8= 30400 possible lumens on start
Yeah i noticed that in the video too, but no fans visible. i wonder if it’s passive cooling only or using fans like Olight X9.
Also in this picture are not XHP70 2
Maybe they are waiting new LED for production…
few more :+1:
She didn’t say not to post them, but if we keep them in here as much as possible then I may get further info in the future
i wished that they really step up their quality control. If this light turn out to be good i might get one.
1,2 kg and 92mm head ! That will help with heat management !
Having this beast along with BLF GT will make my dreams come true…
But 19V charger for built-in charging no thanks…
I would rather get them out and charge with proper charger…
I find this an interesting contrast with the DT70 or DN70; those lights are really bright, really compact, and really light. So the lights step down fast. The DX80 on the other hand is really bright, really compact… but really heavy (this is good in my book at this moment). Interesting… :sunglasses:
make me wonder what other lights in the new DX series may be in the future.
Maybe something that is bigger and does more than the X65? Seven XHP35 in two-inch diameter non-overlapping reflector wells? Head diameter would be huge, but that is needed for huge beam performance. Such an item, and this item are in my area of interest.
Before I forget, I always need to remind myself: I can always throttle back to middle mode for heat management and longer run time.
Man you sure have impressive collections there @richbuff
Some new pictures (nothing spectacular) can be found here: http://www.fengyunbike.com/thread-103122-1-1.html
According to one picture, the light has 8 x 3000mAh battteries, so this light probably uses the same batteries supplied with the DT70/DT35 (= protected 30Q).
Somehow this light is listed on Ali for 425$
